Espritmodel.com Heli Air
Old May 22, 2001, 04:31 AM
Veldhoven, Holland
Joined Jan 2001
Wattage Mirage 2000-5
Have built this one and done a lot of work to get it looking O.K. Maybe I missed something in the English instruction set about routing the Rx aerial....can't find any reference to it. As a beginner to pusher types, what would you guys reccommend i do ?
cheers
Ray
Ray Richards is offline Find More Posts by Ray Richards
Old May 22, 2001, 04:37 AM
All under control, Grommit!
leccyflyer's Avatar
NW England
Joined Sep 2000
Hi Ray
My mate has his run along the leading edge of the starboard wing secured with a bit of Scotch Magic Tape - that keeps it out of the way of the prop.
Cheers
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old May 22, 2001, 11:53 AM
bozmonster's Avatar
St Paul, Mn
Joined Apr 2001
Thats where I put mine, just run it along the wing so it doesn't hit the prop or control surfaces...........chris
bozmonster is offline Find More Posts by bozmonster
Old May 23, 2001, 12:14 AM
Veldhoven, Holland
Joined Jan 2001
Thanks gentlemen, now you mention it, i fell dumb for asking ! such is a lack of confidence.!!!!!!!!!!!!!!
cheers
Ray
Old May 23, 2001, 12:25 AM
Clayton's Avatar
Jackson Hole, Wyoming
Joined Feb 2001
Ray,
Sometimes self-evident questions still need to be answered. Good luck with the mirage. It looks like a cool plane. Definetly be particular with your C.G.!
Clayton is offline Find More Posts by Clayton
Old May 24, 2001, 08:32 AM
Swindon, UK
Joined Nov 2000
Hi Ray,
This is a tricky subject. Some people on other threads stuck their antennas on the underside of the wing in a snake-like fashion. I used some wire to thread mine through the core of the wing. There was still about 18 inches (45cm) trailing in the wind which was fine until I stalled doing a loop and it got wrapped around the prop!! Now I've pulled some back into the fuselage so it doesn't reach the prop.
skids is offline Find More Posts by skids
FS: Used Wattage Mirage 2000-5 jimmyray Aircraft - Electric - Airplanes (FS/W) 4 Mar 25, 2004 08:54 PM
FS-Wattage Mirage 2000-5 NIB ArcherAce Aircraft - Electric - Airplanes (FS/W) 0 Dec 14, 2003 11:48 AM
WTB Wattage Mirage 2000-5 new or used mlehman Aircraft - Electric - Airplanes (FS/W) 6 Dec 13, 2003 09:12 PM
FS: Wattage Mirage 2000-5 digidoc100 Aircraft - Electric - Airplanes (FS/W) 0 Jun 02, 2003 09:28 PM
Wattage Mirage 2000-5 colour scheme awood12345 Parkflyers 35 Nov 03, 2002 04:26 PM
