Old Jan 02, 2008, 01:16 PM
P-51C is offline
Find More Posts by P-51C
Reserved Parking
P-51C's Avatar
Joined Jun 2004
New Product
E-flite Platinum series DeHavilland DHC-2 Beaver
The next model is: (from a post by John Redman in another thread)
P-51C is offline Find More Posts by P-51C
Old Jan 02, 2008, 02:17 PM
peterpont is offline
Find More Posts by peterpont
Troutdale, Oregon, United States
Joined Oct 2003
new beaver
When is this going to be released
peterpont
peterpont is offline Find More Posts by peterpont
Old Jan 02, 2008, 02:28 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
To H--- with the plane , when is the good looking lady being released ?
lake flyer is offline Find More Posts by lake flyer
Old Jan 02, 2008, 02:41 PM
AmpAce is offline
Find More Posts by AmpAce
AmpAce's Avatar
North by Northwest
Joined Nov 2003
Hopefully there are some floats in the works??
AmpAce
AmpAce is offline Find More Posts by AmpAce
Old Jan 02, 2008, 03:10 PM
baldguy is offline
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Oh, I think she probably already floats!
baldguy is offline Find More Posts by baldguy
Old Jan 02, 2008, 03:21 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
yep you can order floats also
Old Jan 02, 2008, 03:26 PM
countrygentleman is offline
Find More Posts by countrygentleman
Ustabee supported Unabomber
countrygentleman's Avatar
Joined Sep 2006
I can't wait for this. So getting one whenever possible!
E-Flite DeHavilland Beaver ARF 68"
Price: $159.99, Due Mid-February
Specs
Wing Span:68 in (1735mm)
Overall Length:43 in (1090mm)
Wing Area:565 sq in (36.4 sq dm)
Flying Weight:4.9 - 6.2 lbs (2.2 - 2.8 kg)
Motor Size:Power 25 or Power 32
Radio:6+ Channels w/6 mini servos
Servos: (6) JR Sport MN-48
Trim Scheme Colors:Ultracote White with maroon and gold trim
Prop Size:APC 12x8E
Hardware Included:Yes
Speed Control :60 Amp
Recommended Battery:3S 11.1V 3200 mAh Li-Po
Flaps:Yes, prehinged
Approx. Flying Duration:10 minutes
Recommended Power Setup Options:
1) E-Flite Power 25, Thunder Power 3s 11.1V 3200 mAH lipo, 60 AMP ESC of choice. This setup is recommended for non-float flying.
2) E-Flite Power 32, Thunder Power Extreme 4s 14.8V 3300 mAH lipo, 60 AMP ESC of choice. This setup is recommended for flying with floats. The Power 32 ought to be more than enough for hauling the floats.
countrygentleman is offline Find More Posts by countrygentleman
Last edited by countrygentleman; Jan 11, 2008 at 05:06 PM. Reason: Figured somewhere on the first page the specs need to be listed
Old Jan 02, 2008, 03:27 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Nice very nice...........another hit I suspect...
Old Jan 02, 2008, 03:33 PM
BigGuyJT is offline
Find More Posts by BigGuyJT
BigGuyJT's Avatar
Fresno, California
Joined Mar 2007
Man, look at them bingo wings!!!! Errr ahhh I mean flaps...
BigGuyJT is offline Find More Posts by BigGuyJT
Old Jan 02, 2008, 03:34 PM
Joined Sep 2006
I wonder what'll power this thing. Do you think this could be flown in a larger residential park? I'm talking two soccer fields, softball field, baseball field, basketball court, and tennis court. Assuming you get it up over the few trees, would it be a smart idea? Or will this be too large? I shudder at the thought of it going down by someone's house.
Old Jan 02, 2008, 03:36 PM
Dora Nine is online now
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Looks like you guys at E-flite made another winner! Once we get a rough idea when the plane will hit the market, I'll start the process for buying up the various parts again. For me it makes the hit in the wallet easier to handle when I do it slowly versus all in one shot.
Some things I like already:
Floats are a given.
The flaps are nice touch whether they are needed or not.
Flap push rods are internal.
I like the strut set-up similar to the T-craft
Easy access battery hatch
Outline looks very close to scale.
I am a little worried about:
Holes in the battery hatch close to floats/water.
Dora Nine is online now Find More Posts by Dora Nine
Old Jan 02, 2008, 03:46 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
It is likely too big - unless your park is huge and nobody is in your overfly area. I think John said it was in the power 25-32 range - that likely means 3-5lbs and I think he also said it was a 68" span......
Highly likely to be a club field model.
Old Jan 02, 2008, 03:50 PM
Dora Nine's Avatar
United States, NH
Joined May 2005
Or on a nice big pond close to home.
Old Jan 02, 2008, 03:55 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
O man - that is just not right!
Old Jan 02, 2008, 04:17 PM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
Guys,
Since John has left for the day, here are a couple stats for you.
68" span, weighs in at 4.3 lbs, so it's certainly not a park flyer. Power 25 does nicely on wheels, power 32 would be good for floats.
Dora, the "holes" in the battery hatch actually are covered from the inside with a molded plastic part. You can still use the holes to grip and remove the hatch, but they are sealed to prevent water from entering the fuse. If you're not going to fly off water at all, you can open them up with a rotary tool at your option.
Regarding the release date of the model holding the model, you'll have to ask her husband. Considering they only got married a short while ago, I doubt she'll be available any time soon!
As far as timing goes, at this point I believe we're still on schedule for some time in February, although I can't get more specific than that.
Have fun with this one!
David Eichstedt
Director of Aircraft Development
Horizon Hobby
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Discussion E-Flite Six-Series Brushless?? finishman2000 Power Systems 8 Jan 25, 2009 05:58 PM
Sold E-Flite Six Series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 4 Nov 24, 2006 09:04 AM
Discussion E-Flite 'Six Series' for Trex? JustPlaneChris Mini Helis 2 Oct 30, 2006 04:53 PM
For Sale E-Flite Six series 2700KV Dora Nine Aircraft - Electric - Power Systems (FS/W) 0 Jul 31, 2006 05:13 PM
For Sale E-Flite Six series outrunner 2000Kv NIB Red Aircraft - Electric - Power Systems (FS/W) 0 May 17, 2006 12:40 PM
