Old Jan 02, 2008, 09:23 PM
Slyster is offline
Find More Posts by Slyster
Google 'Blade 400 bible'
Slyster's Avatar
Joined Nov 2006
Largest FP helicopter?
Other than the Honeybee FP and the many similar models.. is there a BIG fixed pitch heli out there? Or are they all small micro sized?
Slyster is offline Find More Posts by Slyster
Old Jan 02, 2008, 09:43 PM
helitaiwan963 is offline
Find More Posts by helitaiwan963
Rave heaven
Chicago surburbanite
Joined Nov 2006
There was the Corona, i think ti's out of production now. Still can find used ones though
helitaiwan963 is offline Find More Posts by helitaiwan963
Old Jan 02, 2008, 10:01 PM
sparkysko is offline
Find More Posts by sparkysko
Unshaven yokel
sparkysko's Avatar
Portland, Oregon
Joined Oct 2007
Make some huge blades, or shim a CP blade, go brushless, and extend the tail boom out a foot or two on the HBFP. It's the anti-moth mod.
sparkysko is offline Find More Posts by sparkysko
Old Jan 02, 2008, 10:07 PM
Slyster is offline
Slyster's Avatar
Joined Nov 2006
So basically.. currently made today.. the HBFP (and the like) are around the largest FP helis one can get?
Just how much harder are CP helis? Can you pretty much go full throttle (or some percentage) and use the collective to 'simulate' an FP while you learn?
Old Jan 02, 2008, 10:55 PM
PLATINUM is offline
Find More Posts by PLATINUM
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
If you have mastered an FP.. then you should try a CP heli. Flying is the same.. what is different you may ask?
a) starts out like your flying FP..
b) at mid stick you click idle up: where the motor runs at full throttle and the pitch of the blades is what you control to go up and down. So at center stick the heli hovers, negative stick the heli is being pushed down.. positive stick and heli goes up.
This allows you to do inverted flight.. so when you roll the heli you put in negative pitch/stick and the heli goes up..
b) the set up, it takes a while to wrap your brain around it and then learn how to tweak it from there.
PLATINUM is offline Find More Posts by PLATINUM
Old Jan 03, 2008, 04:51 AM
Vince Herman is offline
Find More Posts by Vince Herman
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
The larger CP models are easier to fly than the micro FP helis.
More stable in a hover.
Easier to fly outdoor in wind since the head speed does not have to drop so much to descend.
Vince Herman is offline Find More Posts by Vince Herman
Old Jan 03, 2008, 06:34 AM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
There is another thing to idle up that most dont touch on and it wasnt till i had a 450 for a while and flying my king that some one mentioned why it was good to use.
Most people when they mention idle up they always use the inverted or 3D thing and for me i wasnt interested in doing any 3D or inverted so i shyed away from idle up, i didnt feel i was at that level of flying yet. For me it was just an extra switch that i could bump and strip gears, break blades and wreck my heli. I did that many times
Then some one mentioned that when you flip the heli into idle up mode your running the motor up into its power band so that when you increase the pitch by moving the stick up and down you dont get that motor bog/tail jerk thing that you get with FPs. In idle up mode the tail holds better and is more stable. It actualy flys better
It takes some getting use to though. When your use to flying FPs and when you get into a jam you dump the throttle you have to relearn not to do this and to fly out of bad situations.
BowerR64 is offline Find More Posts by BowerR64
Old Jan 03, 2008, 08:33 AM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
Lately, Iíve been thinking about the need for a 450 size FP heli. What I envision is producing sets of FP head parts for 450 size helis. For example, Iím a newbie and I want to start out on a larger FP heli, so I buy a T-Rex 450. I remove the CP head parts from the T-Rex 450 and replace with the FP head parts. When Iím ready to move up to a CP heli, I simply remove the FP head parts and install the original CP head parts.
My wife is a senior manager for a company that sells plastic injection molding equipment. She has many contacts with plastic parts manufacturers who could produce these parts. I also have a friend who owns a business which manufacturers plastic parts for the automotive industry.
