Looks great. Glad you like it!
Pat |
Latest blog entry: Nico Hobbies
OK Al, I got my lights for my F-22 Night Fighter! I'm going to give you and James a run for your money.
![]() Pat |
I just hope that when I'm done the added weight won't cause any issues.
Pat |
Been having a blast with this thing. Here's a little video my buddy put together. This was on a 2S. Had my first crash today due to a servo failure.
Sorry to hear about your crash. What servos are you using?
Pat |
Finally got my night flyer done!
Pat |
Looks good Al! Looking forward to doing some night flying this year at the Jolt.
And BTW, I'll have 3 rx-ready planes for sale there too for $125 each. ![]() Pat |
Well, what I use are the HXT500s. They seem to be a little tougher than DS75's or HS-55's. I once crashed an F-22 three separate times before finally stripping a servo on a particularly hard pancake landing.
And thanks on the lights comment. I've already got people asking me to build them one with lights. ![]() Pat |
Here are the lights I used:
http://hobbyking.com/hobbyking/store...idProduct=8944 You can get them in 5 different colors; White, Red, Green, Blue and Yellow. The only color I didn't use on the plane was yellow. Those are 1 meter strands, and each group of 3 lights has a built-in resistor on the strip, and they can handle direct connections to 12v. What I did was lay out my lights in sections using a multiple of 3, so I had sections of 3 lights, 6 lights, 9 lights, etc. Between each section of 3 lights is a copper contact strip. You can cut the lights right on the divider and then solder them back together using 22ga wire. There is a + and - printed right on the strip so that you always know what the correct polarity is. And as far as I know, you can daisy chain as many lights together as you want. To power the lights, I just connect them right to the balance tap, and they are always on. I did it this way to save weight. However, you can buy controllers as well to use as an on/off switch. Here's what HK offers: http://hobbyking.com/hobbyking/store...f_Switch_.html http://hobbyking.com/hobbyking/store...d_Switch_.html So for mine I just purchased a female Hyperion balance tap connector (since I use Hyperion lipos) and do a direct connect for always on lights. For other battery brands, all you need to do is get the proper female tap connector for your particular brand of battery. as for weight, my normal plane with paint and decals and a Hyperion 3S 850 comes in at 6.8 ounces. The unpainted night flyer comes in at 7.8 ounces, so the whole system only added one ounce of weight. With 10 ounces of thrust, she should still fly very well. Plenty well enough for night flying. ![]() It was a little tedious cutting and measuring and soldering up all the light strips, but I think the end result was well worth the effort! And let me say, this is the first time I've worked with these lights, and it really is a simple process. For the past few years I'd been too intimidated by al lthe neat lighting setups I've seen on other planes, but this was so simple to do I wish I had done it much sooner. Pat |
| Thread Tools | |
| Sold 3mm White Depron 18 sheets | TreeFlyer | Aircraft - General - Miscellaneous (FS/W) | 1 | Sep 06, 2007 09:57 PM |
| Built up 3mm depron aerobatic/3D??? | bcripe1 | Foamies (Kits) | 4 | Sep 03, 2003 08:00 PM |
| 3mm depron CAP | MGoddard | Foamies (Kits) | 3 | Sep 01, 2003 07:36 PM |
| Slice BlueCore into 3mm Depron | localbuyer | Foamies (Kits) | 1 | Jul 08, 2003 10:28 PM |
| For Sale Fs 3mm Depron Sheets | CMT1961 | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jan 28, 2003 12:01 PM |
