Old Jan 17, 2008, 09:45 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
what air foil do u use from profili?
gazza2003au is offline Find More Posts by gazza2003au
Old Jan 17, 2008, 09:54 PM
Skycruiser is offline
Find More Posts by Skycruiser
I eat only vegetarian beef
Skycruiser's Avatar
Fairlie, New Zealand
Joined Nov 2006
I used PW75 but I've used SD3021 before with a lot of success, and it has a noticeably lower stall speed.
Skycruiser is offline Find More Posts by Skycruiser
Old Feb 08, 2008, 03:15 PM
bdo0000 is offline
Find More Posts by bdo0000
slope aerobatic addict
bdo0000's Avatar
la rochelle france
Joined Feb 2005
Hi all,
I ve seen skycruiser ' s wing this week and as I have the same motor and don t know which toy to do with it, I decided to make this wing
I just checked the DXF , and convert all the data into GMFC, my CNC cutting software and few hours after, I was on the field with my new toy
this wing is really nice. I ve had a lot of fun with it . First I used a 7*4 prop , and it was very easy to fly in very small space at low speed and perform aerobatic, CG given was perfect .
After the first 2S 300mah accu pack I changed the prop for a 4*4, I now discovered a totaly differant wing who seems to like speed.
Tomorow, I m going to show my new toy in my club , sure It s going to have great success.
I join GMFC Pro CNC files for those who want to make their own by CNC cutter.
Regards and thanks for sharing skycruiser
Dorian
bdo0000 is offline Find More Posts by bdo0000
Old Feb 08, 2008, 09:37 PM
Skycruiser's Avatar
Joined Nov 2006
Glad you like it Dorian. I like your idea of heatshrink for control linkages. Might have to try that one.
Old Feb 18, 2008, 02:39 PM
bdo0000 is offline
bdo0000's Avatar
la rochelle france
Joined Feb 2005
heatshrings work great for litlle weight planes.
I ve broken a wire in my motor, and had to wire it again, I choose 15T and with a 5*5 apc prop my wing has become a racer !!
Old Mar 06, 2008, 04:56 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
I will start building my Nick´s wing soon....
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Mar 06, 2008, 06:59 PM
Skycruiser's Avatar
Joined Nov 2006
Slightly bigger version, uses HXT500 servos, HC16g motor, 2s900 pack. Same wing loading as the little one. Cruises around at 5 watts! We're getting 45 minute flights of cruising plus aeros now, or 30 minutes of combat.
Wing is now covered to make it a bit more durable. You can sit it on it's fins and do vertical takeoffs with it
Took this to a fly in last weekend, came away with five requests for them!
Old Mar 06, 2008, 07:42 PM
Sydney, Australia
Joined Jul 2003
at 100grams i would buy one if u sold them mate
Old Mar 06, 2008, 08:16 PM
Skycruiser's Avatar
Joined Nov 2006
Well, the larger covered version comes out at 170g with 2s900 pack. It could be cut down for the 10g motor if required, leave the covering off and lighter battery makes it 100g. I'm doing them for NZD40 plus postage here if you're interested.
Cheers
Nick
Old Mar 10, 2008, 12:02 AM
vinsing is offline
Find More Posts by vinsing
Joined Oct 2006
Fin Size
Hi SkyCruiser
Whats your fin size?
I saw on the other thread the video, it was great.
vinsing is offline Find More Posts by vinsing
Old Mar 10, 2008, 12:49 AM
vinsing is offline
Joined Oct 2006
How do you choose the motor+ propeller combination for a flying wing.
With the batteries my weight will come around 170 grams. I have hacker A15 S motor which they claim to be used for 3D flying up to 170 grams with 7*3.5 prop.
Old Mar 10, 2008, 05:54 AM
Skycruiser's Avatar
Joined Nov 2006
Originally Posted by vinsing
Hi SkyCruiser
Thanks mate. Just 3mm depron triangles about 80mm high and from leading edge to back corner of elevon. Remember to have about 1/3 below the wing.
Old Mar 10, 2008, 06:02 AM
Skycruiser's Avatar
Joined Nov 2006
Depends on the type of flying you want the wing to be doing. Usually people use high kv motors with little props to get the pitch speed up on faster wings. This is a slofly wing so a low kv motor is fine. Looks to me like your motor is 2350 rpm/V so on this wing something like a 5x4 would be good.
Old Mar 10, 2008, 06:18 AM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Great design Skycruiser! Small wings are just the most fun aren't they?
I would like to offer a link for those people that aren't able to replicate your design. This particular wing is the same size as yours, designed by Freeair.cz and is made of EPP.
http://robotbirds.com/catalog/produc...oducts_id=1112
Mine has a 45 Watt motor turning a Graupner 5"x5" carbon prop on a 2s LiPo and it goes vertical for ever! AUW=exactly 4ozs.
Ben D Wing is offline Find More Posts by Ben D Wing
Old May 02, 2008, 07:50 PM
Joined Apr 2005
Hello Nick!
As I still want to build your wing, let me ask you please: I have a Hitec Laser 4 (it has servo reversing). I will need to put a mixer in the wing? I still have to cut the wings...
Thanks again Nick
My new DS wing Chuckhead1 Dynamic Soaring 10 Jan 29, 2005 11:04 PM
my new flying wing ilaurencet01 Flying Wings 1 Nov 25, 2004 12:02 PM
My new AP wing. Flies but needs trimming. Newberry Aerial Photography 8 Oct 30, 2004 01:36 PM
Question Questions on building my new flying wing and on the J250... Picoflyer Flying Wings 3 Jun 14, 2004 12:58 PM
got my new rocket wing Jim Brown Foamies (Kits) 2 Jul 27, 2001 11:54 PM
