Old Jan 06, 2008, 01:57 PM
rcbrust is offline
Find More Posts by rcbrust
Soaring Circuits
rcbrust's Avatar
Coopersburg, PA
Joined Sep 2001
Question
Request for Opinions on RAM3 Batteries
Guys,
I plan on offering a LiPo cell as an accessory for the RAM3 altimeter. As shown below, the cell will come with a lead and connector which will plug directly into the RAM3, making it a self contained package. In other words, you can plug the battery into the RAM3, wrap them up in a piece of foam, and stick them wherever you want in your glider. No need to connect to your receiver.
Now, the question I have is, what size LiPo cell should I go with? I'd like to pick one size so that I can buy them in quantity and keep the price lower. Currently I've settled on two cells, both of which are shown below with a RAM3 and a penny for size reference.
The smaller cell on the top is 30mAh and will run the RAM3 for about 5-6 hours. The cell on the bottom is 50mAh and will run the RAM3 for about 9-10 hours. The size and weights of all three units are as follows:
RAM3: 0.75" long x 0.60" wide x 0.33" thick - 2.2 grams
30mAh Cell: 0.82" long x 0.48" wide x 0.20" thick - 1.3 grams
50mAh Cell: 0.82" long x 0.56" wide x 0.28" thick - 1.8 grams
So, do you think it's worth half a gram and a slightly larger size to get the extra 4 hours of run time? Or, do you think that 5-6 hours is plenty and it's better to keep the size and weight to a minimum?
Thoughts and opinions are invited.
Randy
rcbrust is offline Find More Posts by rcbrust
Old Jan 06, 2008, 02:20 PM
jrerickson is offline
Find More Posts by jrerickson
jrerickson
jrerickson's Avatar
Valencia, CA
Joined Jan 2005
Randy,
I'm for the 50 mah option. Minimal weight gain for many more hours of flight time. Plus, easier not to blow up on charge (until you come out with your charger!)
John
jrerickson is offline Find More Posts by jrerickson
Old Jan 06, 2008, 02:32 PM
rcbrust is offline
Soaring Circuits
rcbrust's Avatar
Coopersburg, PA
Joined Sep 2001
Hmm... I don't know if that's a completely unbiased opinion... considering that 50mAh cell in the picture is yours...
And yes, John makes a good point. Thanks for reminding me. I have a little inexpensive charger designed for safely charging these little cells. It will be a little while though until I can get the pc board laid out and get it into production.
Randy
Old Jan 06, 2008, 03:07 PM
ThermalBuster is offline
Find More Posts by ThermalBuster
ThermalBuster's Avatar
Orlando
Joined Sep 2004
I like the idea of the 50mah in that there is quite a bit of lattitude in the time available. You could potentially use it for a whole weekend if you unplugged between sessions.
How much data (time) will the Ram3 store at say 2 points per second)?
Rick
ThermalBuster is offline Find More Posts by ThermalBuster
Old Jan 06, 2008, 03:25 PM
rcbrust is offline
Soaring Circuits
rcbrust's Avatar
Coopersburg, PA
Joined Sep 2001
Record times are (approx):
1 sample/sec rate - 18 hrs
2 sample/sec rate - 9 hrs
5 sample/sec rate - 3 hrs and 35 mins
10 sample/sec rate - 1 hr and 45 mins
Randy
Old Jan 06, 2008, 03:32 PM
moto0013 is offline
Find More Posts by moto0013
Pleasant Hill CA
Joined Feb 2007
For all of us dlg guys saving the weight is a good thing. And most of us have a way to charge at the field.Either way it looks awesome.
moto0013 is offline Find More Posts by moto0013
Old Jan 06, 2008, 08:21 PM
r3tic is offline
Find More Posts by r3tic
Joined Nov 2006
I'd like to see the 50mAh option.
r3tic is offline Find More Posts by r3tic
Old Jan 06, 2008, 08:47 PM
jirvin_4505 is online now
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
50mah for me .. looks like a great unit.. what will I do with my ram2 now?
cheers jeff
jirvin_4505 is online now Find More Posts by jirvin_4505
Old Jan 07, 2008, 07:07 AM
Orlando
Joined Sep 2004
The 50mah looks like a nice fit to me. Nothing wrong with the 30mah but the 50 isn't that much bigger or weightyier and then you just start it and forget it.
Old Jan 07, 2008, 07:37 AM
rcbrust is offline
Soaring Circuits
rcbrust's Avatar
Coopersburg, PA
Joined Sep 2001
I just realized that I forgot to include one other critical piece of information. At this point in time, the the two cells cost the same.
Randy
Old Jan 07, 2008, 07:43 AM
will_newton is offline
Find More Posts by will_newton
wishes this caption was longe
will_newton's Avatar
wilson, nc, usa
Joined Dec 2005
randy i have one of your older lipos that came with the RAM 2. I have never used because i can't charge it safely. that problem is way more important than battery size.
I suppose you need to keep the gram counters happy. better go small or folks will be mad that it's "too heavy"
If it's not the weight folks will complain about the price of the bigger battery...
there just aren't enough rolling eyes smileys in the world.....
will_newton is offline Find More Posts by will_newton
Old Jan 07, 2008, 08:11 AM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
I vote for the 50mah cell.
Also I suggest you make your charger have a reasonably easy option (eg select jumper, or change resistor) to change the charge current between say 50ma and 20ma, as there are many small cells being used nowadays (eg on indoor toy type helis), and few small chargers.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Jan 07, 2008, 03:48 PM
Orlando
Joined Sep 2004
That's an interesting observation Neil! I have one of those tiny heli's that charges off of the AA powered transmitter. It would be fine if the charger for the 30 or 50mah battery were powered by AA cells rather than having to clip onto a car battery. Any chance?
Rick
Old Jan 07, 2008, 04:09 PM
rcbrust is offline
Soaring Circuits
rcbrust's Avatar
Coopersburg, PA
Joined Sep 2001
It would be possible to do. But, unless I'm convinced otherwise, I think that most people would rather just clip it onto a 12 volt source.
Randy
Old Jan 08, 2008, 10:21 AM
Orlando
Joined Sep 2004
Can't say that I have a good argument for doing something other than a charger powered by 12v. Just seemed like it might be easy to charge off of a 4.8 volt receiver pack or something. Oh, nevermind........
Discussion Looking for quick opinions on a couple batteries before I buy more BuzzBomber Batteries and Chargers 10 May 24, 2007 09:23 AM
Request for advice on motors morage_key_ring Scratchbuilt Indoor and Micro Models 6 Nov 18, 2005 04:04 AM
Looking for opinions on SIMS Murdock Micro Helis 17 Jul 24, 2004 12:20 PM
Looking for opinions on beginer Heli's braxx Micro Helis 3 Dec 26, 2003 11:23 PM
Looking for opinions on this voltage converter idea pcaffeldt Foamies (Kits) 2 Oct 06, 2002 05:35 AM
