Espritmodel.com Heli Air
Old May 21, 2001, 04:00 AM
Swindon, UK
Joined Nov 2000
Mirage 2000-05 downthrust or up?
My Mirage climbs very steeply on full power. I am wondering if its due to the motor down-thrust of 2 degrees stated in the instructions. Has anyone else found this?
A front engined plane normally has down thrust to keep the nose down and compensate for the extra lift generated by the extra speed at full power. So shouldn't a pusher plane should have up-thrust to push the tail up to keep it level? Down-thrust would push the tail down causing it to climb wouldn't it?
skids is offline Find More Posts by skids
Old May 21, 2001, 04:32 AM
RC Addict
Jeremy_D's Avatar
Central Coast, Australia
Joined Jan 2001
hi skids.
why not try moving the cg forward. Mine had the same prob so I just moved the pack forward, flies like its on rails now. I was weary at first about trying this but as a friend said " no guts , no glory!"
See how you go.
Jeremy..
Jeremy_D is offline Find More Posts by Jeremy_D
Old May 21, 2001, 01:37 PM
ToddNicholson's Avatar
Anacortes, Wa. USA
Joined Aug 2000
Skids,
It will do what you're experiencing if you have to much thrust built-in. The thrust set-up per the instructions is just right. I would double check that you haven't gotten too much thrust put in and check your c/g again. It does sound like it's tail heavy.
Todd
ToddNicholson is offline Find More Posts by ToddNicholson
Old May 24, 2001, 07:54 AM
Swindon, UK
Joined Nov 2000
Thanks for the suggestions. I hadn't really thought that the CG could cause it to climb too much and thought that the CG may be too far forward because it doesn't loop very well and rolls quite slowly but perhaps I just need to increase the control throws.
I've re-checked the thrust angle and it does look more than 2 degrees (but its so hard to judge) so I'm going to try using a spacer to angle the motor a bit and try that, then adjust the CG. On about half throttle it flies very smoothly, but throttling up makes it climb steeply.
[This message has been edited by skids (edited 05-24-2001).]
anyone tried a kamdax mig-15 or mirage 2000 yet? Demolisher Electric Ducted Fan Jet Talk 5 Oct 02, 2009 12:00 PM
WTB: Wattage F-22 Raptor or Mirage 2000 pc_pilot Aircraft - Electric - Airplanes (FS/W) 8 Aug 21, 2004 07:43 PM
WTB Wattage Mirage 2000-5 new or used mlehman Aircraft - Electric - Airplanes (FS/W) 6 Dec 13, 2003 09:12 PM
FS @ FL Jets (or nw oh): RT Mirage 2000 EDF foss1997 Aircraft - Electric - Airplanes (FS/W) 0 Feb 16, 2003 03:50 PM
FS: Complete Mirage 2000-5 set -up including Tx Etonic Aircraft - Electric - Airplanes (FS/W) 3 Sep 04, 2002 10:56 PM
