View Poll Results: Poll Closed
cloled 0 0%
closed 0 0%
Voters: 0. You may not vote on this poll
Old May 09, 2008, 01:58 PM
Firstfooty is offline
Find More Posts by Firstfooty
A beginner - believe me
Derby U.K
Joined Nov 2006
Hoghappy,
I forgot to say that the jib boom end attachment is an uphaul line. It acts in the opposite way to the kicker on the main boom. Instead of putting tension into the sail as with the main boom it takes it out of the leech of the jib. It allows me to match the curves of both jib and main. It is attached via a bosie to where the jib stay meets the hounds.
Again, I'm not sure it is strictly within the rules
Cheers,
firstfooty
Firstfooty is offline Find More Posts by Firstfooty
Old May 09, 2008, 02:19 PM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Thanks for the info Firstfooty... The rules on the first post here mention downhauls and topping lifts being allowed, but no mention of uphauls.
D.2.2.3 Sail & Rigging Adjustments - Rigging of out hauls, down hauls, halyards, topping lifts, and boom vangs is to the owners discretion. See change dated 8/01/07 at end of rule.
.2.2.3 Topping lifts may be installed on the aft end of either the main or jib boom. The jib boom may not be weighted.
Capt. Crash
Capt.Crash is offline Find More Posts by Capt.Crash
Old May 16, 2008, 07:16 PM
fx1mark is offline
Find More Posts by fx1mark
Bham,AL.
Joined Aug 2007
I stuck a small video recorder on my nirvana today. I have been curious to see what it would look like to be onboard.
Nirvana II onboard camera. (1 min 13 sec)
fx1mark is offline Find More Posts by fx1mark
Old May 16, 2008, 10:02 PM
aero528 is offline
Find More Posts by aero528
aero528's Avatar
West Lafayette, IN
Joined Sep 2004
Thats really neat! It almost looks like you're on a real boat, except I've never keeled over quite that much in a 40' Cabin cruiser. Where did you get the camera stuff?
aero528 is offline Find More Posts by aero528
Old May 16, 2008, 10:40 PM
fx1mark is offline
Bham,AL.
Joined Aug 2007
the video recorder I got at aiptek for $20.
http://www.aiptek.com/
look under pencams. it's low quality but almost disposable.
and just made a little mount for it.
Old May 17, 2008, 09:12 AM
aero528 is offline
aero528's Avatar
West Lafayette, IN
Joined Sep 2004
Not bad at all for 20 bucks. Pretty small, too. The video isn't honestly that bad for youtube, and just messing around, though. I might have to look into one.
Old May 17, 2008, 09:42 AM
jpatters is offline
Find More Posts by jpatters
Joined Dec 2006
Here's another Nirvana onboard video:
http://www.rcgroups.com/forums/showthread.php?t=757533
jpatters is offline Find More Posts by jpatters
Old May 23, 2008, 02:21 PM
Greysquirrel is offline
Find More Posts by Greysquirrel
Greysquirrel's Avatar
Hendersonville WNC
Joined May 2008
Nirvana arrived today.
Ordered Nirvana Wednesday and came home for lunch and it was sitting on my porch, never expected till next week but have it together and will go sailing tomorrow. Only problem I have is that I ordered blue and they sent yellow but I can live with that. Think it took longer to unpack than to put it together. The only thing I don't like it the little plastic bowser to adjust the shrouds, must be some kind of small turnbuckle or something similar that you can put on the chainplate to adjust them. The bowser is ok for the other adjustment and I can live with what I have till I get sailing and know what I really need to tune the rig.
