Old Mar 08, 2012, 07:04 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
With the 12" F-22 stability becomes a problem. I made a 12", it has a hard time turning left. It wants to knife edge whenever you bank left. So you have to turn at a higher speed. Also you do loose a lot of thrust since you are limited by the small opening in the fuselage.
Cheese5 is offline Find More Posts by Cheese5
Old Mar 08, 2012, 07:27 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Swimmer,
Here you go. I'm also including a couple of pics. This was my "Fly Anywhere" plane. On 2S you can High Alpha and literally fly circles around yourself. On 3S it will "Boot, Scoot, and Boogie" as they say. Enjoy!!! And post pics/vids!!!
ksqm is online now Find More Posts by ksqm
Last edited by ksqm; Mar 08, 2012 at 07:36 PM. Reason: Added comments to attachments
Old Mar 08, 2012, 08:18 PM
ksqm is online now
Joined Mar 2009
One las thing. 250mAh bats work great. Both 2S and 3S bats fit inside the belly pan.
Ksqm
Old Mar 08, 2012, 10:29 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
Originally Posted by ksqm View Post
Swimmer,
Really appreciate the information, pics and plans. I'll get to it when I finish my 18.8. Looks like a great size to fly in our indoor space and even more outside.
Allan
swimmer is offline Find More Posts by swimmer
Old Mar 08, 2012, 11:33 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Originally Posted by swimmer View Post
Is yours a 18 inch wing span version of the F22 and where did you get your motor?
Allan
Yep - it's the 18" version from Pat. The motor is the PowerUp 250 sport from HeadsUp RC.
You space is small, but I have zoomed mine around in the front yard / street and Google Maps says that's an even smaller space.
On my build, I laid the battery sideways, right across the CG, so I can go with different sizes. 450 3S is the smallest I've run, and it flies fine. Never tried a 2S, but I think I will.
mclarkson is offline Find More Posts by mclarkson
Old Mar 09, 2012, 07:26 AM
segraves is offline
Find More Posts by segraves
Joined Jan 2007
Great flying! Looks like the size I'm looking for. How do I resize tiled drawings?
Smaller: print at a smaller scale
Larger: Not a good idea. It's better to scale the single-sheet plan to the size you want; and then tile it.
Cheers,
Bill Segraves
segraves is offline Find More Posts by segraves
Old Mar 09, 2012, 04:19 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Cheers,
Bill Segraves
Thanks, Bill. I found these settings on my printer. Never seen them before, duh.
Allan
Old Mar 09, 2012, 07:31 PM
segraves is offline
Joined Jan 2007
Allan
You're very welcome.
Cheers,
Bill Segraves
Old Mar 16, 2012, 12:37 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Prop Questions
I'm currently waiting on motor and esc for my 5mm 18 inch wing span F22 and in the preliminary stages of cutting out a 3mm 14 inch wing span.
Are the props standard props or are they actually pusher props?
Old Mar 16, 2012, 12:59 PM
ksqm is online now
Joined Mar 2009
Swimmer,
I generally use GWS EP-4025/4040/4530 props with a prop saver. You can order them most anywhere. They are standard 4" and 4.5" props. Just make sure to have the lettering facing forward.
Ksqm
Old Mar 16, 2012, 03:52 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Swimmer,
Ksqm
My LHS carries these props and both motors I've ordered have prop savers. Used your tiled plans for my 14 inch and all working out great.
I hoping to build enthusiasm for the 14 inch F22 among the guys I fly indoors with weekly and they all will want to build one. Be fun to get a little combat competition going.
Thanks, Ksqm,
Allan
Old Mar 16, 2012, 06:20 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Allan,
I used the GWS 4530 on mine with a Hyperion 3mm prop saver. The hubs on the GWS props are just a tad small for the prop saver, but I ream them out with a 7/32 drill bit for a perfect fit!.
And as ksqm said, numbers always face forward, and check the motor to ensure the prop spins in the correct direction. If not, just switch any two motor-to-ESC wires.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Mar 16, 2012, 09:17 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I noticed the other day that I have my physical linkages set up to medium throws, so I moved things around for maximum insanity. Roll rate is now officially scary.
Old Mar 19, 2012, 02:06 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Ksqm
What brand of batteries are you using in your 14 inch wing span F22?
Allan
Old Mar 19, 2012, 04:04 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Not sure what he uses, but I like Hyperion G3's (and the price is reasonable):
Hyperion 2S 25C
Hyperion 3S 25C
Pat
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
