Old Mar 30, 2009, 03:37 PM
alexsosnovski is offline
Find More Posts by alexsosnovski
Joined Jan 2009
It was a good lesson for me not to hurry. Such lessons should better be learnt on cheap and easy to repair planes than on something bigger and more expensive.
alexsosnovski is offline Find More Posts by alexsosnovski
Old Mar 30, 2009, 04:26 PM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
Yes this is very true!
adbradley is offline Find More Posts by adbradley
Old Mar 31, 2009, 12:14 AM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
Thank you Pat! for F15 , so are we going to make it of 3mm? or 6mm?
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Mar 31, 2009, 08:04 AM
adbradley's Avatar
Joined Mar 2007
its designed for 3mm
Old Mar 31, 2009, 08:37 PM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
F15
Adam, is the center fuse made from 6mm or 3mm? Thanks Marty
martys is offline Find More Posts by martys
Old Mar 31, 2009, 09:12 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I would use 6mm for the center fuse section. It works great on the F-22 and has been rock solid in a few smash ups.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Apr 01, 2009, 08:17 AM
adbradley's Avatar
Joined Mar 2007
its designed for 3mm, but 6mm would work also, just have to widen the notches
Old Apr 05, 2009, 02:29 PM
JaJaJim is offline
Find More Posts by JaJaJim
Joined Dec 2008
+1
4mm depron, robbe ROXXY 2214/31 outrunner, HYPERION TITAN 10A esc, AR6100 6CH DSM2 and kokam 450MAH 11.1V accu
weight +- 145g, near 2.1 trust/weight
JaJaJim is offline Find More Posts by JaJaJim
Old Apr 05, 2009, 03:10 PM
adbradley's Avatar
Joined Mar 2007
looks great!!!
Old Apr 05, 2009, 04:13 PM
JaJaJim is offline
Joined Dec 2008
thanks a lot for pdf`s !
Old Apr 05, 2009, 07:05 PM
guys what about F15 Progress ? is any one start making it????
video for my F22, remmber i am new pilot
20090405072515 (2 min 48 sec)
Old Apr 10, 2009, 05:21 AM
Ok Guys, here is F15 Pic, Pat if you think i am some where wrong please let me know. Hope fully i will finish that tomorrow. and will post an update...
Old Apr 10, 2009, 10:27 AM
adbradley's Avatar
Joined Mar 2007
aqkhana, that looks great! how did all of the parts fit? did you find any errors?
Thanx
Adam
Old Apr 11, 2009, 07:43 AM
Thanx
Adam
yes adam , all parts were ok! i will post more pic after 2hr
cheers
Old Apr 11, 2009, 01:41 PM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Hi Guys,
I just maiden my F15! Flew great, no trim necessary, I just had to dial 40% expo to ailerons, somehow it is much more sensitive to roll then F22.
All the guts were transfered from my F22, no change.
The batery has to be att. up front of airscoop on the vertical part of fuse to get proper CG.
Janusz Jawien is offline Find More Posts by Janusz Jawien
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
