Old Jan 05, 2011, 08:42 PM
AirmanAirhead is offline
Find More Posts by AirmanAirhead
AirmanAirhead's Avatar
Novato, CA
Joined Dec 2008
Originally Posted by crxmanpat View Post
I'd say 4540's. I think the trade off of 1/5" diameter for 1" of pitch won't make much difference. But adding 1" of pitch will.
I will pick up some 4540's soon and run some numbers.
Pat
Sounds like you guys have experimented with the props. I tried a 4540 and though the plane flies decent, it does not have the power I thought it might. My local HS did not have any APC's so I orderd some off the net. They came in and are very flexible, (not APC's ) and now I'm wondering if they are too flexible. So I tried a 5.1x4.5 APC, and what a difference. It really kicks with that prop. I need to check my AMP draw and I have not flown it a lot with this prop. And then something interesting happened I nicked the tip of the prop and cut it down to close to 4.5x4.5 this seems to be pretty sweet. The APC's are much more stiff.
What do you guys think? Am I pushing things here too much on that cool little motor Pat sells?
AirmanAirhead is offline Find More Posts by AirmanAirhead
Old Jan 05, 2011, 10:02 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
The key is amp draw. So long as you're not drawing more than 8-10 amps constant, you should be OK. So be sure to check your amps. Anything over 10 could damage the motor.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 05, 2011, 10:37 PM
Novato, CA
Joined Dec 2008
Thanks Pat, I'll check that out.
Old Jan 08, 2011, 10:01 AM
karlpenney is offline
Find More Posts by karlpenney
Halifax, NS
Joined Sep 2009
Spar size
What size of CF spar is used in the wing for the kits? Is it 3mm x 1mm flat carbon?
karlpenney is offline Find More Posts by karlpenney
Old Jan 08, 2011, 11:15 AM
Novato, CA
Joined Dec 2008
Pat
With the prop I have now, I get below 10 amps unless I got full throttle. then it jumps to 12! So I've been careful, I also think I have a very slightly bent shaft.
Old Jan 08, 2011, 01:39 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yes, 3mm x 1mm flat stick CF.
Pat
Old Jan 08, 2011, 01:40 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
If it is bent, send it back to me and I will replace it.
Pat
Old Jan 08, 2011, 02:19 PM
Novato, CA
Joined Dec 2008
Pat
Pat I appreciate that, but really, I have no idea if I did this or not, I did break prop in a landing on weeds, not hard ground, but since it broke the prop, I think it could have bent it so it's not really on you.
It looks like it is pressed in, and has one c-clip on the rear. Is that right?
Old Jan 08, 2011, 03:04 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yes, that's correct. Also, check the bell. There is a nut on the top of it that has two flat sides. This screws down and holds the bell in place. Make sure it is tight.
Pat
Old Jan 09, 2011, 02:58 AM
hanafeearis is offline
Find More Posts by hanafeearis
Malaysia, Selangor, Seri Kembangan
Joined Mar 2010
haiii all....
i need help from you guys.... there is a good motor to scream this little bird from www.himodel.com? i plan to use 3cell bat 610mah that laying beging to used.... any recommnded from this site that i can used
rgrds..
napie
hanafeearis is offline Find More Posts by hanafeearis
Old Jan 09, 2011, 06:38 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Originally Posted by hanafeearis View Post
haiii all....
rgrds..
napie
Napie just use the recommended motor. The plane screams with it! I've been flying mine for 2 years with the 1806/2500 motor. PM Pat. I'll bet he has plenty! Marty
martys is offline Find More Posts by martys
Old Jan 09, 2011, 09:55 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Napie,
We have messed around with a bunch of motors, and really the AX1806N 2500kv is the best we've ever used. I am actually out right now waiting on more from China, but you can order them direct from Hobby King as well.
http://hobbyking.com/hobbyking/store...idProduct=5432
Pat
Old Jan 09, 2011, 11:06 AM
Joined Mar 2010
thank you pat & martys.
i already place order form HC, hope its will show in front my door before friday couse on saturday we'll plan to fly indoor and hope this bird will impress my friends.... i already built 100% bird and i love way its fly .....
rgrds
napie
Old Jan 12, 2011, 10:48 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Here's some video a friend of mine took for me last June. Yeah yeah, I know, I'm a little slow! (PS - This was about 4 planes ago! )
Nico Hobbies Profile Mini-22 (4 min 56 sec)
Pat
Old Jan 12, 2011, 11:23 PM
Novato, CA
Joined Dec 2008
Pat what do you guys end up with weight wise. Without battery, and then also with the battery.
Jeff
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
