Old Dec 01, 2011, 02:57 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Mine weighs 5.0 oz FWIW.
mclarkson is offline Find More Posts by mclarkson
Old Dec 01, 2011, 04:09 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by Lockey View Post
Pat, haven’t been able to get my pal to print the vinyl for me yet, so I have made up a mini f22 and covered it with some spare vinyl I had left from the van. It weighed in at 6.3 oz before the vinyl and is now 7.1oz with the vinyl on it … do you think this is a bit heavy??
Lockey
Nope! I took a bare one and put LEDs on it. It went from 6.5oz AUW to 7.5oz AUW and flies just fine!
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Dec 01, 2011, 04:44 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
You guys must be running 800's or 850's in there.
Old Dec 01, 2011, 05:51 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yep. I used to run Hyperion 450's, but I like the added weight of the 850 in the nose. Seems to penetrate a little better and makes the plane a little less squirrely in the wind.
Pat
Old Dec 01, 2011, 07:03 PM
Lockey is offline
Find More Posts by Lockey
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
Depron must weigh in at the same weight … Can only be the setup/power pack? What are you using? And do you have paint or decals etc?
Lockey
Lockey is offline Find More Posts by Lockey
Old Dec 01, 2011, 07:14 PM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Battery
Guys, I use either a 500 or 800 3S battery pack. Flies better with the 800 pack since it is slightly heavier. I use the 1806 BL motor. Has plenty of b__s! Marty
martys is offline Find More Posts by martys
Old Dec 01, 2011, 08:53 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Some guys are using lighter 10g motors and small 320-450 2S packs. I think with my setup and 3S 450 I came in at 5.8oz AUW.
Pat
Old Dec 03, 2011, 09:56 AM
i12flyrc is offline
Find More Posts by i12flyrc
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
Pat
I'm using the lighter motor and a 350mah 2 cell 25C pack. flies great.
i12flyrc is offline Find More Posts by i12flyrc
Old Dec 03, 2011, 02:44 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Lockey
I'm running
  • 17gram Power Up 250 Sport 2400kV motor,
    Hobby King 10A ESC
    Hobby King OrangeRx receiver (with the case removed)
    (2) Tower Pro SG-50 5g servos
    GensAce 450mAh batteries
I've painted some pink polka dots on mine. You know - for camouflage.
Old Dec 03, 2011, 06:28 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Originally Posted by mclarkson View Post
I'm running
    Hobby King 10A ESC
Yeah M! Your girlfriend won't even notice. It blends in with her fingernail and toenail polish! Marty
Old Dec 06, 2011, 02:56 PM
hamid9890 is offline
Find More Posts by hamid9890
Joined Sep 2011
my Experience about f22 depron
hi every one .
i made depro f22 with 65 cm wing span .
look this...
Description: Name: 25112011416.jpg
Description: Name: f-22.JPG
Description:
and look video...
http://www.aparat.com/v/580aea56eef3...09cc2de6676401
good luck.
hamid9890 is offline Find More Posts by hamid9890
Old Dec 06, 2011, 03:07 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Hamid,
Very nice! That was some nice smooth flying.
At 65cm you are actually closer to the size of tomhe's original one that my smaller one at 46cm.
Pat
Old Dec 06, 2011, 03:12 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
F22
Nicely done ham! You will love this airplane. I have more flights on mine than I can count. marty
Old Dec 06, 2011, 03:37 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Ditto! Impressive Work
Looks like a couple of nice flyers to me. Nice work guys.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Dec 23, 2011, 04:47 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Well, I finally broke down and tried an 800mAh 3S on mine (I've been flying 450's).
And, as much as I hate hate hate to add weight to an airplane that already flies well, I have to admit that it flew great with the 800. You can certainly feel the extra weight, especially at low speeds, but it had more oomph and penetrated better. Landings were less floaty but, all-in-all, probably actually easier than with the 450's. The plane has less of a tendency to just stop dead in the air at the wrong moment.
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
