Old Apr 08, 2012, 10:33 AM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Swimmer,
Yes, the CG is proportional. Divide 14 by 18.8, then multiply by the 18.8" WS's CG. Or just place at the same point you did on the larger plane. You may want to add a tad more expo all around, until you get used to it. This little bird is very nimble at high and low speed. Good Luck on the maiden
Ksqm
ksqm is online now Find More Posts by ksqm
Old Apr 08, 2012, 09:30 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
Originally Posted by ksqm View Post
Swimmer,
Ksqm
Those calculations puts CG at 1.675" and compared with the 18.8 looks correct. My thought is to use 35% expo because I use this when flying my other UM planes. I know expo is relative to the flyer but with your experience with the 14" do you consider beginning with 35% sufficient?
swimmer is offline Find More Posts by swimmer
Old Apr 08, 2012, 10:00 PM
ksqm is online now
Joined Mar 2009
Swimmer,
Should be good!!! I normally go with max deflection on all control surfaces. The plane will flip in it's on length. Keeper light and you'll be amazed what you can do. I think my build was 85g AUW. Should be able to launch at 1/2 throttle. Have fun!!!
Ksqm
Ksqm
Old Apr 10, 2012, 04:16 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Swimmer,
Ksqm
Ksqm
My 14" came out 70g w/o battery. Just waiting for a decent day/evening to maiden it.
Old Apr 10, 2012, 04:18 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Good luck Allan! Let us know how it goes.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Apr 10, 2012, 11:20 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Here is my F22 hanger. A 24", 18.8" and the 14". Tape is on the wings for marking CG. Have yet to maiden the 14" and 24". Will wait for paint until have flown them a while.
Old Apr 12, 2012, 04:14 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Swimmer,
Here you go. I'm also including a couple of pics. This was my "Fly Anywhere" plane. On 2S you can High Alpha and literally fly circles around yourself. On 3S it will "Boot, Scoot, and Boogie" as they say. Enjoy!!! And post pics/vids!!!
Ksqm,
The 1811 is a 2S, 7.4v motor. How long will it last on a 3S, 11.1volts?
Allan
Old Apr 12, 2012, 04:38 PM
ksqm is online now
Joined Mar 2009
Swimmer,
I still have my original 1811 I started with over 2 years ago. An it's getting ready to go into a Micro SR-71!!! Use GWS 4x?? or 4.5x?? props. I had a modified Toxic Toast F-14, about 120g-130g AUW, that I flew into the ground. It's a tough little motor. I used 3S bats from 250mAh to 450mAh. You can do a search to see what builds I've used it on.
Almost forgot. Use a Turnigy Plush 6a ESC. It's 2S also, but the only one I lost was my fault. Crossed uncovered motor leads and smoked it. I use these and nothing else so far.
Ksqm
Old Apr 12, 2012, 05:40 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Which SR are you doing? Or is it a scratch?
Pat
Old Apr 12, 2012, 06:16 PM
ksqm is online now
Joined Mar 2009
Crxmanpat,
Funny you should be asking that. I think it's an early version of jtechlaser's. I've had it cut out for over a year, maybe two. In fact, I was searching an external HD I have plans on to be sure. I wanted to make sure I have the CG right. It's the version that had just the lower cover, but I cut another set for the top. Man time fly's.
I plan to use my standard: HK 1811 2000kV motor, Turnigy Plush 6a ESC, BA 3.xx g Servos, and GWS 4.5x3 prop. Depending on batt, she'll be between 96g-120g and fast. I'm thinking it's 66% scale, about 15" WS. I'll post pics and vid in your thread.
Ksqm
Old Apr 12, 2012, 06:49 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Awesome. Yeah, Jim's and my SR's are pretty much identical, except mine is smaller.
I took the original design by Adam and tweaked it with some of Jim's design techniques.
Pat
Old Apr 12, 2012, 09:54 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Swimmer,
Ksqm
Don't have a 2-3 Cell ESC on hand so ordered one from Heads Up. I'll fly the 14" with the 2 cell ESC and battery I have now to get a feel for how she flies.
Old Apr 13, 2012, 06:50 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
14" Maiden...well, kinda.
Got my 14" out today for the maiden. I don't know if it is my 2S batteries, batteries charged, or motor placement but it just has no power. Did not want to turn right or left well at all. Flight is anemic and only 1-2 feet above ground at most.
Looking at the prop from behind the motor looks a little high so the air flow is not directed equally above and below over the tailerons. Not bad just not perfect. Should I shim it directing more of the air flow equally?
My plane weighs 69g (2.4oz). Motor is the HK 1811. Prop on with writing facing forward.
Anyone have any idea?
Allan
Old Apr 13, 2012, 07:02 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Allan,
You're probably going to have to bump up to a 3S pack. The Hyperion 3S 450 is a great little pack, and I used to use them all the time on the 18.8" version until I bumped up to 850.
http://www.allerc.com/hyperion-g3-cx...ck-p-4504.html
Pat
Old Apr 13, 2012, 07:06 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Allan
I have an 11.5in F-22 (scaled down). It also has some turning problems. Whenever you try to turn left, it starts to bank and then just does a knife edge. If you increase the speed, it snap rolls. The problem was the CG was a bit tail heavy, so that could be your F-22's problem. Add some nose weight, and try again.
Cheese5 is offline Find More Posts by Cheese5
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 10:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 09:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 08:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 11:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 01:01 PM
