Old Sep 26, 2012, 11:15 PM
mrexcel is offline
Find More Posts by mrexcel
mrexcel's Avatar
Joined Jul 2009
Its a DIY cammo using the Printer.
mrexcel is offline Find More Posts by mrexcel
Old Sep 26, 2012, 11:17 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Ah, very cool indeed then!
Pat
crxmanpat is offline Find More Posts by crxmanpat
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
Thank you!
Old Sep 28, 2012, 04:40 AM
Sparken57 is offline
Find More Posts by Sparken57
*GRAVITY* I hate it :(
Sparken57's Avatar
USA, CA, Downey
Joined Jan 2010
5.5 oz
Originally Posted by adbradley View Post
Here is my 3mm depron 18.8 F22, it is much like Tomhe's.
The motor i used is this
http://www.hobbycity.com/hobbycity/s...idProduct=5432
I am currently flying it with a 5x3 prop, and a 2 cell 620 pack, im going to try a 3 cell soon.
My AUW is 5.5 oz
This plane flys great slow or fast.
I have added the plans in .pdf, Tiled, and Full.
I guess your 5.5 AUW is 2 cell My lightest 3 cell is 99g or 3.5oz its a 1500 25c
lighter than most 1500 I may have to invest in a 1000mah 3 cell I have a micro plane 18"X20"ws still building but AUW is double your plane 10.25oz Im trying to use the electronnics I have servos 3X5g receiver orange RX no case-2.6g
now here is the weight esc 24g motor prop and M mount 65g I guess my question is do you think it will fly at that weight 10.25oz Thanks
Sparken57 is offline Find More Posts by Sparken57
Old Sep 28, 2012, 09:34 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
His AUW was using a 3S 500mAh lipo, 2 5-gr servos, a 19-gr motor, and 6-gr ESC.
These days I'm using the same setup except the lipo is a 3S 805mAh, and my AUW is 6.5oz.
What motor/prop are you using on your build, and what plane is it?
Pat
Old Sep 28, 2012, 02:58 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Mine weighed exactly 5 oz with a 450mAh 3S. I usually fly an 800, now, so it's a bit heavier.
mclarkson is offline Find More Posts by mclarkson
Old Sep 30, 2012, 12:24 AM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
450ma 3s is my battery of choice
alpea 41 is offline Find More Posts by alpea 41
Old Oct 09, 2012, 03:01 PM
evalith8 is offline
Find More Posts by evalith8
Let the hating begin
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
I would like to scale this up about 3-4 times bigger.can anyone tell me how to get some measurements & where to get some foam to do it?
evalith8 is offline Find More Posts by evalith8
Old Oct 09, 2012, 03:11 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Well, this one at 18.8" WS is actually a reduced-sized version (about 66%) of this one at 28" WS:
http://www.rcgroups.com/forums/showthread.php?t=723890
I think there may be a plan at 200% on that thread, which may be what you're looking for (that would be 300% of this one). As far as foam, I'd do either 6mm depron and double it up in some spots, or see if you can get hold of some 9mm depron. You can order 9mm depron from RCFoam here:
http://www.rcfoam.com/index.php?cPat...7016d73aad2da1
Also, I see you're in Hampton. Did you go to Electrics Over Tidewater a few weeks ago? A guy named Perry won one of my Su-30 kits, and just also ordered one of the F-22s.
Pat
Old Oct 09, 2012, 03:14 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
If you're gonna make it over six feet (?!!) you'll definitely have to go a bit thicker on the material and maybe add some CF reinforcement.
Old Oct 09, 2012, 03:31 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Here's the 200% plans from tomhe's F-22 thread.
http://www.rcgroups.com/forums/showp...postcount=2057
Pat
Old Oct 09, 2012, 03:40 PM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Pat
Im the guy named Perry & I hope the 22 is sitting on the front porch when I get home in an hour!!
Old Oct 09, 2012, 03:47 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Ha ha, how funny! I had no idea this was you.
Funny, I just tried checking your tracking number, and the USPS website seems to be having issues. I would have thought it would have been there yesterday. If it doesn't show up today, let me know and I will have a trace done.
Pat
Old Oct 09, 2012, 04:13 PM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Pat
I expected iy yesterday to but the post office was closed so Im sure its there waiting now
Old Oct 09, 2012, 07:42 PM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Evalith8,
You're going to really enjoy flying the F-22. With your 3D skills, I'd go with rudders to take full advantage of this airframe. Definitely, if you're going to do one at 200%-300% larger. The one you're getting from Pat, has a 2.5" larger WS, than the one you saw fly at EOT. That was my scaled down version. If you need a specific size WS, let me know. I can scale up the pdf and tile if need be. Also, as Pat said, RCFoam is the place to go to order foam. Shipped right to your front door. Let me know if you need a hand.
Ksqm
ksqm is offline Find More Posts by ksqm
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
