Old Dec 21, 2002, 07:09 PM
CrashDaddy is offline
Find More Posts by CrashDaddy
Joined Dec 2002
Cul De Sac Flying??
I currently have a sky scooter that I fly at a field fairly close to my house. I feel that I have gotten proficient at flying and have been concentrating on reducing the size of my pattern but I really would like to have a plane that I can fly in my cul de sac. Slow and lazy is my goal. Would the Tiger Moth work?? If not, any other suggestions.
CrashDaddy is offline Find More Posts by CrashDaddy
Old Dec 21, 2002, 08:59 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Tiger Moth will work. Any of the IFOs are fantastic. Just put them into high alpha (high angle of attack) mode, and they practically hover.
http://www.flyifo.com/
Dave Hederich is offline Find More Posts by Dave Hederich
Old Dec 21, 2002, 09:05 PM
SoaringDragon is offline
Find More Posts by SoaringDragon
SoaringDragon's Avatar
New Hampshire
Joined Feb 2002
A cul-de-sac is more than enough space for a Tiger Moth. Build it light, stock is probably o.k. but there are plenty of tips in this forum. I'd highly recommend a 2-cell pack of Kokam 1020's. One may be all you need.
SoaringDragon is offline Find More Posts by SoaringDragon
Old Dec 21, 2002, 09:07 PM
Joined Dec 2002
thks for the info!!
Old Dec 21, 2002, 09:14 PM
Rip-N-Burn is offline
Find More Posts by Rip-N-Burn
Rip-N-Burn's Avatar
Chandler Williams, Arizona, United States
Joined Nov 2002
Had a little fun with the slowstick just today.. Its a bit tough with the weight of the camera as it fly's a bit hotter. The more I fly, the easier it gets though.. this is a real tight area and the road entering my house is a great run way..
Rip-N-Burn is offline Find More Posts by Rip-N-Burn
Rip-N-Burn's Avatar
Joined Nov 2002
heres another yesterday
Old Dec 21, 2002, 09:29 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
ripnburn: Judging by the shadows you must get 4-5 hours flight time. You using one of those new fuel cells?
Gene Bond is offline Find More Posts by Gene Bond
Old Dec 21, 2002, 09:33 PM
Rip-N-Burn's Avatar
Joined Nov 2002
Im out there almost every day now. sometimes several times throughout.. I watch the flag on the side a lot to see if its safe..
Old Dec 21, 2002, 09:51 PM
janitor13 is offline
Find More Posts by janitor13
janitor13's Avatar
Sammamish, WA
Joined Nov 2001
A Tigermoth would be a good choice, and I have flown mine in the street pretty easily. Another suggestion is the Gym-E from Todd's Models, it has an even tighter turning radius than the Tigermoth and will fly slower.
-Brian
janitor13 is offline Find More Posts by janitor13
Old Dec 21, 2002, 09:55 PM
Joined Dec 2002
Is is wise to use the servos and receiver from my sky scooter aside from the battery you recommend or should I use the GWS flight pack?
Old Dec 21, 2002, 10:12 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Use the lightest gear you can get/afford. What servos and RX do you have? The supplied ones in most RTF planes are a little heavy.
The Scooter stuff may be better suited to a bigger model, like a SlowStick. You'll need one eventually
Old Dec 21, 2002, 10:19 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I second the motion for the Gym-E. It will turn MUCH more tightly than a Tiger Moth. The TM is flyable in my cul-de-sac, but it's not all that comfortable. The Gym-E is comfortable and relaxing to fly there. Then, after you get really proficient and want to do aerobatics in the cul-de-sac, get a Tiny-X .
BEC is offline Find More Posts by BEC
Old Dec 21, 2002, 10:23 PM
uglyplane is offline
Find More Posts by uglyplane
Master ReKitter
uglyplane's Avatar
San Diego,Ca, USA
Joined Aug 2000
I vote for the SS. Flys slow (even with the 1100 nimh batt) Quick to assemble and will fly in a little wind. I tried in 10 mph wind today and it flew but it wasn't pretty!
uglyplane is offline Find More Posts by uglyplane
Old Dec 21, 2002, 10:45 PM
Joined Dec 2002
The servos are hitec hs-55 and the rx is the has-3mb.
Old Dec 21, 2002, 10:49 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
The servos are fine. Not sure about the RX, though. Should be OK, as small as the SS is, it should fit fine. Probably lighter than a 555. Can you remove the plastic case and just use shrink wrap?
Flying From my Cul de Sac buzzbee Aerial Photography 2 Apr 06, 2004 07:02 PM
Cul de sac Flyer boomerace Parkflyers 28 Jan 25, 2004 11:10 AM
Cul De Sac Maiden of the Dandy Sport boomerace Parkflyers 18 Apr 09, 2003 02:31 PM
Cul-de-sac flying as cold therapy BEC Parkflyers 3 Mar 30, 2003 07:09 PM
Hippo's Frog is a hit in our cul-de-sac Jgardner Foamies (Kits) 2 Aug 26, 2002 10:47 PM
