Old Nov 28, 2011, 09:47 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Lockey, looks cool! I've thought about doing something similar with waterslide decals, but have just never got around to it. Looking forward to seeing how yours come out.
Super, yes, that's the only glue I use for my builds.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Nov 28, 2011, 11:23 AM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Vinyl - Can You Get the 3mm Stuff?
Originally Posted by Lockey View Post
I have superimposed the pictures over Pat's plans and I am going to have these printed on self-adhesive (auto type) vinyl, then stick them onto the Depron and then cut out. … this will give a fully pre-finished model once it is assembled. Lockey
The auto and outdoor sign vinyl comes in all sorts of colors and clear, but it also comes in all sorts of thickness. It is heavy stuff, but the 3mm or thinner isn't so bad for planes around 24" wing span. The thin stuff is stretchy, and easy to over stretch when appling. I bought an F-15 kit a while back, but I am having trouble keeping the vinyl stickers attached. I suspect I will have to ensure the surface is very, very flat and free of and bumps and use a spray glue on the foam. It will then be like contact cement, so getting the alignment right the first time may become a challenge. I have been kicking around the idea of printing on the Japanese tissue paper and using the foam safe wood varnish as the glue and moisture resistant coating like others have been doing. It is a tricky business and some printers are a nuisance, but it is also important to use water proof inks. The others tend to run when they get wet. Wish I could remember which thread talked about how to do this.
Tsavah is offline Find More Posts by Tsavah
Old Nov 28, 2011, 08:13 PM
Lockey is online now
Find More Posts by Lockey
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
Yes Tsavah, you are right, I have used the vinyl before and it can be quite tricky.
This is my work van and my friend printed the vinyl for this and we (both of us and our wives) put it on, took all day to do the 2 sides
Lockey
Lockey is online now Find More Posts by Lockey
Old Nov 29, 2011, 07:36 AM
Lockey's Avatar
Joined Sep 2011
I have just done a test run cutting out and putting together a mini F22
MY GOD … its very flimsy has anyone made and flown this one made from 3 mm Depron?? It feels almost like it is TOO weak.
How much extra weight do you recon it would add to make it from 6 mm Depron?
Lockey
Old Nov 29, 2011, 09:08 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Trust me, 3mm is just fine, except make the fuselage top and bottom parts from 6mm. Once it's all glued together it's pretty strong.
Pat
Old Nov 29, 2011, 10:06 AM
Lockey's Avatar
Joined Sep 2011
Yes done that Pat,, maybe should have made the bottom of 6mm too, it feels rather weak
BUT I will take your word for it mate, I guess you have made and flown these before
Cheers
Lockey
Old Nov 29, 2011, 01:25 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yeah, only 25 or so.
I know it feels weak, but trust me that it's not. I plop them down on the ground all the time with no adverse affects.
Pat
Old Nov 29, 2011, 08:35 PM
superinstaller is offline
Find More Posts by superinstaller
superinstaller's Avatar
United States, SC, Greer
Joined May 2006
I would do some 3mm some 6mm for strength. I built one from all 6mm and it still weighs a gram or two from nothing.
superinstaller is offline Find More Posts by superinstaller
Old Nov 29, 2011, 10:10 PM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
if you still scared, then just use fiberglass tape. 6MM will increase you weight.
Cheers
Lockey
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Nov 30, 2011, 07:46 AM
Lockey's Avatar
Joined Sep 2011
Hi Guys, I wonder if anyone can help
I have a Spectrum DX7 and have never (till now) used it with “Delta” settings (aileron/elevator) no matter what I do I can’t make the Ailerons or elevators work properly
When I move the elevator, the ailerons work and when I move the aileron stick the elevators work … is there a setting that I am missing??
I tried it on 3 different RX's and I tried changing the leads round on the RX
Lockey
I have done this on my 9x without any problems
Lockey
PS Mini F22 Just weighed in AUW at 6.3 oz. no paint or decals
Old Nov 30, 2011, 05:18 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Wish I had seen this thread first. Check the Polaris thread, I put the instructions there.
Pat
Old Nov 30, 2011, 07:28 PM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
F22
I built mine out of 3mm depron and have more flights on her than I can count! She looks a little battle worn by now, but flies as good as the day she first flew. Marty
martys is offline Find More Posts by martys
Old Nov 30, 2011, 07:30 PM
martys is offline
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
DX7 manual
Here you go Lockey http://www.spektrumrc.com/Products/S...ProdId=SPM2710
Old Nov 30, 2011, 07:44 PM
Lockey's Avatar
Joined Sep 2011
Sorry Pat, I just thought a lot of guys seem to get on that post so thought I would put it there too
I have fixed it, it was a combination of switches and changing plugs. With the suggestions I had another go and got it to work OK
Lockey
Old Dec 01, 2011, 10:09 AM
Lockey's Avatar
Joined Sep 2011
Pat, haven’t been able to get my pal to print the vinyl for me yet, so I have made up a mini f22 and covered it with some spare vinyl I had left from the van. It weighed in at 6.3 oz before the vinyl and is now 7.1oz with the vinyl on it … do you think this is a bit heavy??
Lockey
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 10:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 09:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 08:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 11:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 01:01 PM
