Old Dec 28, 2010, 10:48 PM
AirmanAirhead is offline
Find More Posts by AirmanAirhead
AirmanAirhead's Avatar
Novato, CA
Joined Dec 2008
Anybody know where you can get the recommended motor (Mini F-22) or a similar one other than HobbyKing? Was hoping to find a supplier in the US
AirmanAirhead is offline Find More Posts by AirmanAirhead
Old Dec 29, 2010, 12:16 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Jeff,
I have a couple motors and ESCs in stock. I was holding them back for some RX-ready planes, but can sell you one if need be. I've put it up on the site.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Dec 29, 2010, 12:21 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Beat me to it!
Jeesh Pat! You are quick on the trigger! I was about to recommend you and you beat me to it. BTW, I'm off tomorrow and plan to cut out another F22 kit. Just in case I need one! My current warrior is looking a little battle worn, but still going strong! Marty
martys is offline Find More Posts by martys
Old Dec 29, 2010, 12:23 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Marty,
That's the great thing about these little planes. Just spend a few hours cutting and assembling a new airframe, and move your electronics over and viola! New plane!
And I had already sent Jeff a PM earlier today, but the motors were listed as out of stock on my site. That has been fixed.
Pat
Old Dec 29, 2010, 12:27 AM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Originally Posted by crxmanpat View Post
Marty,
Pat
Excellent Pat! Gotta get some new blood. After all, we all suffer from the same addiction! Nothing like encouraging others to share eh? Marty
Old Dec 29, 2010, 12:29 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
After the AZ Electric Festival at the end of January, I plan on placing a large order directly from the motor manufacturer (and cut out the middleman, namely Hobby King). That should tide me over for most of the year. As it is now I have been making small orders to HK every month. But it seems I almost always run out of stock right away.
Not any more.
Pat
Old Dec 29, 2010, 10:41 AM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Not any more.
Pat
Great idea Pat! I'm not aware of any substitutions for the motor, but I'm old school. If it ain't broke, leave it alone! I have 3 of these motors. BTW, I've changed from a 5X3 to a 4.5X4.5 gws prop. What are you recommending? The plane wants to torque roll on my palm with the new prop. If I were to guess, I'd say it should work! Marty
Old Dec 29, 2010, 11:29 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Adam and I tested many motors (lots from HK directly). We never found anything better than this one. Once I have this large stock of motors, I will be reducing the pricing on them and the ESCs.
I use a GWS 4530 prop exclusively now. With the higher C lipos we're using, the 5030 cavitates too much. and the 4545 may be too much pitch for the motor. Keep an eye on the amps.
Pat
Old Dec 29, 2010, 02:08 PM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Crxmanpat,
I've use the APC 4.5x4.5 with the 1806 and the GWS 4530 doesn't compare. I haven't checked the amp draw yet, but the 850mAh 3S would be a better match. I have Watts Up meter now. I'll post data in the next day or so, on vaca at the moment. By the way, the Draken literally leaps forward when you hit the throttle.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Dec 29, 2010, 04:25 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I may have a GWS 4545 in my stash. I'll take a look and put it on the wattmeter if I have one.
And yes, the Draken is one fast puppy, just like Marcel's original one in 6mm.
Pat
Old Dec 29, 2010, 04:35 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I don't have any GWS 4545 props (I think they only make a 4540), and I can't seem to find an APC 4.5x4.5 prop. Are you sure it's not a 4.5x4.1?
Pat
Old Dec 29, 2010, 08:29 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
My Bad!
Well Boys, I just looked at the package for the GWS props and they are 4540s! Figures, the older I get the worst I see! Sorry Boys! Marty
Old Dec 29, 2010, 11:56 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
OK, cool. I'll pick a few up next time I order from the distributor.
Pat
Old Dec 30, 2010, 01:26 AM
ksqm is offline
Joined Mar 2009
Crxmanpat,
I'm on the road, but I'll check when I get home. GWS has 4040s.
Ksqm
Old Dec 30, 2010, 10:05 AM
Novato, CA
Joined Dec 2008
Originally Posted by ksqm View Post
Crxmanpat,
Ksqm
So are we looking for 4040s or 4540?
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
