Old Mar 19, 2012, 04:30 PM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Swimmer,
I'm using Thunder Power, but the Hyperions are good also. I have them in 450mAh, 550mAh, and 850mAh. They are both rated at 25C.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Mar 20, 2012, 09:26 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
Assembling my 14 inch wingspan F22 and noticed the GWS 4 inch prop is not only too long for the slot, I realize the slot has to be longer, it also sticks past the sidewalls. It has been mentioned to pry the sidewalls apart for prop clearance. Does the prop have to be clipped shorter to stay within the sidewall area?
Oops...let me answer my own question....The prop I used to measure is a GWS 4530. The 4025 will fit the area just fine with just a little pry on the sidewalls.
swimmer is offline Find More Posts by swimmer
Old Mar 20, 2012, 09:59 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
Using the NanoTech 370s. They rock.
Foambird is offline Find More Posts by Foambird
Old Mar 21, 2012, 07:59 AM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Do you have a link for this battery? I'd like to check it out.
Old Mar 21, 2012, 08:59 AM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Here they are:
http://hobbyking.com/hobbyking/store...Lipo_Pack.html
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Mar 21, 2012, 06:20 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Thanks, Pat.
Allan
Old Mar 21, 2012, 09:57 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Originally Posted by swimmer View Post
Thanks, Pat.
Allan
Pat,
I've got several Rhino 3S 610 mah (41g) batteries I use in another foamie. Do you think the 14" could handle this weight?
Allan
Old Mar 22, 2012, 01:04 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Sure, no problem. I use 850-1100 in the 18.8" version, so 610's should be OK.
Pat
Old Mar 22, 2012, 04:59 AM
ksqm is offline
Joined Mar 2009
Gents,
The 610 bat may wind up sitting in the prop slot to balance. It'll be close.
Ksqm
Old Mar 22, 2012, 08:33 AM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Originally Posted by ksqm View Post
Gents,
Ksqm
I'm about to the point in assembly I can check CG. I'll let you know where the 610mah battery has to be placed. No problem getting additional batteries but would like to use what I've got before investing in more.
Old Apr 05, 2012, 08:50 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
F22 Maiden Flight
Just got back from the maiden flight(s) of my 18.8 F22. WOW !!!!!!!!!!! What an amazing airplane!! First hand launch I had way too much power and managed to nose it into a soft wheat field. Minor damage to the nose but nothing major. Broke loose the battery mount but not to be undaunted I taped the battery in and gave it another toss. Less power this time and the F22 with the 3S 800mah battery climbed stately into the blue sky. Once I made a couple circuits got brave and did a full power climb, it would have went out of sight, rolls, loops, power dives and high speed passes were easily accomplished. When ready to land did very soft and slow high alpha landings. To say the least I am impressed for the small investment that gives such a wonderful flying plane. I saw a guy watching from a ways off and he came to look and watch. He was very impressed with the simplicity of the F22 and its speed. Hope I can sleep tonight with this grin on my face. Again...WOW!!!!
Old Apr 05, 2012, 11:45 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Congrats on the maiden!
I never cease to be amazed at how well this little plane flies, and I always get hounded with questions about it at every show. It's my best seller for a reason.
Pat
Old Apr 06, 2012, 04:08 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
It's definitely one of my favorites!
Have you ever tried adding a Kline Fogleman step or two to the wings?
mclarkson is offline Find More Posts by mclarkson
Old Apr 06, 2012, 04:36 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I never have. On these small ones, a KF airfoil probably wouldn't make a noticable difference.
Pat
Old Apr 08, 2012, 07:27 AM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
14" ws cg
I've got my 14" WS F22 about ready to fly but cannot find info on CG. Would it be proportionally the same as the larger models? I'm looking at this model and can't wait to get it out to fly. If it is half as much fun as the 18.8 WS I'm in for a really fun time! Thanks for any info on the CG.
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
