Old May 31, 2009, 04:04 AM
AlteredState's Avatar
Joined Nov 2006
This is what happened to my DCH2 Beaver on its Maiden. CofG was perfect, motor thrust was fine (down & right), wing flap was a tiny bit warped but not so much that it should do this. Later inspection revealed two tiny pin holes in the left float which I think filled up with so much water that it caused it to lurch to the left. Not even full right aileron would right it. Anyway enjoy my misfortune and stay tuned for the next maiden.
http://www.youtube.com/watch?v=N_v7PSpNEas
AlteredState is offline Find More Posts by AlteredState
Old May 31, 2009, 05:56 PM
Wilmington, NC
Joined Apr 2008
Originally Posted by AlteredState
This is what happened to my DCH2 Beaver on its Maiden. Anyway enjoy my misfortune and stay tuned for the next maiden.
What a great place to maiden...even though it went bad...it looked good....You will make it next time! I bet the swim was a warm one!
Thanks for the video.
Sleddog is offline Find More Posts by Sleddog
Old May 31, 2009, 07:12 PM
Surrey, BC, Canada
Joined Feb 2007
Hilarious how you edited the video. I had to watch it over and over a few times.
Gerry B is offline Find More Posts by Gerry B
Old May 31, 2009, 08:30 PM
Screw the wind, let's fly!
Naval Warfare's Avatar
Lawrenceville, Ga
Joined Feb 2008
sorry Man
Aww man. Not the dreaded "swim" of shame. Been there, doin the same with it.In a leaky kayak though.
Good save btw. It couldve been much worse.Keep at it. She's a beauty floatin past ya.
Nav
Naval Warfare is offline Find More Posts by Naval Warfare
Old Jun 04, 2009, 12:56 AM
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Ran up the Motor tonight
Eflite 25
CC60
12x8 APCe
TP4200 3s
Only 288 watts. What are others getting? This seems pretty marginal.
DavidN
DavidN is offline Find More Posts by DavidN
Old Jun 04, 2009, 08:17 AM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Eflite 25
CC60
12x8 APCe
TP4200 3s
DavidN
You need more prop and 500w+. I would shoot for 550-600w or so.
Old Jun 04, 2009, 09:36 AM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Thanks Mike
I would probably be OKwith 400 minimum for this style of plane and no floats.
BUT I was more concerned that this is a brand new motor. First run out of the box. Is it performing to specs. Do I have poor ESC settings or a bum motor?
DavidN
Old Jun 04, 2009, 02:02 PM
pda4you's Avatar
Joined May 2002
It has been a while since I have run a power 25 - but remember running a larger prop on it.
I suspect all is fine - but someone with the power 25 will chime in here...
Old Jun 04, 2009, 07:37 PM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Eflite 25
CC60
12x8 APCe
TP4200 3s
DavidN
I think you may find it difficult to fly this pane with 288 watts. It may fly but it will be very marginal on power with NO reserves for those times when you need more power. I run a 4S battery with a 13 x 8 prop and produce 490 watts with my Turnigy 42-50 700kv motor. I don't use all the power I have available but it is there if I need it. She flies very good at about half throttle which means I am not pushing the motor, ESC or battery very hard.
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Jun 04, 2009, 08:27 PM
Horizon Hobby Employee
Mahomet, Illinois
Joined Aug 2007
Eflite 25
CC60
12x8 APCe
TP4200 3s
DavidN
You should be getting a little less than double that wattage. Check your battery's charge, and verify your controller settings are set for a 3S cutoff voltage.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Site Sponsor
Old Jun 05, 2009, 12:49 AM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
verified controller settings. Tried 2 other batteries' within 20 watts. I have a power 32 which I have swapped in. I hope to test with same batteries and also 4s. This may shed some light on the health of the motor.
Both 25 & 32 are new. 32 was out of stock when I bought the 25 for the Beaver.
Old Jun 05, 2009, 03:39 AM
T-28 abuser
bigstatik's Avatar
United States, NY, New York
Joined May 2009
sorry, I can't search the whole massive thread.
how long would it take a noob to build this plane?
bigstatik is offline Find More Posts by bigstatik
Old Jun 05, 2009, 09:24 AM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
I am a slow builder. I'd say. 3 evenings.
Check the flaps on opening the box tp make sure they are equal & have bind free travel. My original Left wing had the outer flapsticking up at the front. it wouldn't fully close. Fortunately I didnt build the wing(replaced after long wait). The right wing was a little tight to get to close so ended up with unequal travel. So I have 1 flap on the gear channel mixed in to get the throw adjusted.
Old Jun 06, 2009, 01:05 AM
Surrey, BC, Canada
Joined Feb 2007
I had trouble with the flaps too. Worked great after rehinging.
By the way I used a power 32 and an apc 13x6.5 for the maiden at Chilliwack.
I am a way slower builder, usually a couple of weeks for me. It took a month for me to build the floats.
Old Jun 06, 2009, 11:43 AM
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Painting the engine & fitting it took much longer than I expected
Fitting cowl tip
Cut washers of fuel tubing about 3/32" and use them between the cown and the fuse. they will allow the bolts to be held in place. Then I propped the fuse on it's tail against my bench under a bright light & could screw the bolts in with relative ease.
DavidN
Discussion E-Flite Six-Series Brushless?? finishman2000 Power Systems 8 Jan 25, 2009 05:58 PM
Sold E-Flite Six Series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 4 Nov 24, 2006 09:04 AM
Discussion E-Flite 'Six Series' for Trex? JustPlaneChris Mini Helis 2 Oct 30, 2006 04:53 PM
For Sale E-Flite Six series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 0 Jul 31, 2006 05:13 PM
For Sale E-Flite Six series outrunner 2000Kv NIB Red Aircraft - Electric - Power Systems (FS/W) 0 May 17, 2006 12:40 PM
