Power Setup
I have a strong motor I am using in a 7.5 lb plane (HXT-50-52B). This motor is rated at 480Kv, 50A, and 300g. It is a big motor that I use with a 6S2P 22volt setup and draws over 800 watts with a 12 x 7 3-blade prop.
I plan to use this motor in a 6S2P setup (2 3S1Ps 2200mah in series) with a smaller prop to get about 600 watts in. Is this too much motor for this plane? Any thoughts? |
I just waited about 15 minutes and the rain broke again. That's when I maidened mine. The plane does like to weather vane into the wind. So be mindful of that. Good luck on yours. Maybe next weekend you can come up to my field and we can fly together. Joe |
The Power 25 weighs about 200G, so you might be able to get away with it. Joe |
Too bad the local Hobby shop here is worthless! I don't know how they stay in business! Glen |
United States, TX, Kerrville
Joined Oct 2003
My 4S1Ps Fit!
Finally got the fuse out of the box and trial-fitted my True RC 4-cell 4,000 MAh
battery. I have to slide it to the rear , lower the front and then slide it forward into the "cage" but there's plenty of room for it. Lots of space to move it back and forth to adjust the CG. CR |
Joined Oct 2003
Assembly Sequence?
So I'm looking at the assembly manual. It wants the LG put on first then the motor and ESC, then the cowl......
I don't like the idea of adding all that weight to the fuse before I have the tail glued on. Methinks I'll do the wing servos first, join the wings and install them, then do the tail. Work on the fuse can wait. How are you others doing it? CR |
Made it back from the hobby shop with my Beaver and everything needed for the 25 motor. Got a good deal on a Thunder Power 3300mAh extreme series.Total: $633.0
Also ordered a Spektrum DX6 with the AR6200 recever. This is my first ARF so I'll get some help from my friend at the RC club. Glen |
the recommended 13x6.5 prop on a 4s 4200 pack will give about 5 minutes at WOT... your setup will give about 2. Now, since you're going to be cruising at less than WOT, YMMV... but I still think it's the wrong setup for this plane. |
| Thread Tools | |
| Discussion E-Flite Six-Series Brushless?? | finishman2000 | Power Systems | 8 | Jan 25, 2009 05:58 PM |
| Sold E-Flite Six Series 2700KV | Dora Nine | Aircraft - Electric - Power Systems (FS/W) | 4 | Nov 24, 2006 09:04 AM |
| Discussion E-Flite 'Six Series' for Trex? | JustPlaneChris | Mini Helis | 2 | Oct 30, 2006 04:53 PM |
| For Sale E-Flite Six series 2700KV | Dora Nine | Aircraft - Electric - Power Systems (FS/W) | 0 | Jul 31, 2006 05:13 PM |
| For Sale E-Flite Six series outrunner 2000Kv NIB | Red | Aircraft - Electric - Power Systems (FS/W) | 0 | May 17, 2006 12:40 PM |
