Old Jan 04, 2008, 03:02 AM
Antonsoarer is offline
Find More Posts by Antonsoarer
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
TWF: Pitcheron differential and LE shape?
TWF: Pitcheron differential? Do I need any diff on Aileron or Pitch movement?
Foil: Not Symmetrical and has low pitching moment.
LE shape should it be: Sharp? Blunt? or just Accurate?
Thanks to all TWF experts...
Antonsoarer is offline Find More Posts by Antonsoarer
Old Jan 04, 2008, 10:10 AM
ShredAir is offline
Find More Posts by ShredAir
slope'n somewhere in the Andes
ShredAir's Avatar
Peru, Puno
Joined Mar 2001
Ail diff probably will help.
Pitch diff probably will not be needed if plane is dialed in properly.
LE shape: accurate is best; err on side of bluntness.
Dieter Mahlein, ShredAir
ShredAir is offline Find More Posts by ShredAir
Old Jan 04, 2008, 10:41 AM
winchdoc is offline
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
LE shape:
What cuzzin Dieter said, you won't want any sharp LE stall when that wing panel is cranked 30 degrees past stall angle. Differential is a subtile thing, but let me add that you will have less differential than you would on an aileron ship. The less camber/pitching moment your airfoil has, the less diff you will need. I don't run any diff on any of my TWF, except maybe my Xica when I ran the Xingu 100 wings on it a while back.
WinchDoc
winchdoc is offline Find More Posts by winchdoc
Old Jan 04, 2008, 12:00 PM
Long to be flyin'
Wirral, (UK)
Joined Dec 2003
Thanks Dieter & Winchdoc for the feedback, no surprises there.
Tony.
Old Jan 25, 2008, 07:25 AM
Mtntop is offline
Find More Posts by Mtntop
Family, wind, snow & fun
Mtntop's Avatar
Osburn Idaho
Joined May 2006
Don't consider myself an expert on the matter but I know my experience falls right in line with winchdoc and dieter. Mtntop
Mtntop is offline Find More Posts by Mtntop
Discussion Tips for sanding a square LE to shape arukum17 The Builders Workshop 10 Mar 12, 2007 02:47 AM
