Old Dec 20, 2002, 10:01 PM
kbstingwing is offline
Find More Posts by kbstingwing
FLY OR DIE YOU MAGGOT
kbstingwing's Avatar
Vista, Ca
Joined Oct 2002
New spray glue better than 3m super 77
I found a new spray glue, works great, won't melt styro, hold better than super 77, it's called " STICK IT ", it's clear and it can be found at
blowoff.com
try it you'll like it
kbstingwing is offline Find More Posts by kbstingwing
Old Dec 20, 2002, 10:40 PM
ke6guj is offline
Find More Posts by ke6guj
ke6guj's Avatar
Rialto, CA
Joined Jun 2002
Be Careful!!
Just checked the MSDS sheets on the four versions of STICK IT. All contain ACETONE. the ingredient that melts syrofoam.
Depending on the version, 10, 15, or 20% acetone. That is better than 3m-77, 30-40% acetone. Comparable to DURO's spray adhesive at 15-20%.
Still looking for spray adhesive without acetone.
ke6guj is offline Find More Posts by ke6guj
Old Dec 21, 2002, 02:04 PM
Ripley is offline
Find More Posts by Ripley
Don't provoke my wife!
Fort Worth Texas
Joined May 2002
So KBSting, what type of foam did you spray it on that it didn't melt it. Probably EPP. EPP is hard to melt. I"m sure if you sprayed it on EPS it would still melt it. What do you think.
Ripley is offline Find More Posts by Ripley
Old Dec 21, 2002, 03:25 PM
Spaceship13 is offline
Find More Posts by Spaceship13
Just an A&P mechanic
Joined Sep 2002
M-77?
Hey you guys check with Tom Broeski at
tjb@adesigner.com
he has someting thats just as good and dont got no ctone in it.
he will be us distributor in Jan. i looked at tit and it does waht he says it does. its good stuf. big cans too. hehehe:-)
Spaceship13 is offline Find More Posts by Spaceship13
Old Dec 21, 2002, 05:19 PM
Vista, Ca
Joined Oct 2002
stick it
I tested it on styro foam, and epp, it did not melt it, sprayed a large puddle of it and " NO" melting, dried clear too.
Old Dec 21, 2002, 06:16 PM
ke6guj is offline
ke6guj's Avatar
Rialto, CA
Joined Jun 2002
Thanks for doing the melt test for us. Which version are you using?
I've got some old 77 left for styro, and have been using DURO for EPP, but will have to give it a try when the 77 runs out.
Old Dec 21, 2002, 06:21 PM
Ripley is offline
Fort Worth Texas
Joined May 2002
Hey ke6guj, what does that stand for. I hate abbreviations. Be more specific. I have used GHID, GHKO, GHKO, LKDM, does that mean anything to you. What exactly is it that you used. Geez
Old Dec 21, 2002, 06:31 PM
ke6guj is offline
ke6guj's Avatar
Rialto, CA
Joined Jun 2002
KE6GUJ is my Ham Radio callsign. Don't use it anymore, but when I started playing online, I used it, and I have ever since. Don't have to worry about going to a new forum and find out someone else is using my name
What do the above abbreviations mean, never heard of them?
Jack
Old Dec 21, 2002, 06:41 PM
ke6guj is offline
ke6guj's Avatar
Rialto, CA
Joined Jun 2002
Sorry Ripley, first time I read it, I thought you were asking what KE6GUJ stood for. Now I read to mean what does DURO stand for.
DURO is the brand name for a Spray adhesive that some people are using instead of the new 3M-77.
Old Dec 21, 2002, 07:19 PM
Joined Sep 2002
my call sign
hey mine is KG4WNY
Old Dec 22, 2002, 12:06 AM
Vista, Ca
Joined Oct 2002
ke6guj
I'm using the general purpose type, it may contain acetone but so does the old 77, but it does'nt melt styro, I like the strength of it , it sems to hold better than 77, especialy for the covering, no bubbling.
3M Super 77 Spray Adhesive culiv Foamies (Kits) 10 May 22, 2016 04:15 AM
Alert 3M Super 77 Spray Adhesive jimboyzguy The Builders Workshop 27 Apr 10, 2008 02:22 PM
FS: 3M Super 77 Spray Adhesive (old formula) Jeff_Berg Aircraft - Electric - Airplanes (FS/W) 30 Dec 16, 2004 10:28 AM
New 3m Super 77 SmoothSL Foamies (Kits) 32 Oct 17, 2002 06:29 PM
