Old Sep 03, 2010, 01:50 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
You got me then. Just turned 44 a month ago. But I say 29 with 15 years experience!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Sep 03, 2010, 05:22 PM
SCAZE is offline
Find More Posts by SCAZE
SCAZE's Avatar
Sweden
Joined May 2009
My scale is not so good i belive, but not over 6oz is it.
150-160g and 17" should not be any problem??
Some paint now and then ^^
/Anders
SCAZE is offline Find More Posts by SCAZE
Old Sep 03, 2010, 07:05 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
That size and weight should be perfect!
Pat
Old Sep 04, 2010, 05:59 PM
deanc338 is offline
Find More Posts by deanc338
Shut up and talk to me!!
Manila
Joined Aug 2006
Pics of my F22 based on Adam's 5mm 20x30 plan
She flies ok, loops and rolls fine, but the 1811-3800 feels underpowered for this 180g plane. Waiting for the delivery of the recommended motor and see if it will make this thing scoot.
Thanks adam for a fantastic plan!!
deanc338 is offline Find More Posts by deanc338
Old Sep 06, 2010, 06:17 AM
deanc338 is offline
Manila
Joined Aug 2006
Some flying pics last weekend, the camo almost made it invisible when passing in front of those thunder clouds
Old Sep 06, 2010, 08:02 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
That's what is't all about deanc! Having fun and enjoying something YOU built! Keep her flying! Marty
martys is offline Find More Posts by martys
Old Sep 06, 2010, 04:26 PM
SCAZE is offline
SCAZE's Avatar
Sweden
Joined May 2009
Flew mine yesterday and it was so easy to fly.
For an minute or so it was no problem. Did an loop an should do a roll when one rudder must hawe got lose.
Whent right down in a barrel roll an is no more
Going to build another one but beeing more careful while building
Old Sep 06, 2010, 04:31 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Ouch! Sorry to hear that. I use hot glue to secure my control horns.
Good luck on the next one!
Pat
Old Sep 06, 2010, 04:39 PM
SCAZE is offline
SCAZE's Avatar
Sweden
Joined May 2009
My heatgun is to hot for depron, it melts
Just forgot to use glu at all on them
Old Sep 07, 2010, 10:36 PM
foxy29 is offline
Find More Posts by foxy29
foxy29's Avatar
scunthorpe/england
dean, ive found the best auw for that motor is 120g and it should do about 50mph, mine did, but got porky at 140g still fast but felt sluggish, and best prop ive found is the gws 4x2.5.
ive also just FINALLY got the 1806 2500kv motor(i have a 2350kv one), its been out of stock for donks, and what amp draw are you guys getting on it? a 5x3 is pulling 14amps!!!!! a 4.5x4.5 pulls 11, tis only rated at 8amp what the smeg.
a 5x3 on the 2350kv gets 8 odd, i have a range of props to test but its late and every one is in bed, but its looking like a 4x2.5 should work or clip one down to a 4x3, a 4.1x4.1 might work 10amp i can live with as i have massive in flight cooling using a heatsink in air flow, but even 11 amp was not that hot, 14 was tho after it had stood and the heat had transfered from the windings
foxy29 is offline Find More Posts by foxy29
Old Sep 07, 2010, 11:00 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I've found that the GWS 4530 (4.5x3) is the perfect prop for this 1806N 2500kv motor.
Pat
Old Sep 08, 2010, 02:59 AM
deanc338 is offline
Manila
Joined Aug 2006
Yup 4x2.5 seems the right prop for the motor. But my AUW is about 180g so it gets a bit undepowered and sluggish. My weight might be because I used 5mm foam board from the 20x30 plan and used a 2S 800mAh lipo. I ordered a couple of 3mm FB and build another one when the recommended motor arrives.
Anyways, this thing fly and could easily catch up with my fellow flier's GWS Zero and Guanli P47 warbirds even if it is a bit underpowered.
Old Sep 09, 2010, 04:58 AM
foxy29 is offline
foxy29's Avatar
scunthorpe/england
Pat
thanxs pat i will try one of those as well, it was only size i missed, i spent more on props than the motor cost, ive tried a 4x4.5 which worked well and the 4.5x4.5 was ok but compared to the 2350kv one it seemed slow using the same props, and the 2350kv on a 5x3 really shines,bit disappointed in the performance of the 2500kv motor.
if you build out of 3mm it should come in at about 120g using a 500mah or 800mah 2s and 5g servos, i prefer tha 1811 if i can keep it light as it just bounces and is almost as quick as using the 2350kv one and seems to high alpha better but both are excellent performers,one is just lighter.
o yeah i forgot to say i love the noise of the 1811 its a little screamer aint it, i could not believe how much power it had for something so tiny(ive lost it more than once lol), i want to use it for a little 3D plane or a mini hotliner,im gonna try for 100g or under and it should be like off a shovel at that weight. or maybe the 12in f22 if im not dreaming that there are 12in plans
ps ive ran doppler on the 1811 3800kv 120-130g f22 at 40mph 45mph and 50mph(downwind).
i could not get a clear run on the 1806 as i got prop flex and it made a weird noise so could not get a speed reading
Old Sep 10, 2010, 01:14 PM
Jee is offline
Jee
Find More Posts by Jee
Jee
Jee's Avatar
Germany, BW, Ulm
Joined Jun 2010
-news from germany..
So I failed to check my servos worked in the correct directions... wich meant after the start it took about 0.1 seconds to completly crush the F-22s nose.
Anyway.. after setting the servos up the correct way it was flying.. without a nose now.. tail heavy.. and with a terrible role rate.. but still.. it was controlable - this is my first self build plane - and it's my second plane ever (30 flights of HK-Miniswift is my whole flying experience) - so I am still proud it flew.
(Even if I'm very angry with myself rushing to fly without checking everything.. )
Here is what happend:
Youtube F22 Crash & Flight
I'll now build a new nose - at home i removed the crushed parts completly, and I think I can attach a new nose.
And man.. this thing is noisy - I am using these components:
AX 1806N 2500kv Brushless Micro Motor (19g)
HXT500 5g / .8kg / .10sec Micro Servo
HobbyKing 12A BlueSeries Brushless Speed Controller
GWS EP Propeller (DD-5030 127x76mm)
Rhino 610mAh 2S 7.4v 20C Lipoly Pack
+ a prop saver
+ some balsa wood
+ 1mm wire
My roll rate is terrible (I can fly arround, but I absolutly can't roll the jet.. it's so slow I would crash into the ground before it comes arround).. not sure what exactly I did wrong. But with a new nose I'll sure do more flights and experiment arround.
So much for now, thanks for the plans for this plane!
Jee is offline Find More Posts by Jee
Old Sep 10, 2010, 06:10 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
+ a prop saver
+ some balsa wood
+ 1mm wire
Go with a smaller prop, dump the 2S battery and go to a 3S. Set your controls for max deflection and add some differential at center. That will wake it up! I fly a 3S 800 mah or a 3S 500 mah battery in mine. Flys great rolls good and is fast!! marty
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
