My suggestion is that if you have a computer radio with enough channels, put each servo on a separate channel and use a mix to control both flap servos. Doing this allows you use the EPA and Subtrim features to sync them together.
Whenever I use separate servos for flaps or ailerons, I always put them on individual channels so I can fine tune the travel adjustments easily. Make them as close mechanically as possible then use the radio's features to your advantage. Makes life more easy! JMHO, Joe |
Central Lake, Michigan
Joined Dec 2002
After perusing through my Eclipse 7 handbook, I was even more confused, so I'm calling them Friday and try to get it sorted. I would also like to set up the aileron and flap servos on their own individual channel, but getting the mixes and hopefully a 3 way toggle switch to control the flap setting may be more than what the radio is capable of.
I just got my new servos for the elevator and rudder (HS-225BB) today from BP Hobbies. Fast service from these guys. Now I need to get my Berg 7 Rxcr and maybe, just maybe it'll work. |
Joined Dec 2002
I talked with one of the techs at Hitec and found the radio did not have the programing to do what I want. @#%&*** so now I'm going to set up the ailerons on ch. 1&6 and use ch.5 for the flaps and see if I can mix the elevator in the with flaps that way. the radio has 5 P-mixes so it should not be a problem. Looks like my next radio will either be a JR or Spectrum. LOL
United States, TX, Kerrville
Joined Oct 2003
CR |
Canada, ON, Guelph
Joined Jan 2003
Floats...?
Anybody out there tried to fly the E-flite Beaver off water using the recommended E-flite floats? My one and only try was unsuccessful. No damage but this sucker would not get off the water, and it was being flown by a more experienced pilot. There's no detailed instruction on how to set up the floats other than to "install them". What is the correct angle of the floats, where is the CG, ac forward CG or aft CG? Any suggestions out there?
Joined Oct 2003
BTW, did you try it with the flaps extended? CR |
Joined Oct 2003
Float Rigging
When I applied throttle, holding full up elevator (EL), the model tried to dig in the float tips. I had to blip the throttle to get moving a bit for the EL to bite before it quit blowing water from the prop. After it got on the step, I had to apply a bunch of up EL to yank it off the water. Not good. In the air it was fine. Power 32 on 4c 4,000 is more than enough. Flies very scale. Sure looks good on a flyby. Landing was a little hot but when it was greased in pretty fast it did OK. My evaluation is that it needs more positive incidence between the wing and floats, say 3 degrees, and the CG needs to be at the rear spec. Mine was balanced in the middle of the CG range. I'm going to shim the front mounts and I'll tellya wha' hoppen. Pics: |
Man I was lookin at the 1st pic,saying, dang if he didnt giter done, then this. Very cool .Thank you.Can you post pic of the inside servo set up. ??? Ive been doin a littler tinkering in there myself.Unveiling later this week.Maybe... Biiiig WIP
Joined Dec 2002
Got it all sorted now. The ailerons are plugged into ch.1&6 so I can set up some differential. Maybe a DX-7 is in my future.LOL |
Joined Oct 2003
Spoke too Soon
I remember now that when I chose which radio for my Beaver, one reason I used the RDS 8000 was that it had the 3 position switch directly controlling channel 6. The other reason was that I want my float planes on spread spectrum so I don't have to worry about interference if I'm not at an AMA field that has a frequency control board. CR |
| Thread Tools | |
| Discussion E-Flite Six-Series Brushless?? | finishman2000 | Power Systems | 8 | Jan 25, 2009 05:58 PM |
| Sold E-Flite Six Series 2700KV | Dora Nine | Aircraft - Electric - Power Systems (FS/W) | 4 | Nov 24, 2006 09:04 AM |
| Discussion E-Flite 'Six Series' for Trex? | JustPlaneChris | Mini Helis | 2 | Oct 30, 2006 04:53 PM |
| For Sale E-Flite Six series 2700KV | Dora Nine | Aircraft - Electric - Power Systems (FS/W) | 0 | Jul 31, 2006 05:13 PM |
| For Sale E-Flite Six series outrunner 2000Kv NIB | Red | Aircraft - Electric - Power Systems (FS/W) | 0 | May 17, 2006 12:40 PM |
