Old Jan 03, 2008, 05:59 PM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
3mm Depron 18.8 Inch F22 With Plans
Here is my 3mm depron 18.8 F22, it is much like Tomhe's.
The motor i used is this
http://www.hobbycity.com/hobbycity/s...idProduct=5432
I am currently flying it with a 5x3 prop, and a 2 cell 620 pack, im going to try a 3 cell soon.
My AUW is 5.5 oz
This plane flys great slow or fast.
I have added the plans in .pdf, Tiled, and Full.
adbradley is offline Find More Posts by adbradley
Old Jan 06, 2008, 12:20 PM
adbradley's Avatar
Joined Mar 2007
Wow i flew this lil guy yesterday with a 3 cell pack, very fast, and tons of power, im very happy with this motor!
Old Jan 06, 2008, 03:11 PM
adbradley's Avatar
Joined Mar 2007
Here are some pics
Old Jan 07, 2008, 12:07 AM
tomhe is offline
Find More Posts by tomhe
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Nice build! Any chance of a video?
tomhe is offline Find More Posts by tomhe
Old Jan 07, 2008, 12:09 AM
tomhe is offline
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
I see that you had to cut through the side fuselage to fit the 5" propeller. Do you think it would fly on a 4" propeller with that motor?
Old Jan 07, 2008, 06:35 AM
adbradley's Avatar
Joined Mar 2007
The pics are of my first one, and i didnt realize i had made it to narrow for the 5" prop. In the plans that i posted on this thread, the fuse has been widened by 1 inch, so that you dont have to do all of that notching.
As far as the video goes, im going to build another one of these from the updated plans this week, and try to get video of it by the weekend
Old Jan 07, 2008, 07:58 AM
adbradley's Avatar
Joined Mar 2007
also, a 4" prop would work, but i think you would be loosing out on some thrust.. This motor with a 5x3 prop is very impressive on 3s.. on 2s i fly it with a 5x4 prop, and it does well.
Old Mar 01, 2008, 05:10 PM
adbradley's Avatar
Joined Mar 2007
Here is a link to the long anticipated video http://www.rcgroups.com/forums/showa...mentid=1741312
Old Jul 10, 2008, 12:08 PM
adbradley's Avatar
Joined Mar 2007
I got a message from RacerX208, and he said they had used my plans to build a few of these planes from de-papered elmer's 5mm foam board. He asked me to revise the drawing so that the tabs worked with the 5mm board, so here it is. This should fit on a standard 20"x30" sheet of elmers foam board.
This drawing now shows the approximate CG
I added a tiled drawing as well
Old Jul 10, 2008, 12:40 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
EDIT - See Post #941 for the most updated plans!
Kits and Power Packages available for sale at www.nicohobbies.com.
Adam,
I can't believe I never commented on this thread (especially seeing as I did your video! ).
Do you still have this plane? Been a while since we've flown together.
I have #2 of the 100% all cut out and glued together. I got a replacement Grayson motor on the way (should be here tomorrow) so I need to get it painted up and ready to go. I miss this plane.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Jul 10, 2008, 01:23 PM
ac_rite90 is offline
Find More Posts by ac_rite90
up up and away
United States, LA, Concordia Parish
Joined Mar 2008
That f22 flies nice. good job. that size would be a great build. I have that same motor lying around and would like to to put some use to it. I would like to try it would elmers foam board, can you post the plans for elmers board tiled. that would be great. thanks. where is the cog at. I love the f22, they fly real nice. I enjoy flying my 22 inch wingspan epp f22.
ac_rite90 is offline Find More Posts by ac_rite90
Old Jul 10, 2008, 01:58 PM
adbradley's Avatar
Joined Mar 2007
Tiled drawing added Ac_rite
Old Jul 25, 2008, 03:03 PM
RacerX208 is offline
Find More Posts by RacerX208
RacerX208's Avatar
Joined Apr 2004
Adam,
Here is "Build 2" using the 5mm foamboard. Hopefully it will take to the skies this weekend, weather permitting. I laminated the 5mm foam board with clear tape on both sides before airbrushing. The build used the first version of your plans, which called out for 3mm foam.
She is powered by a ELE C20 2900kv motor and a 3S1P 1200mah pack, both from TrueRC.com. For servos, I'm using a couple of 5gram units from Lazertoyz.com. A 4 channel Corona Rx with a Azzar antenna attached rounds it out.
I was going to go with a 5x5 APC prop, but didn't know that their props can only go on one way, so I used a GWS 5 x 4.3. Seems like it has plenty of power though!
www.aatoolbox.no-ip.com
RacerX208 is offline Find More Posts by RacerX208
Old Jul 26, 2008, 03:43 PM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
I'm building one!
Boys I ran across this thread while surfing RC Groups and boy am I hooked!! I downloaded the plans (thanks so much!!) and am shortly about to start cutting out the parts. I just have a couple of questions. Do you think it's OK to build the body/wing out of 6mm and the other parts out of 3mm? I have some 6mm spars so I would like to take advantage of the 6mm foam. Or should I just use one or the other? I plan to use the same motor from hobby city (I have 2) and a 700 Mah li-poly 2 C. I finally found the CG so I'm OK there. What are the throws set to? I also assume I will need mixing ( I have a Futaba 7C computer radio). I am the VP of a club in Southern NJ and I am going to take her to the meeting this month. I would like the Guys in the club to consider your design for a one of a kind design contest. I hope you don't mind Adam. I look forward to your reply. Thanks ahead of time Guys. Marty
martys is offline Find More Posts by martys
Old Jul 26, 2008, 05:34 PM
Vanish is offline
Find More Posts by Vanish
Concept Builder
Vanish's Avatar
United States, CO, Boulder
Joined Feb 2008
I'm not sure what you mean. I use APC 5x5 props on pusher jets all the time.
Vanish is offline Find More Posts by Vanish
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
