Old Jun 25, 2009, 05:01 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Originally Posted by adbradley
FYI i will soon be offering a light weight 25c to 45c burst 450mah pack that can be charged at 5c, that means you can have a packed charged in less than 15 minutes! These batteries will sell for 15.99 and weigh in at 42 grams, it will be the lightest and most powerful pack we will have to offer.
Any news on these packs?
carlsoti is offline Find More Posts by carlsoti
Old Jun 25, 2009, 05:49 PM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
They are still on the slow boat from china from what i understand, i will keep you posted.. i do have some 500mah 20-30c packs on my site right now for $14 http://www.nicohobbies.com/store/ind...2543b081e1b0b4
adbradley is offline Find More Posts by adbradley
Old Jun 26, 2009, 12:40 PM
adbradley's Avatar
Joined Mar 2007
Great news the 450mah packs that can be charged at 5c are here!!! i will have them listed on my site by this weekend
Old Jun 26, 2009, 01:01 PM
carlsoti is offline
carlsoti's Avatar
Joined Jun 2008
Mark me down for two! Maybe, if you're not too busy, we can meet up somewhere. Do you plan on flying at any of the local fields saturday night, or anytime sunday?
Old Jun 26, 2009, 02:36 PM
adbradley's Avatar
Joined Mar 2007
I dont get to do much flying these days, but i may be able to meet up with you somewhere, im located at signal butte and southern, and i drive to tempe every day down the 60 for work, so maybe monday morning?
Old Jun 27, 2009, 02:30 PM
adbradley's Avatar
Joined Mar 2007
I have a few new battery options avilable on my site now, as well as the new Hyperion G3 Packs that can be charged at 5C!!
Old Jul 02, 2009, 06:37 PM
bsfixit is offline
Find More Posts by bsfixit
bsfixit's Avatar
Sarasota, FL
Joined May 2009
I am a noob to this type of kit... how do I assemble it? I know the electronics side of it.. I am retired ASE master mechanic.. but I never liked puzzles..
the worst puzzle I did while working was a lexus head rebuild .. probably
thousands of parts... but ... I would think some kind of manual would tell me how to put this puppy together.. screws for the motor mount or is everything glued?
going to pick up the CA and accelerant tomorrow...
bsfixit is offline Find More Posts by bsfixit
Old Jul 04, 2009, 10:38 PM
keithdubya is offline
Find More Posts by keithdubya
Build - Fly - Crash - Repeat
Arlington, TX
Joined Sep 2007
If you look at the pictures people posted, its pretty easy to figure out. For the motor mount, I used a 1" x 1" 1/8" thick ply to mount the motor with screws or tiny nut and bolt. Then I epoxy the whole thing to the styrofoam with 6 minute epoxy. I thought it was going to be hard to line it up properly, but if you keep adjusting it until it gets hard, it seems to work out. Going through the early posts in this forum helped me alot. Its worth the effort, this has been a great plane. I am building a new one right now, the old one was looking pretty beat up. I got a cheap airbrush kit at the hobby shop yesterday. Hopefully this one will look better than the last.
Keith
keithdubya is offline Find More Posts by keithdubya
Old Jul 05, 2009, 01:15 AM
adbradley's Avatar
Joined Mar 2007
Id love to see some pics when u get it all painted up Keith, Thanx for being a great customer
Adam
Old Jul 05, 2009, 01:25 AM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
What you can do is check out the assembly of my F-15 starting at post 32 on this thread:
http://www.rcgroups.com/forums/showthread.php?t=1033244
It's pretty much identical to the F-22. Also, check out my thread on general park jet construction techniques:
http://www.rcgroups.com/forums/showthread.php?t=1052464
This will give you some tips and pointers as well. One thing I recommend NOT doing is using foam safe CA and accelerant. CA tends to get brittle and shatter. One of the foam glues I mention in that thread work much better.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Jul 05, 2009, 08:43 AM
bsfixit is offline
bsfixit's Avatar
Sarasota, FL
Joined May 2009
Thanks Everyone, When I got the kit I didn't realize there were so many other similar builds I could follow. Now I know which glues to use.. I am almost done with assembly. Thanks Adam for a great kit and Customer support.....
Old Jul 05, 2009, 09:51 AM
profilefan is offline
Find More Posts by profilefan
profilefan's Avatar
United States, NY, New Hyde Park
Joined Jun 2008
Hey guys, i busted my gws prop i got from nicohobbies. My friend has a 4.5x4.5e, i tried it and it works but motor seems a little warm. Not sure if that is bad, what do you guys think?
profilefan is offline Find More Posts by profilefan
Old Jul 05, 2009, 10:10 AM
bsfixit is offline
bsfixit's Avatar
Sarasota, FL
Joined May 2009
I am going to try to add some landing gear to protect the prop and be able to land.. well see if I can do it .. I saw a thread where it was done.. somewhere on here..
did you use a prop saver?
Old Jul 05, 2009, 11:34 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I highly recommend a prop saver so that it protects your props as well as your motor mount on landings. Adam has two kinds available, one for regular APC type props, and one specially machined for the GWS props.
profilefan, yes that higher pitch will get your motor warmer, but as long as it's not overly hot after flight, you should be OK. Also a good idea to check your amp draw and make sure you're not taxing your lipo or ESC.
I had the lower 2200kv version of this motor on my F-22 and flew it with an APC 4.7X4.1E no problem.
Pat
Old Jul 11, 2009, 11:08 PM
Arlington, TX
Joined Sep 2007
Adam,
I Finally got it finished. I think this is the third mini F-22 I have built of yours. Each time it gets a little easier. Here is a picture of it. I hope to Maiden it tomorrow if the wind isn't too bad. Thanks again for the plans Adam. This was the first scratchbuilt foamie I ever built. It is a great plane to learn on. It runs fast or slow, and handles the wind well too. Now I have built around 8 foamies, 3 of them were the mini F-22. Its a great plane, I keep going back to it. The first one went down hard about the 15th flight. Pilot error of course The second one I retired after almost 50 flights. It was looking pretty beat up.
Keith
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
