Old Jan 05, 2008, 05:08 PM
squidbait is offline
Find More Posts by squidbait
Zzzt! Buzz! Click!
squidbait's Avatar
State of Confusion
Joined Jan 2004
Originally Posted by squidbait
It would cost exactly 2 MN-48 servos more and a 20A higher ESC. The E-Flite J3 (which I have and love!) takes 4 servos, a Power 25 and a 40A ESC and 3s lipo - same as the wheeled Beaver, except the Beav recommends a 60A ESC.
The Float version would be more still, an extra $10 for the Power 32 over the Power 25, and another $40 for the 4s over the 3s lipo... plus the cost of floats.
OK.... not sure what I was smoking when I wrote that.... somehow I read that to read "how much more would it cost than the Cub...?"
Ah well. The Cub is a fantastic plane, and I get a lot of enjoyment out of it. I just wish it had a) been a bit more crash-resistant; and b) had foam on the back of the firewall so that the motor-mount bolts hadn't speared my lipo when it did crash
squidbait is offline Find More Posts by squidbait
Old Jan 05, 2008, 05:18 PM
countrygentleman is offline
Find More Posts by countrygentleman
Ustabee supported Unabomber
countrygentleman's Avatar
Joined Sep 2006
Does the Beaver use standard or micro sized servos?
countrygentleman is offline Find More Posts by countrygentleman
Old Jan 05, 2008, 05:53 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Mid size - these:
http://www.horizonhobby.com/Products...rodId=JSP20040
Old Jan 05, 2008, 09:44 PM
Joined Sep 2006
Is that equal to an HS-55 or slightly bigger? If bigger, is it equal to the servos that come with the Spektrum DX7? I believe those are standard sized. I don't want to have to blow another $120 on servos.
Old Jan 05, 2008, 09:50 PM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
HS55s are considered Sub Micro servos
MN48s are minis, thus larger and stronger torque-wise.
Specs for MN48:
Specs
* Type:Mini
* Torque:48 oz/in @ 4.8V
* Speed:.18/60 @ 4.8v, .15/60 @ 6v
* Dimensions (WxLxH):0.58 x 1.30 x 1.02
* Weight:0.8 oz
* Bearing:Ball bearing output
* Application:20- to 40-size Aircraft
Specs for HS55:
* Torque:15.27 / 18.05 oz.in (4.8v/6v) 1.1 / 1.3 kg.cm
* Speed:0.17 / 0.14 sec @ 60deg.
* Dimensions (WxLxH):0.89" x 0.45" x 0.94"
* Weight:0.28oz (8.00g)
* Bearing:None
* Motor Type:Coreless
Bajora is online now Find More Posts by Bajora
Old Jan 05, 2008, 09:53 PM
Joined Sep 2006
Thanks BARNESJONR. Do you think standard servos would work?
Old Jan 05, 2008, 09:57 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
They likely would - with modification (full size will be larger and the trays will need modified). And of course the weight penalty.
Old Jan 05, 2008, 09:58 PM
Joined Sep 2006
I'm thinking the ailerons and flaps would take the standards and then get some mini's for the rudder and elevator. As for weight, I'll go the Power 32 route on 4s so those several extra ounces shouldn't be too bad.
Old Jan 06, 2008, 12:03 AM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
John, I guess I'm a little confused. If you need to make video of the plane on floats and all your lakes are frozen, why not take some company funded trip to say southern CA. and find a lake? I betcha it's warm enough down there? You could do a little vacation time and do some "marketing."
Well, I ordered mine up through the LHS. I didn't want to miss out. I also ordered the floats and the ESC too. That'll get my wallet started. I'll order the remaining stuff in a couple weeks..
Dora Nine is offline Find More Posts by Dora Nine
Old Jan 06, 2008, 12:16 AM
AA6JB
Bajora's Avatar
Joined Sep 2004
Hey John, if they were down there right now, the winds would blow them all the back home probably!
The West Coast is quite the mess right now. The weather is so bad we cannot get out and fly! And to add insult to injury, just when you accept it and decide it won't be so bad to stay home and work on building some projects ... POOF ... the power goes out and stays out for 24 hours!!
Hey Countrygentlemen ... my opinion is that standards would probably be too large, extra weight and just overkill all the way around?
Old Jan 06, 2008, 09:21 AM
P-51C is offline
Find More Posts by P-51C
Reserved Parking
P-51C's Avatar
Joined Jun 2004
If the plane is similar to the cub as far as servo requirements, the Hitec 225 should be a good choice.
I like the marketing trip idea. I think the plane should be in a natural setting like a beach in the Florida Keys. I'll be happy to tag along as an impartial test flier and photographer...
P-51C is offline Find More Posts by P-51C
Old Jan 06, 2008, 09:24 AM
John Redman is offline
Find More Posts by John Redman
John Redman's Avatar
United States, CA, Lancaster
Joined Oct 2005
A company funded trip to Souhtern California would be great, I could see some old friends and enjoy the land of opportunity again. I like the way you think D9, come run our company so I can get some good R & R.
Standard size servos will be a bit big and I am not sure they will fit in the wing. You could enlarge the holes in the fuselage to accept them if you so wanted, but the wings, I would suggest staying with a mid sized servo for ease of installation. Hitec HS 225's or HS-85's would do the job if you don't want to use the JR Sport servos. I believe they are very close to the same price, check them out and see.
John
John Redman is offline Find More Posts by John Redman
Old Jan 06, 2008, 09:41 AM
Tom Smith is online now
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
John, you could save your company the trip mone to send you to California and just send the Beaver to me along with the floats and I would gladly video it for you here in sunny Florida. Just trying to be helpful. Tom
Tom Smith is online now Find More Posts by Tom Smith
Old Jan 06, 2008, 10:01 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Ok, well add another kit to the list.. Man.. I've got to slow down..
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 06, 2008, 01:38 PM
N726AC is offline
Find More Posts by N726AC
N726AC's Avatar
Joined Apr 2004
Hey John! I am futher south than Tom, I'll even find ya a place to sleep. Oh, BTW, there is a nice pond in my back yard and a runway in the front yard!!
And N905JR ??? Juliet Romeo AKA John Redman ??
N726AC is offline Find More Posts by N726AC
Discussion E-Flite Six-Series Brushless?? finishman2000 Power Systems 8 Jan 25, 2009 05:58 PM
Sold E-Flite Six Series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 4 Nov 24, 2006 09:04 AM
Discussion E-Flite 'Six Series' for Trex? JustPlaneChris Mini Helis 2 Oct 30, 2006 04:53 PM
For Sale E-Flite Six series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 0 Jul 31, 2006 05:13 PM
For Sale E-Flite Six series outrunner 2000Kv NIB Red Aircraft - Electric - Power Systems (FS/W) 0 May 17, 2006 12:40 PM
