Old Apr 09, 2010, 08:47 AM
Ace12GA is offline
Find More Posts by Ace12GA
Ace12GA's Avatar
Canada, ON, Peterborough
Joined Oct 2009
My overloaded airframe flew on an APC 4.75x4.75 on a 20g 2200kv motor with a 500mah 2s batt. Flew is a loose term. I could keep it in the air at WOT if I worked at it. My airframe however, is nearly 2x heavier than one built from 3mm depron. Its 5mm depron with hot glue, and a doubled up KFm airfoil. Mine now flies nicely on a larger prop and motor.
I'm curious to the performance increase by giving the wing a slight UC at the leading edge; looking forward to your maiden.
Ace12GA is offline Find More Posts by Ace12GA
Old Apr 09, 2010, 09:35 AM
foxy29 is offline
Find More Posts by foxy29
foxy29's Avatar
scunthorpe/england
some one on the thread quite a bit back put some slats on the LE of his wing and said it worked well, i think when i get a new motor i will build another and use this one as a test bed for all kinds of stuff, and its nice to have a spare this plane flys so well i dont want to be without one now
got my f15 done im going to maiden in a min so fingers crossed and the weather is purfect no wind at all no breaze at all perfect maiden weather yay
edit perfect maiden flew mint only needed some down trim tiny bit tail heavy maybe rolls are drill like and very fast tis a fast plane once i dial it more should be good
foxy29 is offline Find More Posts by foxy29
Old Apr 09, 2010, 03:08 PM
fraggin is offline
Find More Posts by fraggin
Spring, TX
Joined Jun 2006
Originally Posted by foxy29 View Post
what motor are you using on your craptor fraggin
hextronik 24gram bm with a 3s lipo.
Kv - 3000rpm/v
Load [no prop]: 1.2a / 7.4v @ 21500rpm (0g thrust)
Load [7x4 prop]: 21A / 7.4v @ 8800rpm (380g thrust)
Load [8x3.8 prop]: 22A / 7.4v @ 8200rpm (430g thrust)
fraggin is offline Find More Posts by fraggin
Old Apr 09, 2010, 04:40 PM
foxy29 is offline
foxy29's Avatar
scunthorpe/england
Kv - 3000rpm/v
it should rip with that prop
4,75x4,75 2s/13,6A/102W 3s/24A/262W
if this is out to go by 262watts will be quick sharp on a light 100-140g plane my 3800kv 10g 7 amp motor is pushing 40mph on 2s so yours should scream have you got a watt meter??
Old Apr 09, 2010, 07:44 PM
fraggin is offline
Spring, TX
Joined Jun 2006
I have a multimeter, but not an inline tool like for R/C. I fitted everything on today, need to balance and velcro in battery and adjust thrust angle on the motor. After that, just some reinforcing and a search for tall grass.
I tested the motor with that prop and it really screams. Sounds like an electric leaf blower.
Couple of questions though.
With all the gear and supposedly balanced, what kind of toss will I have to give it to test cg and glide with no power?
What kind of thrust angle do you guys reccomend?
Old Apr 09, 2010, 07:52 PM
foxy29 is offline
foxy29's Avatar
scunthorpe/england
i dont use any but or 2 degree right thrust wont hurt if its got a lot of torque roll
you can use a multimeter witha a 10 min mod and a few plugs an a reisister
look here its what i use it says 10a on meter but goes to 20 and will do more if you solder to the shunt inside
http://www.rcgroups.com/forums/showt...=949923&page=2
a post by sir Raleigh has the best pic took me 10 mins to do and i riped a reisister out of some dead leccy crap i always keep
http://www.rcgroups.com/forums/attac...mentid=2376163
my cg is just after the first tab after the wing /fuse join at about 4 and half cm after the wing break if its about there it will be golden dont need much of a lob to test just try it on maiden with power on, mine flew on first go even with cg to far back just trimmed it out you will enjoy this plane its my fave at the min
Old Apr 10, 2010, 08:01 PM
fraggin is offline
Spring, TX
Joined Jun 2006
It flew after getting the elevon mix right. Lots of control. I really need to build another one now and give it the detail it deserves. I like how you can just raise the nose to slow it down.
Old Apr 10, 2010, 08:02 PM
foxy29 is offline
foxy29's Avatar
scunthorpe/england
quick question to those who use this gorilla glue stuff, what size bottles do you buy most, and how many planes does it build on average, seen 2oz-57ml bottles for like 3.50 and 115m bottles for 5 quid and 8 for 275ml bottles from here.
http://www.gluegorilla.co.uk/
and p+p is 1.50 seen cheaper but P+P was way more but this seems like very good glue for depron,and i plan on using depron a lot i love building now im hooked i will never buy another plane again, unless it somthing special lol
Old Apr 10, 2010, 09:34 PM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Originally Posted by crxmanpat View Post
foxy,
A friend of mine is actually working on producing a series of planes similar to the Steve Shumate builds, but reduced down to about 66%. They use 6mm depron and he will use the same power system I have for my mini pushers.
