Old Mar 15, 2008, 05:48 PM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Originally Posted by #1Crash Tester
I'm on the way to my not so local Hobby shop 50 mile drive to get my Beaver. I had one on order at hobby Zone but canceled the order, don't want to wait till April.
Too bad the local Hobby shop here is worthless! I don't know how they stay in business!
Glen
I hear yeah I have to drive about an hour to a good LHS myself. I have couple small ones near me that'll order pretty much whatever I want. As for things in stock, yeah not so much. Good luck with your plane. I'm pretty certain you are going to like it. I know I like mine.
Dora Nine is offline Find More Posts by Dora Nine
Old Mar 15, 2008, 06:05 PM
Iflyrc_vic is offline
Find More Posts by Iflyrc_vic
Iflyrc_vic's Avatar
USA
Joined Dec 2004
BIG Motor
Squidbait,
I think you are right. I was not pleased with my number crunching for flight duration which turned out to be 5 minutes or less. I ordered a smaller motor - Power 32 equivalent.
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Mar 15, 2008, 06:41 PM
no stick is offline
Find More Posts by no stick
Ohio
Joined May 2003
3 position servo flaps
I thought I would pass on a tip for setting up three position flaps up on a DX-7 and AR7000 Rx. Flap movement half way down listed in the manual is 1/2 inch travel and full down should be 1 3/8 inch. In order to get the correct throw measurements I set my servo center at half way down flaps or 1/2 inch. The up flaps and full down flaps positions were then set using end point adjustment or travel adjustment of 33% up flaps and 45% down. I then realized I had to rebind the Tx/Rx with the flaps in up position with the new travel adjustment.
Ed
no stick is offline Find More Posts by no stick
Old Mar 15, 2008, 08:58 PM
Dora Nine's Avatar
United States, NH
Joined May 2005
Making progress...
Well I've made it to about as far as I can go without servos. Hopefully they will come in early next week.
Old Mar 15, 2008, 09:06 PM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
Dora Nine
Don't forget the piece of trim tape over the top center seam in the wing.
Is there any detail molded into the floats, or are they just smooth?
One Six Right is offline Find More Posts by One Six Right
Old Mar 15, 2008, 09:12 PM
Millsdo is offline
Find More Posts by Millsdo
Millsdo's Avatar
Arlington, TN
Joined May 2007
Awesome work Nine...looks VERY nice.
Millsdo is offline Find More Posts by Millsdo
Old Mar 15, 2008, 09:39 PM
Dora Nine's Avatar
United States, NH
Joined May 2005
Wings aren't glued yet because I don't have servos. The floats are just smooth fiberglass.
And actually as a suggestion to Mr. Redman, It'd be nice to have small piece of each of the colors of Ultra Coat with each kit. I'd like some of the red to cover the gear plugs. But I'm not going to buy an entire roll of trim when I only need about three square inches. My Beaver is going to be a float plane only.
Old Mar 15, 2008, 10:57 PM
Mopar92 is offline
Find More Posts by Mopar92
Motorized lawn dart
Mopar92's Avatar
United States, MS, Columbia
Joined Nov 2003
How are you all getting them when the site shows April???
Mopar92 is offline Find More Posts by Mopar92
Old Mar 15, 2008, 10:59 PM
squidbait is offline
Find More Posts by squidbait
Zzzt! Buzz! Click!
squidbait's Avatar
State of Confusion
Joined Jan 2004
If you'll read back a few posts, you'll discover that Horizon Hobbies supplies it's dealers first, before selling direct from their website.
Most of the guys who have them here have picked them up from their LHS's.
squidbait is offline Find More Posts by squidbait
Old Mar 15, 2008, 11:06 PM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Looks GREAT John! Man oh man, I can't wait for the videos and in-flight photos to start showing up.
Bajora is offline Find More Posts by Bajora
Old Mar 15, 2008, 11:15 PM
another MONSTER ?
Valencia, CA
Originally Posted by Iflyrc_vic
Squidbait,
What motor did you go with?
thanks, Gary
Old Mar 15, 2008, 11:21 PM
another MONSTER ?
Valencia, CA
Oops, never mind. I guess you know the trim piece is included.
Old Mar 15, 2008, 11:56 PM
moogly is offline
Find More Posts by moogly
moogly's Avatar
Joined Jun 2006
well I bought a beaver and i'm planing on running this motor with 2 2250mah in parrellel do you think this will fit the bill or is it to big
Model: TR42-50A
Max efficiency :38A
Max Load : 43A
Kv : 700
Power: 720W
Weight : 195gr
Pull/Thrust : 900~2100gr
Prop size: 11x5.5 or 12x8
Voltage Range: 9~15v
No Load Current : 3.4A
Shaft: 5mm
Resistance: 0.0327ohms
Max Efficiency: 82%
Power equivalent : .30 to .40 glow engine
Manufacturer recommends 11 x 5.5 or 12 x 8 props.
Ideal for planes up to 5lbs (1~21.kg) in weight.
Mount holes are 25mm apart and take 3mm screws.
Similar to E-flight Power 32
moogly is offline Find More Posts by moogly
Old Mar 16, 2008, 12:15 AM
gwong is offline
Find More Posts by gwong
gwong's Avatar
Vancouver, B.C., Canada
Joined Sep 2003
Hi Moogly,
I am thinking about ordering the same motor from Hobbycity.com, if it's equivalent to the Power 32 setup it calls for 4S lipos.
Please let the group know how this motor performs with your setup.
Cheers,
Gord.
gwong is offline Find More Posts by gwong
Old Mar 16, 2008, 01:17 AM
Mopar92 is offline
Motorized lawn dart
Mopar92's Avatar
Joined Nov 2003
Got it...thanks
Discussion E-Flite Six-Series Brushless?? finishman2000 Power Systems 8 Jan 25, 2009 05:58 PM
Sold E-Flite Six Series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 4 Nov 24, 2006 09:04 AM
Discussion E-Flite 'Six Series' for Trex? JustPlaneChris Mini Helis 2 Oct 30, 2006 04:53 PM
For Sale E-Flite Six series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 0 Jul 31, 2006 05:13 PM
For Sale E-Flite Six series outrunner 2000Kv NIB Red Aircraft - Electric - Power Systems (FS/W) 0 May 17, 2006 12:40 PM
