Old Dec 21, 2002, 05:42 PM
Wm_cheng
Wm_cheng
Guest
n/a Posts
Newbie question about soldering resistors to motors?
HI all,
I am a newbie with a question about soldering the resistors to the motors.
I just got a Tamiya XB (pre-built) Hummer and would like to replace the
mechanical speed controller with a LRP Runner Plus. I have read the
instructions and my question is that when I solder the resistors, do they go
between the motor terminals and the casing, with the motor lead wires still
in place? Or do I disconnect the motor lead wires and connect them through
the resistors?
P.S. one other questions, how do I remove the rear dampers, the top
connections seems like a brass ball joint - does the dampers just "snap"
on - do I just force it off?
William
Old Dec 21, 2002, 07:52 PM
Dirtnap
Dirtnap
Guest
n/a Posts
Re: Newbie question about soldering resistors to motors?
I tried to put it into works, but works fail me.
I posted two pix at: alt.binaries.radio-control
Hope this helps.
"Wm_cheng" <No_spam@sympatico.ca> wrote in message
news:hA6N9.10951$pS6.1734071@news20.bellglobal.com ...
> HI all,
go
still
through
> the resistors?
> Thanks,
> William
Dirtnap
Dirtnap
Guest
n/a Posts
Words.
I meant words.
"Dirtnap" <dirtnap2001@hotmail.com> wrote in message
news:xJ8N9.2502$eB.51430@twister.kc.rr.com...
> Hope this helps.
> > HI all,
motors.
they
> go
> still
> through
> > the resistors?
> > Thanks,
> > William
Old Dec 22, 2002, 07:32 AM
sanj.varah
sanj.varah
Guest
n/a Posts
You don't solder resisotrs to the motors, they are capacitors. 50uF
unpolarised ones to be precise.
solder one between the +ve motor terminal and the casing of the motor, one
between the -ve motor terminal and the casing and one between the +ve
and -ve motor terminals. then solder the wires from the speedo to the
terminals on your motor.
have a nice day
sanj
www.schumacher.clara.net
> HI all,
go
still
through
> the resistors?
> Thanks,
> William
Old Dec 22, 2002, 01:52 PM
Wm_cheng
Wm_cheng
Guest
n/a Posts
The diagram only shows 2 capacitors - one on each of the terminal - however
my LRP Runner Plus w/ reverse did come with 3 capacitors in the baggie.
Which is correct?
William
"sanj.varah" <sanj.varah@rolls-royce.com> wrote in message
news:uYiN9.376$385.75956@newsfep1-win.server.ntli.net...
> have a nice day
> sanj
> > HI all,
motors.
they
> go
> still
> through
> > the resistors?
> > Thanks,
> > William
Old Dec 22, 2002, 03:52 PM
Dirtnap
Dirtnap
Guest
n/a Posts
Use three.
One from positive to negative,
One from positive to the can,
One from negative to the can.
news:PuoN9.246$o51.122602@news20.bellglobal.com...
> Thanks,
however
> Which is correct?
> Thanks,
> William
one
> > have a nice day
> > sanj
> > > HI all,
> motors.
the
> they
> > go
> > still
> > through
> > > the resistors?
"snap"
> > > Thanks,
> > > William
Newbie question about "floaters" & their motors konaboy Electric Sailplanes 12 Aug 30, 2005 12:41 PM
Newbie Question about chargers kash Batteries and Chargers 0 Nov 27, 2002 02:24 PM
A newbie question about stall Orion1 Beginner Training Area (Aircraft-Electric) 6 Oct 29, 2002 10:07 AM
Newbie question about channels kash Beginner Training Area (Aircraft-Electric) 10 Oct 07, 2002 04:39 PM
Question: about astroflight 020 motors aeox Electric Plane Talk 2 Jan 03, 2002 07:30 PM
