Old Feb 08, 2009, 04:45 AM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
i m lucky that i have pat hay pat i change prop from 5*5 apc to 4*7.5 apc and got my power back, i hope that will fly now. 2nd just one quesiton how much you thin motor can be heat? if ran arround 1 mnt it was heated not much but yes was,,,,
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Feb 08, 2009, 12:20 PM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Sr71
Any plans available yet on SR71? I would LOVE to build one! I just happen to have a motor just waiting for a home. Marty
http://www.hobbycity.com/hobbycity/s...Outrunner_(10g)
martys is offline Find More Posts by martys
Old Feb 08, 2009, 12:22 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
My prop
Boys I use a 5X3 prop on mine. Only had to notch the body a little. Didn't affect the airframe at all. It's got plenty of thrust. Marty
Old Feb 08, 2009, 01:07 PM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
5x3 is perfect for this motor on 3s,
i will get plans up monday
adbradley is offline Find More Posts by adbradley
Old Feb 08, 2009, 01:13 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Plans
Thanks Adam! I can assure you there will be several members in the club (South Jersey Silent Flyers) anxious to build and fly her. It seems like these pusher jet designs are catching on like wildfire! I will post pics and a flight report for you of the build if you would like. Boy, I can't wait! Marty
Old Feb 08, 2009, 03:32 PM
helipilot is offline
Find More Posts by helipilot
Clear for Take-Off!!!
Dexter, Michigan USA
Joined Nov 2003
AD, Un-real! Looks like I will be downloading another fine plan set from you tomorrow! I cannot wait. Thanks a bunch for such a fine design. It also looks like I better order up some more depron!
helipilot is offline Find More Posts by helipilot
Old Feb 08, 2009, 09:14 PM
Hay Pat, asking quesiton again , is there a way before flying you can guess your CG?
Old Feb 08, 2009, 09:47 PM
adbradley's Avatar
Joined Mar 2007
Im glad you guys like the sr71, i almost have the f15 done as well.
The sr71 prototype is half built, i will get some pics up asap.
i will take some requests, any other attack or fighter jets you would like to see in my style?
Old Feb 09, 2009, 02:05 AM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
That SR-71 looks kool too! Can't wait to build it!
On the 10 gram hobbycity motor with turnigy 10 amp esc..and 3s 610mah 20c should the motor and esc be getting hot?
Flexserve is offline Find More Posts by Flexserve
Old Feb 09, 2009, 04:59 AM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Motor
Come to think of it Boys, I think I will opt for the 19 Gram motor since the SR71 looks like it'll be larger. As far as planes, the Mig 15 and the F86 Sabre jet are 2 of my favorites. Marty
http://www.hobbycity.com/hobbycity/s...cro_Motor_(19g)
Old Feb 09, 2009, 07:59 AM
adbradley's Avatar
Joined Mar 2007
I have not tried that motor, i use the 19 gram motor that martys linked to above. sorry
Old Feb 09, 2009, 08:03 AM
adbradley's Avatar
Joined Mar 2007
It actualy is quite a bit larger, i beleive its going to be to large for this power combo, had to tell when drawing it. so i may have to shrink it down.
there are already some decent designs out there for the mig and saber, i wanna stick with newer jets. i think i may do a mirage 2000
Old Feb 09, 2009, 10:22 AM
adbradley's Avatar
Joined Mar 2007
ok guys, here is the sr71 thread with plans posted
http://www.rcgroups.com/forums/showt...8#post11542042
Old Feb 09, 2009, 10:44 AM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
oops meant 19 gram..thats the one I have. GWS 4.5x3 prop and everything gets hot..is that overkill on the prop. (Battery is Rhino (Zippy) 610Mah 3s 20c) ESC is Turnagy 10 Amp.
Old Feb 09, 2009, 10:59 AM
adbradley's Avatar
Joined Mar 2007
Shouldnt be, this is the same setup i use.. my motor, esc, and battery get warm to the touch, but not hot enuff that you cant hold your finger on it for sevral seconds..
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 10:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 09:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 08:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 11:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 01:01 PM
