Old Jan 05, 2008, 02:40 PM
Skycruiser is offline
Find More Posts by Skycruiser
I eat only vegetarian beef
Skycruiser's Avatar
Fairlie, New Zealand
Joined Nov 2006
My new 100g wing
Hi all
Made this one to take on holiday with me. One evening for the airframe, one evening to fit the bits. Cheap and cheerful but a lot of fun to fly. Video was the second flight, I wring it out a lot more now. I'll post plans and pics when I get home in a weeks time if anyone's interested.
http://www.rcgroups.com/forums/showthread.php?t=796465
Skycruiser is offline Find More Posts by Skycruiser
Old Jan 05, 2008, 03:35 PM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
Very nice. Looks like fun.
Please do share when you get back from vacation.
Great for taking along on camping trips too!
reefboy is offline Find More Posts by reefboy
Old Jan 05, 2008, 06:45 PM
woolebugr is offline
Find More Posts by woolebugr
Fighter of Gravity
woolebugr's Avatar
Joined Aug 2007
That is exactly what I have been looking for. Something small, light, agile, and aerobatic! Great job man. I would love to see plans for this wing.
woolebugr is offline Find More Posts by woolebugr
Old Jan 17, 2008, 12:45 PM
Skycruiser's Avatar
Joined Nov 2006
OK, here's a very basic plan and some construction photos. I've thrown in some foam cutting pics of a Red Herring type wing, pusher style wing is just the same but with more sweep.
Old Jan 17, 2008, 12:50 PM
Skycruiser's Avatar
Joined Nov 2006
Here's the plan and template in zipped DXF form. Sorry I don't have a PDF converter.
Old Jan 17, 2008, 02:34 PM
Kokopeli is offline
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
Originally Posted by Skycruiser
OK, here's a very basic plan and some construction photos. I've thrown in some foam cutting pics of a Red Herring type wing, pusher style wing is just the ssame but with nore sweep.
Please tell me what you are using for cutting wire.
I have been toying with a similar idea and have two ways to provide power.
One is a soldering iron with the tip removed - 100w - the type that uses a resistive tip that is connected to the transformer with two compression nuts. The other that I might use is a variac transformer - it is called, I think, an autotransformer - lots of volts with low current - DIRECT FROM THE MAINS ( I think that is what you call it - we call it the wall outlet).
So now I have been looking around for some common material to use for the resistive cutting wire. Haven't yet found the right wire.
Walt
Kokopeli is offline Find More Posts by Kokopeli
Old Jan 17, 2008, 03:35 PM
wingnutt is offline
Find More Posts by wingnutt
Will work for foam
wingnutt's Avatar
United States, WI, Muskego
Joined Apr 2005
wjbite - you can use stainless steel fishing leader wire, .020 aircraft safety wire or rene wire. any of these in the .018" to .022" diameter will work great.
wingnutt is offline Find More Posts by wingnutt
Old Jan 17, 2008, 03:36 PM
Skycruiser's Avatar
Joined Nov 2006
I use control line wire. I know some use guitar string. Nichrome wire will require less power to heat, but it's weaker so it can break if you use hand tension like this. You can get that from an old heater or hair drier.
For power supply I use a 24V transformer. Quick'n'nasty, use a 12V car battery in series with a 12V charger. I stated out that way, actually had a switch wired in, flipped one way I got 24V at the wire, flipped the other way the charger topped up the battery while on standby.
I'd suggest you only use the variac if it's feeding a stepdown transformer. Feeding full voltage into your cutting wire is potentially lethal.
And to anyone else reading this: ONLY WORK WITH MAINS VOLTAGE IF YOU'RE 100% SURE YOU KNOW WHAT YOU'RE DOING! That's why the charger+battery is a good idea.
Some links
http://www.rcgroups.com/forums/showthread.php?t=628704
http://www.rcgroups.com/forums/showthread.php?t=675339
Good luck
Nick
Old Jan 17, 2008, 03:39 PM
Skycruiser's Avatar
Joined Nov 2006
Hey wingnutt, what's rene wire?
Old Jan 17, 2008, 03:57 PM
Skycruiser's Avatar
Joined Nov 2006
Forgot to mention, fins are held on with foam double sided tape. One got knocked off in one of it's many midairs, and the plane flew no differently. So they're probably a bit large for normal flight, but I like them this way, they stop the plane sideslipping into the ground on low slow very tight turns. I also flew it with no fins at all, and it had a good bit of adverse yaw and wasn't comfortable to fly at all.
Nick
Old Jan 17, 2008, 05:37 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
i dont have the program to open your file its a shame maybe someone else with the PDF program will convert it for you?
i got my hotwire cutters working i used 25lb fishing wire trace worked a treat
gazza2003au is offline Find More Posts by gazza2003au
Old Jan 17, 2008, 08:27 PM
Skycruiser's Avatar
Joined Nov 2006
OK, I've converted to PDF using CutePDF.
Dimensions in cm BTW
Nick
Old Jan 17, 2008, 08:40 PM
Sydney, Australia
Joined Jul 2003
awesome mate but the second PDF only shows one airfoil looks like its your wing tip airfoil being 10cm?
Old Jan 17, 2008, 09:07 PM
Skycruiser's Avatar
Joined Nov 2006
Should be 220mm. Is your printer set to landscape and page scaling turned off? Alternatively you might have to print your own using Profili
Tethered cutting only uses one template, at the root
Cheers
Nick
My new DS wing Chuckhead1 Dynamic Soaring 10 Jan 29, 2005 11:04 PM
my new flying wing ilaurencet01 Flying Wings 1 Nov 25, 2004 12:02 PM
My new AP wing. Flies but needs trimming. Newberry Aerial Photography 8 Oct 30, 2004 01:36 PM
Question Questions on building my new flying wing and on the J250... Picoflyer Flying Wings 3 Jun 14, 2004 12:58 PM
got my new rocket wing Jim Brown Foamies (Kits) 2 Jul 27, 2001 11:54 PM
