Joined Sep 2006
Yup, plane nosed over at edge of table, landing gear clamped, gooseneck lamp, sitting on the floor, balancing screws with ball driver. That got old sooo fast. Fuel tubing solved the awkward vertical part, but still way fiddly. That's when I switched to hooked tabs, with the washers glued to the cap screws. Much easier to start the screws without the cowl, then rotate the cowl onto the screws, and finally tighten the screws down. Magnets are dead simple, but I didn't have the magnets at the time, and the dremel was at hand. Plus I still have a fear (probably irrational) that the cowl might pop off without any mechanical restraint to keep it on. Bruno |
When I used the magents for the cowl, I didn't have to shim out the motor. In fact, I actually stacked two magnets on the top to achieve perfect cowl alignment and there were no issues with prop spacing.
I'm much better with the camera now...honest! (lol)
Here is a link to my YouTube home page if you want to see some better videos. I'll have to get the Beaver up again soon. I've been distracted by a number of builds and have started to get more serious about sport aerobatics and 3D. Unfortunately, scale flying has taken a bit of a backseat. https://www.youtube.com/user/rgthd007?feature=mhee Cheers |
Hi Oatmeal Savage: just curiousity, how much does your Beaver weigh (not your wife/ girlfriend -hehe)? You have used heavy components all thru the plane, guys here have used lighter stuff, and still run into the ground looping/ tip stalls. It never a lack of power, even the Eflite 25 is good. At 6 1/2 lbs what i saw was an unfriendly plane that snaps viscoiously if slowed too much. Thats something every flyer wants theri Beaver to do well.
I have a much lighter Unionville 72" Beaver (4lbs,4ozs rtf) that shows none of these tendencies. It has no flaps, but will slow to a crawl on calm days. Yours flies great, some of the best landings I've seen posted, must be pilot skill right!! Thanks for the video, looks darned good for a first attempt. Doug B
Okay, so I just used the Cuisinart Kitchen scale (which is probably pretty accurate) and mine weighs in at a portly 5 pounds 6 ounces (without the battery). A chunk of the extra weight over the claimed weight of 4 pounds, 13 ounces is probably due to the fairly heavy Du-Bro 4 1/2" soft tires. Even with a battery I think I would be lighter than 6 1/2 pounds. Weight aside, the plane flies great but as you mentioned, doesn't like to take off going too slow with too much elevator or turn too slow and tight with the flaps on. Hope this helps. |
Joined Nov 2005
Oatmeal, I love your scale flying. Nice job with the Beaver. I did mine on floats and it came in at about 6.5 lbs.
I have not experienced any of the tip stall issues and it flies great. I ran the plane through all the common manuevers without issue: snaps, stall turns, slow and fast flight, loops. The stalls drop gracefully nose first, and I really have to try and stall it. I put the CG in the middle of the recommended range. |
USA, WY, Cody
| Thread Tools | |
| Discussion E-Flite Six-Series Brushless?? | finishman2000 | Power Systems | 8 | Jan 25, 2009 05:58 PM |
| Sold E-Flite Six Series 2700KV | Dora Nine | Aircraft - Electric - Power Systems (FS/W) | 4 | Nov 24, 2006 09:04 AM |
| Discussion E-Flite 'Six Series' for Trex? | JustPlaneChris | Mini Helis | 2 | Oct 30, 2006 04:53 PM |
| For Sale E-Flite Six series 2700KV | Dora Nine | Aircraft - Electric - Power Systems (FS/W) | 0 | Jul 31, 2006 05:13 PM |
| For Sale E-Flite Six series outrunner 2000Kv NIB | Red | Aircraft - Electric - Power Systems (FS/W) | 0 | May 17, 2006 12:40 PM |
