Hi friends!
Hereīs my progress until now. Already carved the servos place, the motor mount is 2mm plywood epoxyed with 5min. I decided to paint the wing with foam safe spray can. I applyed thin layers of paint and them didnīt added significant weight (less then 10 gr I think. Winglets and elevons are all black. As here in Brazil is raining a lot, itīs so cold, to dry the filler and the painting, I used my wifeīs dryer The weight until now is 114gr, and wonīt be so much more higher; now I only need to put the tape in the LE to reinforce, the speed control (6gr) and no more issues, I think. Still have to carve the battery place, do you think velcro is a nice choice to hold it? I have to make sure to carve in the correct place to find exactly the CG point. Iīll go back to work friends, news after lunch
Nick |
Hi Nick,
Finally I finished my sonīs wing. I had some problems to find the CG, once I think I put the hextronik 9gr servos, 10cm from the LE, instead of 9cm. I had to cut the battery place on the top and put the berg near it but appears to be ok. As this is my first wing, let me ask you: does the motor needs any incidence? My Hitec is already with the setup to fly the wing. The final weight is 134gr. What do you think? I have to thank you a lot by all the help and sharing the plans! Iīll try to fly as soon as possible to see itīs perfomance! Best regards, Luis Claudio |
Looks really sweet Luis! I'm pretty sure mine was set so the motor thrustline was parallel to the centre line of the wing. If it pitches up too much under power put a packer under the top screw of you motor mount. I've flown mine with a 2s900 battery which took the weight up around there and it flew fine.
Good luck with the maiden! Nick |
Thank you again Nick!
News later! Quote:
well my day started off slow than my replacement battery turned up in the mail yipee so i headed off to the LHS for some parts to get this little wing going i get home assembled everything and fired her up wooohoooooo the sound of an EDF lovely!!!! i took it out to a park got her ready for the maiden i gave her full throttle and a slight toss she nosed in not to worry i told my self
couple of up clicks on the trim another toss and she was away!!!! zipping and zooming around doing fast rolls etc... after about 3-4mins i brought her in not knowing when the battery was last charged than i packed up started to walk away and thought what the heck ill go for another try stupid move! it flew about 30meters away got caught in abit of wash from the hill behind me and put the little wing into a spiral SLAMMMMMMM! strait into the long'ish grass i walked over picked her up my home made keel snapped in the thinnest section that was around the fan unit also the impellor snapped and the whole motor and mount ripped right out of the fan its an easy fix abit of 5mins glue the keel will be stronger than before and a new EDF is only $11 this little wing with the small EDF done around 40mph with a head wind of around 10mph also the all up weight including a 3cell 400mah hyperion battery was 187.7grams mini speed wing at 24" and 2cell lipo weighs in at something like 224grams my little wing has a 26.4" wing span alot more wing area alot more thicker foil at the tips plus a 3cell lipo and EDF and still come in well under the weight????
Honolulu, Hawaii
Joined Apr 2007
Cut out a kf version last night for my unused 10 gram motor. I'm gonna run a GWS 7035 and 2s 500 mah battery. It's 3mm cellfoam. Little more root and tip than the plans. Maybe it'll slow down even more? Chopstick in the middle to support things. Not sure it'll fly but we'll find out this weekend i guess. Wheres everybodies cog? 1/4 distance from leading edge?
| Thread Tools | |
| My new DS wing | Chuckhead1 | Dynamic Soaring | 10 | Jan 29, 2005 11:04 PM |
| my new flying wing | ilaurencet01 | Flying Wings | 1 | Nov 25, 2004 12:02 PM |
| My new AP wing. Flies but needs trimming. | Newberry | Aerial Photography | 8 | Oct 30, 2004 01:36 PM |
| Question Questions on building my new flying wing and on the J250... | Picoflyer | Flying Wings | 3 | Jun 14, 2004 12:58 PM |
| got my new rocket wing | Jim Brown | Foamies (Kits) | 2 | Jul 27, 2001 11:54 PM |
