Old Jan 29, 2012, 05:48 PM
Lunchbox is offline
Find More Posts by Lunchbox
Lunchbox's Avatar
Pleasant Grove, Utah
Joined Jan 2007
After having the plane for over 2 years, I finally got it finished up and took it out for its maiden flight today! The first takeoff was ugly and all over the place, I ended up maxing out my trim which now I need to adjust before the next flight day. Plenty of power! Once I got it to cruise it flew pretty nice. A lot different than the other planes I am used to. Is it super touchy to anyone else? I have all the throws on low rate and it is super responsive! I threw in 25% AIL to RUD mix and I might go a little more on that. I have the trim on the elevator up as much as I'm allowed along with as far right as I can so I'll have to fix those before the next time. I am thinking of getting bigger tires for it as well. The first flight I flew it without and flaps to elevator mix and that was a pain! I have the mix for that spot on now and flies much better with flaps. My problem is though, I have a bad tendency to bring it in faster than I probably should. I'm just too nervous about stalling it! As far as the ESC goes, I have on major concern on that. It doesn't give much of a warning before the battery gets too low, and when it does it's "wee-wee-wee" noise, its VERY quiet! How do you guys deal with that? I did 4 landings total with the one battery. That's pretty much the whole flight report for today! Hopefully next time, it will be clear blue skies! I am including a picture and some videos (which aren't great quality). Thanks to everyone for the help, this plane is finally flying!
Me with the plane before the flight (Just in case it doesn't come back in one piece)
First Take Off
http://s225.photobucket.com/albums/d...rstTakeoff.mp4
Low flyby
http://s225.photobucket.com/albums/d...rent=Flyby.mp4
Second Take Off
http://s225.photobucket.com/albums/d...2ndtakeoff.mp4
Lunchbox is offline Find More Posts by Lunchbox
Old Jan 29, 2012, 06:47 PM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
1st.......on a plane this size I highly recommend you do NOT fly to the cut off; but use a timer, starting low & checking how many maH you put back in. Work up to about 75 - 80% usage. Batteries will last MUCH longer.
Yeah mine was twitchy first flight; but I needed a lot of down elevator.
In the photo it seems the stab may not be quite parallel to wings,though the pic is a hair off straight on.
DavidN is offline Find More Posts by DavidN
Old Jan 30, 2012, 05:10 AM
CurrentDude is offline
Find More Posts by CurrentDude
Flying is Electrifying
United Kingdom, England, Macclesfield
Joined Jun 2011
Congrat Lunchbox for getting a successful maiden. 2 years was worth waiting for
+1 from here on both points.
You also need to remember that LiPos make nose dive when you reach approx 30% - you'll have a disaster waiting to happen. So it can become a loose-loose situation (unless you enjoy frequent repairing)
Enjoy flying
Cheers
CurrentDude is offline Find More Posts by CurrentDude
Old Jan 30, 2012, 09:51 AM
NDPilot is offline
Find More Posts by NDPilot
Fargo, North Dakota
Joined Feb 2011
Good job on the maiden Lunchbox. I'm sure you'll get the throws and trim dialed in. I have Dubro 5-inch Tundra Tires (Tower Hobbies) on mine which are pretty cool although they do add quite a bit of weight compared to the stock tires.
NDPilot is offline Find More Posts by NDPilot
Old Jan 30, 2012, 11:55 AM
Doug Bartley is online now
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I'd recommend you use your radio to its full advantage! Use 30% Expo on all surfaces on low rates, 35 to 40% on high rates. High rate while on wheels are probably never needed from the two I've seen fly. They where both very touchy fliers without being tamed by expo. High rates also caused severe tip stall if speed was allowed to drop off.
I would aslo use no more than 15% aileron to rudder, another area where too much rudder can cause a stall. FWIW Doug B
Doug Bartley is online now Find More Posts by Doug Bartley
Old Jan 30, 2012, 12:40 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
It is a scale taildrager and it will require attention on take off to not ground loop.
Set the push rod for the tail wheel as close in on the servo as possible, Makes it track easier.
be sure the tail wheel and rudder are ligned up so that it will taxi straight
Should not be twitchie in flight, very stable
Use throttle for landing, hold a little up elevator with flaps down and then reduce throttle to touch down. It is difficult to do a full power off landing.
Not a trainer so do not try to fly to slow, Flaps down it will slow down very well but you have to be aware of what it is doing. Go to far and it will tip stall.
If your elevator is a bit out of aligne you will still be ok, it will only show up in loops where it will not traack perfectly.
