Old Jan 01, 2011, 11:48 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
This post has pics of my friend flying today after breaking off the nose. Check out the last pic of the inverted landing!
http://www.rcgroups.com/forums/showp...postcount=1141
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 02, 2011, 02:52 AM
AirmanAirhead is offline
Find More Posts by AirmanAirhead
AirmanAirhead's Avatar
Novato, CA
Joined Dec 2008
Yes, very strange site seeing it fly without the nose! The inverted landing is also a trip, no broken vertical stabs it seems.
Makes me wonder about building a "Funky 22" with the vertical stabs mounted on the under belly with small wheels then you could ROG now that would be strange indeed!!
AirmanAirhead is offline Find More Posts by AirmanAirhead
Old Jan 02, 2011, 02:56 AM
Novato, CA
Joined Dec 2008
At the risk of going just a wee bit off topic here, check out my "Water Raptor"
F-22 Water Raptor.mp4 (3 min 34 sec)
Old Jan 02, 2011, 09:48 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yeah, I remember seeing your water Raptor. That thing was funky indeed!
Pat
Old Jan 02, 2011, 09:57 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
F22
Break it, crack it up, snap the nose off, fly it till it falls apart, fly it off water...... is there anything this plane won't do???? Marty
martys is offline Find More Posts by martys
Old Jan 02, 2011, 09:59 AM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
#2 f22
Airframe #2 built and ready for paint (just in case I can't do without another one!). Marty
Old Jan 02, 2011, 01:39 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
What do you mean "just in case"? I was without an F-22 for about a month once. Drove me absolutely insane! Now I'm never without one in the inventory for personal use.
Pat
Old Jan 02, 2011, 06:38 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Old and new
OK Boys, Pat, here's a shot of the first and second airframes (2nd not quite done yet). I took my time and did a nice job on filling gaps and reinforcing the seams. The second F22 will have the same equipment as the first (it ain't broke so I'm not messing with it). This will include the Spektrum 6110, 5 gram HXT servos, 1806/2500KV motor, 10 amp HKSS 10 amp SC and a 500-800 mah 3 cell battery. Just have to decide on a proper camo scheme. BTW, the original F22 is still going strong wilh many flights on her (right Fran?). Marty
Old Jan 02, 2011, 07:24 PM
Novato, CA
Joined Dec 2008
Hey guys sorry to ask this question, but I lost track of the placement of the CG. I have to leave for the evening but hope to get this ready for a maiden for the morning. It might be on my plans at my shop, but I'm not sure. Any help here??
Old Jan 02, 2011, 08:45 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I took one of Marty's pics and put the CG on it. Just behind the notch opening that I marked in a red rectangle.
Also, here's the build guide:
http://www.nicohobbies.com/store/fre...ly%20Guide.pdf
Pat
Old Jan 02, 2011, 09:09 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Pat
Glad to be of service Pat!
Old Jan 02, 2011, 09:14 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Motor mount
I've decided to not use a stick mount on airframe #2 (if you look carefully at the picture you can see it). I've opted to use a piece of multi layer plywood and epoxy glue it directly to the formers (upper and lower). This will undoubtly provide a strong mounting so I can use the stock round base mount that comes with the motor. More pics to come on the build. Marty
Old Jan 03, 2011, 12:15 AM
Novato, CA
Joined Dec 2008
Thanks guys just what I needed.
Jeff
Old Jan 04, 2011, 05:27 PM
Novato, CA
Joined Dec 2008
Hey Pat, I got a motor problem on the little guy you sent me. I flew it once, and then I got a new prop to try a 4540 while putting on the new prop, I noticed that the magnet cover is loose and therefore mis aligned. If i push it towards the magnet things line up and it spins freely, but it seems it needs to be pressed back on. I have a drill press I've used in the past to replace shafts, etc as a press, can I press this thing back on somehow? Thanks,
Jeff
Old Jan 04, 2011, 06:07 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
Originally Posted by AirmanAirhead View Post
So here's a photo of my version of the mini F-22...
Looking good buddy!
I've seen CaptGeek (above with 2200 KV motor question) fly his 100% F-22 with the nose completely gone from a crash...
can't beleive this same plane is still flying! over a year old, nose smashed off multiple times. lost for over a week in high winds, neighbor found it and returned. here it is before maidened:
http://www.rcgroups.com/forums/attac...mentid=2916598
and here's it famous rocket ship take off's can't wait to try to do this shot again:
f22 rocket ship take offs and waves (3 min 22 sec)
f22 profile foam prop jet rocket ship takeoff (3 min 31 sec)
captaingeek is offline Find More Posts by captaingeek
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 10:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 09:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 08:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 11:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 01:01 PM
