Old Jan 04, 2008, 04:16 PM
Lamborghini12345 is offline
Find More Posts by Lamborghini12345
Slope Drifting?
Lamborghini12345's Avatar
New Zealand
Joined May 2007
Help!
KF Aerofoil for Glider
Hi,
I am making a glider out of elmers foam board style stuff and would like to know what aerofoil I should use some use 40% top or 50% top and then someone came along and said 50% bottom????? I am confused please help!
Lamborghini12345 is offline Find More Posts by Lamborghini12345
Old Jan 04, 2008, 05:03 PM
wingnutt is offline
Find More Posts by wingnutt
Will work for foam
wingnutt's Avatar
United States, WI, Muskego
Joined Apr 2005
For a glider, go with 50% top.
wingnutt is offline Find More Posts by wingnutt
Old Jan 04, 2008, 05:17 PM
Slope Drifting?
New Zealand
Joined May 2007
How well does it work? what sort of weight will it glide at and i forgot to metion its for a DLG
Old Jan 04, 2008, 06:26 PM
JMPaccassi is offline
Find More Posts by JMPaccassi
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Lambo,
I used elmers foam board to build a DLG w/ KFM & it seems to work great. I made mine a top step at 50%.
40" WS 6.25oz AUW
I posted a vid in the sailplanes vid gallery 2 days ago if you'd like to see it in action. If you need anymore info let me know
JP
JMPaccassi is offline Find More Posts by JMPaccassi
Old Jan 04, 2008, 07:12 PM
Slope Drifting?
New Zealand
Joined May 2007
Hi,
I saw your glider in the other kfm glider forum and it looked like it flew great! I think I will go with 50% topstep
Also how long is it?
Old Jan 04, 2008, 07:58 PM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Length is 31.75 in. Good luck with the build, DLG's are a blast!
Old Jan 04, 2008, 08:05 PM
Slope Drifting?
New Zealand
Joined May 2007
also how wide is your wing? not wingspan
edit:maybe lenght?
Old Jan 04, 2008, 08:44 PM
Slope Drifting?
New Zealand
Joined May 2007
long is your wing?
Old Jan 05, 2008, 12:25 AM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Welcome to the world of hand launch guys! It can become addictive!!
Go to this link http://www.charlesriverrc.org/ then go to articles and tips index,then to the online plans section, then to the Apogee. Read the articles about the Apogee.
In the Hand Launch Forum look for stuff by Doug Montogmery , He did a lot of work on the KFM wings for hand launches last year. He may have been the first to use the KFM / Depron wing, so he deserves a lot of credit for his work !
How much should these little things weigh ? Dr Mark Drela says 3.1 ounces or less per Square foot of wing area. If you don't know who Mark Drela is , he probaly knows more about gliders than anyone in the world ! If he says something belive it !!! Most of the newer compition gliders of any kind are off shoots of his designs.
Blue Skies ...... R Dub
RWCLOUD is offline Find More Posts by RWCLOUD
Old Jan 05, 2008, 01:54 AM
Slope Drifting?
New Zealand
Joined May 2007
can I just say yours wa the inspiration!!! I looked at yours for weeks! and now I will make one! I think it may end up around 6-7ounces and with a 40" wingspan with 7"long wing so 3.5" will be the KF does this sound ok?I will try and make it as light as possible.
Old Jan 05, 2008, 02:03 AM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
heres a good base to work off of
Hope this helps, 7" is almost too big of a root, try 6.5 and 4" at the tip.
Doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Jan 05, 2008, 10:53 AM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
I made my wing 6" wide, I started off by cutting 2 seperate panels 20" x 6" & then just rounded out the tip by eye, then cut my steps 20" x 3" & laid them over the other panels, traced the curve at the tip with charcoal pencil & cut. For the basic measurements I used sailplanecalc(sp?), should be able to find it here doing a search. My tail ended up being a little long which is why I'm using such a heavy battery (1.9oz), with a slightly shorter tail moment, I would've probably been able to shave another 1/2 oz off of my AUW.
JP
Old Jan 05, 2008, 11:02 AM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Double post deleted, darn browser back buttons!
Old Jan 05, 2008, 11:11 AM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
JP : I don't think the tail can be to long , the longer the tail , the higher the launches. It looks like your're using an arrow shaft for the boom , right? Next time scrape /sand the last half to a taper. There is a lot of epoxy used in making arrow shafts so getting rid of it will make the whole glider lighter.
Sand the foam tail parts more also. And use .012 to .015 wire for push rods. Every gram that you save at the tail will save 4 to 5 grams at the nose. 2 1/2 grams saved at the tail will make the total weight 1/2 ounce lighter !
Blue Skies .....R Dub
Old Jan 05, 2008, 01:04 PM
JMPaccassi's Avatar
Fresno, CA
Joined Jan 2007
Boom
RW,
I think the boom may be my problem, I am using a carbon tube that I bought at hobbyTown, it's .210" O.D. x .132" I.D. x 27.5" never weighed it but is kinda thick walled, maybe a little heavy compared to other options??
Also, I originally had used wire pushrods(don't remember what size), but the AUW was at 7.3 oz to balance near CG & had to use carbon rods to get down to 6.25.
Here are some closer pics of my boom & tail, I have 2 guide tubes out on the boom secured by heat shink tubing, H-stab is secured to boom by (2) 3/16 x 3/16 wood squares stacked 2 high which are held down with fishing line & epoxy.
JP
ECO 8 - For sale or trade for glider Lewis Adam Aircraft - Electric - Airplanes (FS/W) 1 Jan 02, 2003 09:18 PM
Geared 600 for glider Robbie d Power Systems 0 Nov 16, 2002 07:56 PM
Battery Question for glider Keitha Radios 2 Jul 26, 2002 06:22 PM
Aerofoil for Trainer? Hangar Rat Power Systems 3 Jun 10, 2002 11:03 AM
Aerofoil for 140cm wingspan 1.2kg twin 400 apolo1 Power Systems 13 May 24, 2001 09:31 AM