I have the contacts and resources to get this done, Iím just wondering about the demand. What do you guys think?
racin06 is offline Find More Posts by racin06
Old Jan 03, 2008, 10:11 AM
Flipper_118 is offline
Find More Posts by Flipper_118
Flying on Flux Capacitors
Flipper_118's Avatar
Edmonton, AB
Joined Apr 2005
racin06,
I am fairly sure most people use radios that allow you to mix the throttle and pitch curves to simulate a FP head for a CP heli...unless you are trying to simplify the head therfore keep crash costs down...
Curt
PS - <---- That heli is FP...fully upgraded corona...will lift a 8oz camera without batting an eye.
Flipper_118 is offline Find More Posts by Flipper_118
Old Jan 03, 2008, 10:23 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
My old beater LMH 100 is 24 in. rotor span so don't know if it qualifies. I don't know the rotor span of the Honeybee. Works good for a 12 yr. old.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jan 03, 2008, 03:59 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
That's not necessarily true. The affect you are talking about is due to running different pitch and throttle curves in Idle Up (for lower pitch and higher throttle, the same lift at higher head speed) Idle up doesn't always change the curves, and with a decent transmitter you can set the curves any way you want in any flight mode.
What Idle up does is keep the motor running when the throttle is below half stick, so you have to use throttle hold to stop it.
Higher head speed makes a heli more stable and more responsive, and generally better to fly - it also makes it a lot more expensive to crash - and THAT'S why FPs are good for beginners, not because they are easier to fly but because they don't break as often.
That would be really useful. I would suggest you design something to fit the Blade400, because it's much cheaper than the TRex and a lot of newbies are going to buy one and crash it. If you could offer them a crash kit for the same or less than the official one, that will reduce the cost of their other crashes you'll be very popular.
There was a thread about it recently, the people who were enthusiastic were mostly experienced pilots who have seen too many 'I've just broken my new RTF CP heli' posts...
EDIT: here it is
http://www.rcgroups.com/forums/showthread.php?t=774690
RobinBennett is offline Find More Posts by RobinBennett
Old Jan 03, 2008, 05:42 PM
Vario3 is offline
Find More Posts by Vario3
Vario3's Avatar
Southeast PA
Joined Oct 2005
Sounds good. Check what Robin sez about the Blade 400. ALSO! Be carefull and test the parts well. They are small, and the bigger size and weight will put additional strains on these parts. It's just not plain black plastic. You might want to find out the formula the heli manufacturers use and copy it. You will need to make blades too.
Vario3 is offline Find More Posts by Vario3
Old Jan 04, 2008, 12:32 AM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Most arnt at the stage they have their own transmitter though. Every RTF heli ive flow does this with out idle up.
Old Jan 04, 2008, 01:38 PM
Sussex, UK
Joined Jun 2004
That's a fair point, I was just being pedantic ;-)
FWIW, it might be easier to make the FP parts from aluminium - there are plenty of CNC firms that just need a good CAD drawing for a small production run.
I thought the PlasticBlades were originally made on a rapid-prototyping machine, so it should be possible to make them from plastic.
Old Jan 04, 2008, 02:24 PM
PLATINUM is offline
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
hmm.. an FP 450..
A full cnc head for existing FPs would be great.. market already exists.. you don't have to reinvent the wheel.
Currently there is no USA producer of a belt tail mod for the existing motor tail helis. Be nice to order these and parts in the USA. I would think you would get more orders for this.. than a 450 FP head.
Lastly .. there are certianly more FP trainers out there than 450s..
Question Hidden Upgrade on HBII FP Helicopter? ritzheli Micro Helis 0 May 26, 2006 07:43 AM
Question is it possible to get a compleat aluminum head assembly for a fp helicopter helli crashed Micro Helis 1 Sep 25, 2005 03:50 PM
FS : blinged brushless HB1 FP helicopter avance_x Aircraft - Electric - Helis (FS/W) 4 Apr 29, 2005 10:36 PM
Best FP Helicopter for Newbie... ESR Micro Helis 10 Nov 29, 2004 08:26 AM
FS: NIB Hornet FP Helicopter Hooters Driver Aircraft - Electric - Helis (FS/W) 4 Oct 18, 2004 05:59 PM
