Old Oct 10, 2012, 06:02 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Depends on the prop and batt combo. But the answer is likely yes.
Play around with the flight calc linked above and figure out the best setup, otherwise you're going to be depending on someone else to figure things out for ya, and who knows, I might not have any idea what I'm doing!
Josh
jgalexander is offline Find More Posts by jgalexander
Old Oct 10, 2012, 07:03 PM
CurrentDude is offline
Find More Posts by CurrentDude
Flying is Electrifying
United Kingdom, England, Macclesfield
Joined Jun 2011
Originally Posted by hobbiconexstar View Post
hey will a castle creastions 50 amp esc work for a power 32?
Eflight Power 32 motor is 800 watts. I know from experience that their motors are more powerful than specs suggest. Even HZ recommends using 60A ESC. but I use 75A ESC. It's better to go slightly above the recommended ampere ESC but not a good idea to go less than recommended size.
You may be lucky and get away with a 50A ESC but that's a big risk IMO. Remember, if you crash a model because of ESC failure then it'd be a big loss + your building time. I think it's not worth the gamble.
HTH
Cheers
CurrentDude is offline Find More Posts by CurrentDude
Old Oct 10, 2012, 07:14 PM
Joined Apr 2010
Well, it really depends on the setup. A 12x8x3 on 3s only draws 38A. Doesn't seem like a big risk to me. Conversely, a 13x6.5 on 4s draws 52A - a little more iffy.
Josh
Old Oct 10, 2012, 08:26 PM
hobbiconexstar is offline
Find More Posts by hobbiconexstar
SMASH AND DASH :)
hobbiconexstar's Avatar
United States, ME, Bangor
Joined Feb 2011
ok Thanks' do you guys think that I would be better off to use the himaz motor?
hobbiconexstar is offline Find More Posts by hobbiconexstar
Old Oct 10, 2012, 08:37 PM
Joined Apr 2010
Both will work. It's up to you.
http://www.ecalc.ch/motorcalc_e.htm?castle%29:
Click it. Try different setups. Learn. Come back and ask questions.
Old Oct 10, 2012, 10:40 PM
SMASH AND DASH :)
Joined Feb 2011
ok what do you think that I should use for a battery? He said that with that motor he used 3s 5000 mah, but were I am going to use a power 32 then what battery?
Old Oct 11, 2012, 03:19 PM
SMASH AND DASH :)
Joined Feb 2011
Old Oct 11, 2012, 03:21 PM
Joined Apr 2010
Put in some work - try different setups here: http://www.ecalc.ch/motorcalc_e.htm?castle%29:
Then come back and ask questions.
J
Old Oct 11, 2012, 03:36 PM
SMASH AND DASH :)
Joined Feb 2011
how do i use it?
Old Oct 11, 2012, 04:12 PM
Joined Apr 2010
Good Q. Start at the top an work your way down. Plug is your battery mAh & C rating, then the number of cells. Choose an esc amp rating. Choose your motor brand, then pick the motor model. Finally, choose a prop size. Then check the results. Amps, watts, motor temp, prop pitch speed, and static thrust are all important.
If you have more Q's feel free to ask.
J
Old Oct 12, 2012, 10:07 PM
SMASH AND DASH :)
Joined Feb 2011
ok I figured it out FINALLY! Thank-you So what do you guys think, should I leave the power 32 in it or should I take it out and put in the Himax?
Old Oct 12, 2012, 10:37 PM
Joined Apr 2010
Good deal I think the main difference between the two is their kv, which means your choice will likely depend on whether you want to run 3s or 4s batts. Both motors are about the same size and can handle loads of power. The Himax is geared more towards 3s batts, and the E-Flite is more for 4s (unless you want to run a three-blade with lots of pitch - like a 12x8x3 on 3s).
Hope that helps,
Josh
Old Oct 12, 2012, 10:39 PM
SMASH AND DASH :)
Joined Feb 2011
I was thinking about getting a 3 blade prop to make it more scale but then will I have to use a 3s?
Old Oct 12, 2012, 10:49 PM
Joined Apr 2010
Nope, not necessarily. Pull up the calc and try this: your power 32 with 4s, 50a esc, and a 12x6x3 electric prop and see what you get.
Old Oct 12, 2012, 10:58 PM
SMASH AND DASH :)
Joined Feb 2011
it says that It will be voltage:10.62
Rated voltage 11.1 v
sound right?
Discussion E-Flite Six-Series Brushless?? finishman2000 Power Systems 8 Jan 25, 2009 06:58 PM
Sold E-Flite Six Series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 4 Nov 24, 2006 10:04 AM
Discussion E-Flite 'Six Series' for Trex? JustPlaneChris Mini Helis 2 Oct 30, 2006 05:53 PM
For Sale E-Flite Six series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 0 Jul 31, 2006 06:13 PM
For Sale E-Flite Six series outrunner 2000Kv NIB Red Aircraft - Electric - Power Systems (FS/W) 0 May 17, 2006 01:40 PM
