Old Jan 03, 2008, 02:04 PM
eruji is offline
Find More Posts by eruji
"plane don't hurt"
eruji's Avatar
Mountain Home Village, CA
Joined Aug 2005
Possible use of bit char-g bits and Aerosoarer?
I was reading in the micro sticky above about the use of Bit Char g for planes. Is anyone still doing this?, the article is almost 4 years old!!
I came across an old bit char clone i bought a long time ago. Is it possible to still use this?
I would like to try the BUMP model. but before i get started i wanted to make sure this would still work since its a knockoff char g.
eruji is offline Find More Posts by eruji
Old Jan 03, 2008, 03:43 PM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
You and I might be the only ones playing with these. This area is very trendy and whatever is hot at the moment gets the attention. I just printed out the BUMP and I havent yet found a prop for the M-20 motor I have. From what I have read, if you are not using the BitESC, then you need to add a mosfet to the Rx. They are all very similar in design. I got lucky and picked up a Rx, Tx, actuator, BitESC which already had some work done to it.
HELModels is offline Find More Posts by HELModels
Old Jan 03, 2008, 03:50 PM
eruji is offline
"plane don't hurt"
eruji's Avatar
Joined Aug 2005
Hi HEL, have you successfully built a Bit plane?
by BitESC you mean the RX from the car right? so the RX has an ESC built onto it?
I have an Aerosoarer, Picooz and AeroAce motors/gearboxes at my disposal, would those work with this?
Old Jan 03, 2008, 03:58 PM
gguy is offline
Find More Posts by gguy
I forgot the transmitter!
gguy's Avatar
Tucson Arizona
Joined Oct 2006
yup!
gguy is offline Find More Posts by gguy
Old Jan 03, 2008, 04:33 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Hi,
I've built and flown several bit planes. Since low cost rc planes became available there isn't much use of the bit stuff anymore. I'd recommend doing a conversion of the x-twin/Aero Ace. They are cheap and work well.
If you really want ot do a bit try to find a Crazy Car or one of the other ones that uses a motor for the steering channel, much easier to deal with. You will need to use a lipo battery and I'd recommend the Bump, it's a great design.
mcross is offline Find More Posts by mcross
Old Jan 03, 2008, 04:56 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
I've got a few of these type cars left 10.00 shipped or 3 for 20.00 shipped...pm me
thanks,
David
David Hogue is offline Find More Posts by David Hogue
Old Jan 04, 2008, 04:19 AM
HELModels's Avatar
Joined Aug 2003
I printed out the BUMP plans and have some 1/16 balsa that I will use to build the airframe.
What I mean by BitESC is that there was an add-on ESC someone put together. It alleviates the need to modify the Rx to handle higher amps to a motor. More like 1 amp max With the BitESC. I have an M-20 motor which is typical for this, but need the right prop.
I tested the Tx and Rx with the motor and actuator tonight and it did some weird things. The actuator would flicker back and forth if throttle was not touched, but as long as throttle was hit once in a while it would settle right down. The throttle on ESC seemed totally unresponsive, maybe some effect, but without a prop I cant tell. It should atleast handle the current to the motor is my guess.
These have already been mentioned and I have no experience with them.
Bit Char-G drksyd Cars - Cars and Parts (FS/W) 0 Jan 23, 2003 02:13 PM
Bit char-G cripple capacitor Andrew8 Micro Cars 4 Jan 14, 2003 03:56 PM
Are there any Bit Char-g planes yet? henke Scratchbuilt Indoor and Micro Models 9 Nov 04, 2002 06:48 PM
