Old Jan 08, 2008, 07:55 PM
stefalo is offline
Find More Posts by stefalo
Joined Sep 2006
Trying to build a mechanically actuated tricopter, Help!
Hey All,
This is all new to me but so intriguing. I have seen a number of tri and quad copters with complex gyro setups an multiple esc's. I like the idea of varying thrust to roll/pitch/yaw but do not have the electronics needed.
My initial idea was to try a rather small tricopter useing the rotors from a Havoc (hopeing they will keep me from needing a gyro.) Run off of one esc to three motors in a T shape. The two front motors pitch forward and backwards on a single carbon shaft with bushings, via a 3.6g servo on my elevator channel. The tail motor (long part of the T) will rotate left and right on the aileron channel hopefully pushing the tail right and left. Combined I hope to be able to generally fly up, down, left, right and backwards.
I think in theory this is correct. My biggest question is can I run all three motors off of one esc? I have a 15a brushed esc and based on my calculations my max amps will be about 2a? Any help would be greatly appreciated.
Regards,
Stefan
stefalo is offline Find More Posts by stefalo
Old Jan 09, 2008, 06:29 AM
Turnell is offline
Find More Posts by Turnell
Joined Dec 2007
This is the same as you have in mind. Hope this helps.
http://www.rcgroups.com/forums/showthread.php?t=795039
Joe
Turnell is offline Find More Posts by Turnell
Old Jan 09, 2008, 12:30 PM
stefalo is offline
Joined Sep 2006
Picture of my plan
Man somebody always has the idea first. That does help, thank you very much.
Stefan
Old Jan 09, 2008, 04:10 PM
stefalo is offline
Joined Sep 2006
Trying to upload pic
Direction of arrows show shaft rotation.
Stefan
Discussion Help - Klutz Trying To Build Alula Martinuk Slope 5 Apr 26, 2007 11:57 AM
Tryin to build my EZ-400G...Help! FX1SUB Beginner Training Area (Aircraft-Electric) 1 Apr 17, 2002 03:35 PM
I'm Trying to build a . . . . Jar'sbuddy Power Systems 5 Mar 31, 2002 11:50 PM
trying to build battery packs drummermike85 Beginner Training Area (Aircraft-Electric) 10 Jan 09, 2002 12:42 AM
Trying to learn on my own"HELP" Dandi6065 Electric Sailplanes 68 May 14, 2001 07:15 PM
