Lately I have found I can use it in compression mode too, that is, instead of just using it to hold my boom down, I can dial in just a bit of UP on light wind days to put a little curve in the sail, well not really to put curve in it, but to offset the weight of the boom, which tends to flatten the sail by stretching it downwards. I'm not explaining this very well, I can tell, but I think you'll know what I mean (I hope). ![]() The one caveat is to make sure there is no resistance/friction caused by the ball swivel links. They tend to be a bit stiff when new. This is not good on a light wind day as your boom will not swing over easily like it should. You can use an adjustable ball link available, or if you don't have room (they are a bit bulky), you can slip a 4-40 bolt through the hole in the ball link with a nut locked on each side, put the head of the bolt in your drill chuck, smear some abrasive stuff on the ball, (rubbing compound, valve grinding compound, whatever), turn on the drill, and work the swivel all around at many different angles while the drill is spinning the ball. This will loosen it up. If it is already loose, a little light lubricant, like WD 40 helps too, nothing gummy. Silicone lube is good. |
For the real sailors, they just strap a pillow slip to a stick and where they go is anyone's guess eh Capt !!! ![]() ![]()
You know, the growth of this thread, and its old popularity was mainly lively conversation, and the HUGE amounts of rabbit trails, so to speak, in this thread.
I have noticed guys saying they are doing other stuff, but, dont wanna post it here... This thread has ALWAYS been about friends meeting, discussing the Nirvana, and every other thing known to exist..which made it the fun thread it WAS.. We used to get 1-2 pages a day..look back, cars, girls, guns, all the good stuff.. How much can be said about a Nirvana???? its been said. Pointy end goes forward, IF there is wind..fix leaks, adjust sails, fiddle with boat in general, fit new sails...THE END. Killin this thread is easy...make it boring. We didnt get to 500+ pages by that, trust me. |
United States, AL, Montgomery
Joined Jul 2011
This seems a bit much when you consider the price of a new one with updated radio, although it does have the charger pack.
http://www.ebay.com/itm/Megatech-32-...item4abf268ab8 |
| Thread Tools | |
| Discussion Vixen yacht. | chidago | Sailboats | 1 | Mar 01, 2013 02:58 PM |