Don't know if he'll post plans, but I may be selling kits for him sometime in the future.
Pat
Pat let me know if it happens. Marty
martys is offline Find More Posts by martys
Old Apr 11, 2010, 12:07 AM
belabs is offline
Find More Posts by belabs
Philippines, NCR, Makati City
Joined Dec 2004
Hi guys! I need your opinion.. I cant find a AX 1806N motor locally. What can you say about this motor as an alternative? http://www.gsmodels.com/en/products_view.php?id=256
If im going to use this one, does it mean I have to use a bigger prop (8x4)??
belabs is offline Find More Posts by belabs
Old Apr 11, 2010, 02:58 AM
foxy29 is offline
foxy29's Avatar
scunthorpe/england
glad you got it flying, i love just slowing right down to almost stall and give it full wack and watch it accelerate in an instant,also high alpha is fun with this plane i like to come down as low as i can then shoot off full wack just before i touch the ground impresses the kids they love it ,my nephew thinks he can run faster and likes to try racing it when i slow down and then shoot off good fun
Old Apr 11, 2010, 05:21 AM
foxy29 is offline
foxy29's Avatar
scunthorpe/england
dont know those motors but cant you find any hexotronic or there clones, no location in your profile so cant recomend a store if your in the usa try crx's nicco hobbies he has them
http://www.nicohobbies.com/store/
or hobbyking not ordered from them but they do world wide
http://www.hobbycity.com/hobbycity/s...idProduct=5432
but any 10g-to 24g fairly high kv motor will work say 2100kv to 3800kv range will work, the 24g 2100kv and 2500kv ones do very well 50mph kinda speeds on 3s
im using a turnigy 10g t1811 3800kv on a 4x2.5 gws or a 4x3 and a 500mah 2s and a 800 2s
or try a blue wonder type in 2500kv or 3000kv or even a emax 2805 on 2s but seen peeps run these emaxes on 3s with no probs but some have tho,turnigy do a range that will work as well a D2211 at 2300kv 19gram would work on a 5x3 or 5x4
off topic here is a link to pics off my shumate f15 enjoy
http://www.rcgroups.com/forums/showp...postcount=2526
Old Apr 11, 2010, 10:10 AM
Ace12GA is offline
Ace12GA's Avatar
Joined Oct 2009
I find Gorilla Glue is only useful for laminating foams, say when making a KFm wing, or a flying wing, or a monobloc fuselage. Gorilla Glue needs to be clamped, because it expands. Its very strong, and if used conservatively, very light. For butt joints, or main air frame assembly its not terribly good. I have started using Fabritac for depron joints, and it works really well. It is supposed to be a great replacement for UHU Por or Creativ. If you can get Por or Creativ, they are the glue to get apparently for depron. Setup time is 1 hour, full cure in 24. Gorilla Glue is set and cured in 2 to 4 hours.
Also, if you can get Elmers Ultimate Glue, its the same as Gorilla Glue, and half the price. I have them both, and its the same thing. Goes on the same, sets up the same, and is as strong.
My 8oz bottle of GG has laminated the wings on 7 planes, and the monobloc on 2. There is about 2oz left. I have wasted a lot learning to use it.
Old Apr 11, 2010, 02:20 PM
foxy29 is offline
foxy29's Avatar
scunthorpe/england
thanks for that info ace,i never heard of fabritac looks like i will be looking in the sewing shops, uhu por is 5.50 in the model shop a complete rip or it would be what i use, the depron place i use is 2.50 BIG difference just forgot to stick it on my order. i have been using bostick solvent free comes in 2 flavors bog standard and extra strong its good for bits that fit first time and is like a contact glue if left for 10 mins but takes hours to dry if you just put parts together with no drying time before puttin parts together so guess it needs air to work its like a white glue and bond is fairly strong but gives before the foam does unless a large area is glued and is only 1.67 AND IS SOLD ALL OVER big plus asda/wilco's most diy shops,but sort of helps to absorb shock in my several f22 nose in's lol. looks like all my glue is coming from the land of internet as not one shop and ive looked in almost every shop that does diy/glue type stuff nothing only wood glue and nothing PU like probond, i hate this town more and more each day its pathetic for stuff like this lol
Old Apr 11, 2010, 02:49 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
An agent
Foxy, you need an agent in the USA to help you purchase what you need/want! Stop farting around with those rip offs where you live. PayPal will convert currency for you when you send money to someone else. I have no idea about shipping prices, but they can't be that bad. Just a thought. Marty
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