Dennis
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Feb 02, 2012, 10:32 AM
brunom15 is offline
Find More Posts by brunom15
Joined Sep 2006
I agree:
1. Use a timer and don't fly to lipo cutoff, or near. This plane does not float. If you do lose power dead stick straight in, no turns, easy on the up elevator, no flaps. Ask me how I know.
2. I tamed twitchy ground handling by turning the clevis upside down at the servo (to clear the servo output shaft bearing housing), and drilling a new hole in the servo arm as close as possible to the center of the servo arm while still maintaining clearance. Combined with 30% expo that completely cured my ground handling issues.
Regards,
Bruno
brunom15 is offline Find More Posts by brunom15
Old Feb 04, 2012, 08:41 PM
racer7696 is offline
Find More Posts by racer7696
Joined Oct 2009
Power 32 on floats. NEED MOTOR SUGGESTIONS
Hello guys I have the beaver on flots and I really like this plane.However maybe its just me but I think with the power 32 and a cc 60 amp esc with a 13-6.5-6 prop she could use a little more. I have higher end hyperion bats so i dont think the problem is there. My seems to cruise at 7/8 power if you fly it much slower it has some nasty tip stall tendencies. I know its a scale plane and im not looking to fly it like a jet. I am interested in a axi motor can anyone reccomend me one for the 60 amp esc 13 -14 inch prop on 4s power.I am just interested in axi motors i know ther eare others out there that are good to but always wanted to try axi so now is the tie
racer7696 is offline Find More Posts by racer7696
Old Feb 05, 2012, 08:35 AM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
I fly mine on the Power 32 and floats using an Eflite Pro60 ESC and I have no power issues. Cruises just at about 50-60% power, climbs full throttle VERY steep. Full loops from level with no issues. I am using an APC 13 x 6.5.
You may want to check your watt meter. I had "new" batteries that I did not store charge, and after one season, they were bad. 30% less power which can make your plane feel like a dog at the high end.
See if you are pulling 750-800 watts before you change your motor, cause it may be your battery.
tclaridge is offline Find More Posts by tclaridge
Old Feb 15, 2012, 02:22 PM
Edjahar42 is offline
Find More Posts by Edjahar42
Jasper, Texas
Joined Jan 2010
read all 240 pages
Been looking at this plane since it came out at $150.00
Just took delivery from HH at $250.00 including the once free cockpit kit.
This thread has been interesting, could have been much shorter without all the arguing and off subject posts.
Some of you guys who've been on here all along were very helpful, I've started a log of good build tips and add-ons.
jgalexander, I'd like to hear from you on your Seniorita, I'm flying my second one now and wondering if I should float it as a float trainer?
Edjahar42 is offline Find More Posts by Edjahar42
Old Feb 15, 2012, 03:08 PM
Dennis C is offline
Dennis C's Avatar
Joined Jun 2004
It will be a little heavier and require more attention on the floats.
I have been flying mine on floats and really enjoy it.It is not a trainer, and requires some skill. If you understand and respect what it can do it is just great. Get it slow get the nose up, or hold the nose up in a turn and it will make you an unhappy person.
It will go slow with the flaps, but not slow like a light weight 3D airplane,
If you are comfortable on wheels then you should be ok with the floats, if you are getting some stalls and recovering maybe not quite yet.
Dennis
Old Feb 15, 2012, 05:15 PM
Jasper, Texas
Joined Jan 2010
Thanks Dennis, you've been one of the helpful contributors on this thread, glad you're still around.
Ed
Old Feb 16, 2012, 12:40 AM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Congrats on the new bird! What's a seņorita?
Josh
By the way, my float trainer? Hobbyzone Cub on floats. Big fun
jgalexander is offline Find More Posts by jgalexander
Old Feb 16, 2012, 01:45 PM
Joined Nov 2005
And remember to keep at least 1/4 throttle with floats and full flaps. Then I ease off the throttle slowly as I kiss the water because you don't want to dump the prop in the water.
Old Feb 16, 2012, 05:20 PM
Jasper, Texas
Joined Jan 2010
Sorry jgalexander I confused your name with someone else.
Thanx for the tip tclaridge
Discussion E-Flite Six-Series Brushless?? finishman2000 Power Systems 8 Jan 25, 2009 05:58 PM
Sold E-Flite Six Series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 4 Nov 24, 2006 09:04 AM
Discussion E-Flite 'Six Series' for Trex? JustPlaneChris Mini Helis 2 Oct 30, 2006 04:53 PM
For Sale E-Flite Six series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 0 Jul 31, 2006 05:13 PM
For Sale E-Flite Six series outrunner 2000Kv NIB Red Aircraft - Electric - Power Systems (FS/W) 0 May 17, 2006 12:40 PM
