Old Dec 15, 2008, 01:53 PM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
sorry
adbradley is offline Find More Posts by adbradley
Old Dec 15, 2008, 02:01 PM
helipilot is offline
Find More Posts by helipilot
Clear for Take-Off!!!
Dexter, Michigan USA
Joined Nov 2003
Hey, not a problem. I was gearing up to do some cutting before you had mentioned the kit. It's all good!
helipilot is offline Find More Posts by helipilot
Old Dec 15, 2008, 02:23 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Adam,
Quick question. For the fuse section, is that 3mm doubled up to make 6mm? When I printed the plans it looks like the holes are 6mm wide.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Dec 15, 2008, 02:51 PM
adbradley's Avatar
Joined Mar 2007
thats corrrect pat, a piece of 6mm could be used as well. this is the version 2 design that has this, on the version 1, i only did 1 3mm thick layer, and it is strong enough, the 6mm isnt needed.
Old Dec 15, 2008, 02:58 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
OK, thanks. I had thought the later version changed from 3mm to 6mm. I have lots of 6mm scrap lying around, so I'll use that, and use 3mm for the rest of the plane. Hope to have this done and flying by AEF so it can play with it's big brother.
Pat
Old Dec 15, 2008, 03:21 PM
adbradley's Avatar
Joined Mar 2007
yeah, i will prolly have one goin then too, what motor are you using?
Old Dec 15, 2008, 04:04 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Same one you got from HC originally. Or do you have something better in mind?
Pat
Old Dec 15, 2008, 04:21 PM
adbradley's Avatar
Joined Mar 2007
nope, thats the perfect motor
Old Dec 17, 2008, 12:03 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Originally Posted by corsair nut
youll love it. just take a little extra time and round all the edges, and taper the trailing edges, and also i think the drooped leading edge helps alot. it really flies smooth for a profile, i was really shocked.
Nice leading edges, I think the droop really helps with control on some foam jets. This is a Tomhe Mig-29 I drooped!
capt is offline Find More Posts by capt
Old Dec 18, 2008, 09:10 PM
adbradley's Avatar
Joined Mar 2007
ok guys, my jtech laser came through for me!! i have a stock of these planes now, like i said they are 15$ each and about $8 shipping unless you are on the west coast then its $5 for shipping. Just PM me if you want one.
Adam
Old Dec 22, 2008, 08:54 PM
Joined Nov 2003
Quick question,
What is the angle in degree's the vertical fins should be? Am I getting too technical to ask the question?
Old Dec 22, 2008, 09:37 PM
adbradley's Avatar
Joined Mar 2007
heheh yeah, any angle will work, what i normaly do is install them last, and use the fuse sides as a guage, i just put the fins at the same angle as the sides.. A cardboard guide can be made at that angle to help while gluing them in place. But they will work at pretty much any angle, just as long as both are the same.
Adam
Old Dec 23, 2008, 10:31 AM
rdc767 is offline
Find More Posts by rdc767
Joined Dec 2003
What prop and battery? for indoor?
Hello
Just order some of Adbradley's kits. I'm going to try to fly this indoors in January. Most guys have those Parkzone Cessna’s.
The indoor facility is an oversized basketball court with 30 feet of bleachers on each side.
Watching the video of the f22 in the hanger I see it can be done. What prop and battery should I use?
I am going to buy the
http://www.hobbycity.com/hobbycity/s...idproduct=5432
AX 1806N 2500kv Brushless Micro Motor (19g)
Is there a better motor for indoors?
I think you all were using the 5x3 cut down to 4x3. Anybody have Hobbycity link? to the prop.
Ron
rdc767 is offline Find More Posts by rdc767
Old Dec 23, 2008, 11:11 AM
adbradley's Avatar
Joined Mar 2007
Here is the prop
http://www.hobbycity.com/hobbycity/s...idProduct=4252
you can just use the 5x3 prop if flying indoors, if you are outside and want more speed, id trim it.
here are some batteries
http://www.hobbycity.com/hobbycity/s...0mAh_3S1P_20C#
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
either one should work great
Here is the esc i use
http://www.hobbycity.com/hobbycity/s...ed_Controller#
If you want to have more fun, slow it down, cruse up behind one of the cessnas, then knock it out of the air at my field some of my friends were flying slow sticks, and i was toolin around with them to see how close i could get, and twice i bumpped the nose of my f22 on the tail of there slow stick, the f22 just bounced off and kept going, the slow stick didnt move at all, it was fun.
Old Dec 23, 2008, 11:37 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
BAtt/motor/ESC combo
Guys the motor selected is perfect for this plane. I use a 2 cell 500mah pack with a super simple 10 amp ESC, 5 gram HC HXT servos and a BERG RX. I find this combo just right. Ad how does it perform with the 3 cell pack? It's definately heavier than the 2 cell but I'm curious about the flight characteristics with the heavier battery. I'm guessing the extra cell would give me more speed (which isn't a bad thing). Marty
martys is offline Find More Posts by martys
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
