Old May 31, 2001, 12:14 AM
tnsfrk is offline
Find More Posts by tnsfrk
Ontario Int, California, United States
Joined Feb 2001
Forget about the X-250- Global's SST 09 rocks!!!
Hello guys, I just can't help but share my excitement about my new electric conversion SST 09 from Global-I bought it last friday at Hobbypeople-instore sale for $59.00-it took me one night to put everything-using a 9 x 6 prop from my ferias, electrifly cs20 and a 480 motor with metal gearbox and only using my reliable 8.4 600mah nicad-it flew with authority!! I even able to roll it. I'am of course only using a 3 channel-but it ain't hard to convert it to 4 channel using rudder too with the ailerons-for $59.00 ARF!!! I since gave up on purchasing the X-250 because of the time spent building it plus I don't own a 4 channel yet but the SST 09 in my own opinion can match X-250's flying characteristics using a more potent motor/battery combination and you'll be in the flying field sooner like me! Give it a try guys-you won't regret it.
tnsfrk is offline Find More Posts by tnsfrk
Old May 31, 2001, 12:28 AM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
What motor and gearbox did you use for the conversion. Will it take off from pavement. I have been thinking about doing the same thing my self.
Joe
Joe Elston is offline Find More Posts by Joe Elston
Old May 31, 2001, 03:24 AM
dezflyer is offline
Find More Posts by dezflyer
heli on the brain
dezflyer's Avatar
Apple Valley/Victorville, Ca
Joined Apr 2001
...i was looking at the same deal last week (oddly at the same store probably!), and was thinking about putting a P450T in it. I opted to save the motor for some other future project, and like a kid in a candy store sale, ended up buying a Mirage instead which was also on sale for only 39$. The SST does look like it would take a stronger electric conversion very well, glad to know its capable of getting some of that 'wish i had a X250' off of the brain!
DeZ
dezflyer is offline Find More Posts by dezflyer
Old May 31, 2001, 01:43 PM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
Mike,
I just want to point out a couple things.
You can run the 8x4 on 7 cells at ~19 amps or 8 cells on a 7" prop with no problems, but a 450 with direct drive, with an 8x4, and an 8x800 pulls more than the 20 amp limit of the 450. If the prop unloads well, the 450 may last for a few flights, but if you cross that 20 amp limit, the 450 will not last long.
In addition, I would head the RPM limits of the APC prop. These props are meant to fit on geared motors and they have RPM limits. I blew off these limits and ran one on a 450 direct. Consequently, I had a prop shatter without warning. A blade separated violently as if it had hit something although it had not. Thankfully, I was not in the line of fire as the prop when sailing across my garage.
Dave
dave_lilley is offline Find More Posts by dave_lilley
Old May 31, 2001, 02:19 PM
realdeal is offline
Find More Posts by realdeal
Festina Lente
realdeal's Avatar
USA, KY, Lexington
Joined Nov 1999
Dave - APC makes several props in the 8x4 size. They make a slowly, freeflight, and a thin electric version. The thin electric version should stand up to some pretty serious RPM as it is designed for direct drive. The freeflight version will take even more as it is designed for .25 size glow engines. I know that a friend of mine is using an APC 8x4 on an Electrostreak that turns about 13K RPM with no problems although I'm not sure if it is an E version or freeflight version.
The slowfly prop should definitely be used on a small motor and gearbox. These are the only ones I have seen an RPM warning with.
I am also curious about the current draw of that combo. I know most people run that motor on a 6x4 with 8-cells. An 8x4 would definitely load it up pretty good.
Keith
[This message has been edited by realdeal (edited 05-31-2001).]
realdeal is offline Find More Posts by realdeal
Old May 31, 2001, 03:23 PM
jsc is offline
jsc
Find More Posts by jsc
jsc
Where does it all end?
Boise/Nampa Idaho
Joined May 2000
It only took me 5 days to build my x-250. I am sure it flies just as well, but I am 100% positive it is way easier on the eyes.
Jeff
jsc is offline Find More Posts by jsc
Old May 31, 2001, 05:12 PM
California Condor is offline
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
I run the APC 8x4E on my Veco .19 (a slimmer) at more than 20,000 rpm without problems. Your prop must heve been damaged at some time before the failure. Eut
Originally posted by dave_lilley:
Mike,
Dave
California Condor is offline Find More Posts by California Condor
Old May 31, 2001, 06:19 PM
Leonard is offline
Find More Posts by Leonard
Leonard's Avatar
Tyler, Texas, United States
Joined May 2001
I would agree with the reply by JSC. My X-250 built in less time than most ARF's. It is also much better looking than the SST.
Leonard
Leonard is offline Find More Posts by Leonard
Old May 31, 2001, 09:26 PM
tnsfrk is offline
Joined Feb 2001
-not as fast as the SST 09-it even came pre-hinged-just add CA. There is no question the X-250 looks prettier-but try to compare that with the SST 09 at $59.00 and comparable ability to tear up the sky-there is no question-it's a better buy-Thanks Mike for the info.-I just added a CANOPY out of a small water bottle-cut to shape and spray painted the inside black-man, it's awesome! I can't wait to buy a 4 channel and convert this to a full house. Good luck fellow e-flyers!!!
Old May 31, 2001, 10:54 PM
Texas
Joined Aug 1999
Many of the e-props like the Graupner Slim Props and APC props are rated at ~13-14 RPMs or less. While they may survive for a while, all it takes is one hairline defect or crack. I was just sounding the word of caution.
Dave
Old Jun 01, 2001, 12:24 AM
Mike Greenshields is offline
Find More Posts by Mike Greenshields
Fountain Valley, CA USA
Joined Oct 2000
Gentlemen,
FYI, we've flown that plane with motors ranging from the basic Ezette 380 motor/gearbox/prop to a cobalt 05 on 7 cells direct.
Personally, I like the Multiplex Turbo 450 with direct drive (APC 8x4E Prop), and 8 800AR cells. Run time is a little short (about 3 minutes at full throttle) but the performance is excellent and the battery/motor system is much lighter than the Cobalt.
It takes off from asphault, rolls, loops, etc. and for such a small plane is quite easy to fly and predictable.
Remember, this design has been around since the 70's and I've been flying different version of it since I was quite young.
This ARF version was lightened and modified so that whether you chose an AP 09 or an electric system, the plane would maintain it's best flight characteristics.
Now, of course, my opinion is biased, but I really enjoy this plane and always keep one ready to go.
Have fun,
Mike Greenshields
Hobby People/Global Hobby
Product Manager
mikeg@hobbypeople.net
Mike Greenshields is offline Find More Posts by Mike Greenshields
My X-250 It's baaaaaaaak! ChrisD Sport Planes 4 Aug 16, 2002 02:32 PM
Are HS-55's sufficient for X-250 ailerons,etc ? Al P Sport Planes 8 Jun 12, 2002 08:59 AM
Opinions of Electrifying Global SST 09 kelvin Beginner Training Area (Aircraft-Electric) 5 Feb 18, 2002 05:58 PM
$25 X-250 Upgrade Rocks! EricBjorn Electric Plane Talk 22 Jun 23, 2001 12:53 AM
What's the rpm on your x-250? temacc Electric Plane Talk 5 Jun 11, 2001 10:24 AM