Greysquirrel is offline Find More Posts by Greysquirrel
Old May 23, 2008, 03:16 PM
doomracing is offline
Find More Posts by doomracing
doomracing's Avatar
United States, NY, Buffalo
Joined Mar 2002
goto your local dicks, or fishing store, and get some steel leader, and leader crimps. some people use pieces of brass tubing, but for me they aren't as strong. it's up to you. then your lhs, and get some shrink tube big enough to make contact about half way down the clevis, or use some fuel tube, 4-40 nuts, clevis clips (du-bro # 304), and 4-40 rigging couplers (du-bro #618).
pass the steel leader threw the mast crane long enough to reach the chain plates plus 6". double it back to the spool, and cut the wire so you now have 2 equal leads from the mast crane. slip a leader crimp over both wire, and slide it to the mast crane. crimp it twice 90 degree from each other. feed both wires threw the (not sure what it is called but...) thing the original wires went threw. put a crimp on the wire, and a piece of shrink tube/fuel tube, then the rigging couplers, and back threw the crimp. attach the clevis to the chain plate, and then do the other side. put a nut on both rigging couplers then the clevis clip. thread the rigging couplers so they just start to show threw the clevis clips. attach the clevis clips to the chain plate on both sides. slide the crimp down kinda tight making the mast look as straight as you can. at this point crimp the crimps.
now do your final adjustments to snug up the 2 shroud lines keeping the mast straight. don't let go of the rigging couplers, or they will unthread themselves. snug down the nut. remove the clevis to let it untwist itself. put it back on the chain plate cut off excess wire, and slide the shrink tube/fuel tube down on the clevis clip, and poof. your done. now you have a repeatable setup. you could do the same to the stern line, but would have to add the bowsi and string for adjustment.
just thought of something. use 2 different color pieces of shrink wrap/fuel tube so you put the clevis to the proper side. they should be of equal length, but better safe than sorry.
heres a pic of mine.
doomracing is offline Find More Posts by doomracing
Old May 23, 2008, 04:44 PM
Hendersonville WNC
Joined May 2008
Thanks Doom, you're full of good advice, first you set me straight on what not to buy, then tell me where to get the best price, and now this rigging advice your OK no matter what your brother says, just kidding don't beat up on your brother.
Again thanks for the tip.
Old May 23, 2008, 05:09 PM
doomracing's Avatar
Joined Mar 2002
i'm here to help. i try to give back when i can.
Jerry
Old May 26, 2008, 01:32 PM
Alman is offline
Find More Posts by Alman
Alman's Avatar
Canada, Quebec
Joined May 2001
Question?
Hey guys,
I’m ready to order a Nirvana II sailboat but can’t decide between the original RTR and the “Choice” version offered buy SailRc.
The “Choice” has a Zebra radio and a Hitech 645MG servo. The original Nirvana has a FM radio and also a metal gear servo. I’ve search the net for information on the zebra radio; only found an AM 27mhz version…is it the one?
Anyone here got a “choice” version to comment about?
Great tread
Alman is offline Find More Posts by Alman
Old May 26, 2008, 02:59 PM
DougHemi is offline
Find More Posts by DougHemi
Footy USA 30
DougHemi's Avatar
Joined Apr 2005
What Doom said, except I would use Steelon leader (nylon coated steel wire) which is less inclined to tangle when off the boat. 20# test should be sufficient for a Nirvana.
According to UPS, my "Naked Nirvana" (no radio--lord knows I've got enough of THEM laying around) from SailRC.com is in Buffalo awaiting delivery tomorrow.
Doom, watch your email later this week for an outline of something I'm thinking of doing later this summer.
--Doug
DougHemi is offline Find More Posts by DougHemi
Old May 26, 2008, 08:48 PM
doomracing's Avatar
Joined Mar 2002
Doug you back home now? glad to see your on the mend. everyone in the club, and on race night asks, and wonders how your doing? glad to see your back online.
yup thats the stuff i use. not sure if it's steelon, or not but it's nylon coated steel wire.
Old May 26, 2008, 09:38 PM
jpatters is offline
Joined Dec 2006
The Zebra I received from from sailrc last year is 75mhz and works fine. You could contact sailrc for more information.
Discussion Vixen yacht. chidago Sailboats 1 Mar 01, 2013 02:58 PM
