Old Dec 31, 2007, 01:41 AM
Dan the man is offline
Find More Posts by Dan the man
Sydney Kingsford, Australia
Joined Feb 2004
Sokol build tips and hints
Hey guys,
After years of having a Sokol Pylon racer sitting in my garage I'm finally building it.
What I'm after are some hints about how to throw it together. In particular where to place the servos and receivers and how to fasten it into place. I.e do I use CA, epoxy silicone glue from the hardware store.
I know these questions border on the basic to plain silly but I figure a wise man learns from others and does his homework.
By the way this is the setup I intend to run,
Mega 16/15/4 (I'll move on to a 16/15/3 once I'm used to it!)
Prop : 4.7x4.7
Battery: LiPo 3S1P 2200mAh.
I look forward to hearing from all of your. I'll let you know when the plane is up.
Best Regards
Danny
Dan the man is offline Find More Posts by Dan the man
Old Dec 31, 2007, 04:49 PM
shhhhh! is offline
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Hi Danny,
Here is a photo of the servo installation for the ailerons:
http://www.espritmodel.com/index.asp...n=Custom&ID=14
You can wrap the aileron servo with masking tape and then glue it in with epoxy or goop
The elevator servo is mounted just aft of the trailing edge of the wing.Wrap the servo with tape and glue it in with goop. The goop can flex during a hard landing allowing the servo to still stay in place.
Mount/place the receiver next to the elevator servo. The receiver needs to be placed as far away from the speed control as possible.
The speed control is mounted/connected directly behind the motor.
Your power set up is fine. The fir4st flight/launch is always a challenge!~
Good Luck!!
-Dave
shhhhh! is offline Find More Posts by shhhhh!
Old Dec 31, 2007, 05:32 PM
rosco is offline
Find More Posts by rosco
That motor isn't hot...
rosco's Avatar
Brisbane, Australia
Joined Aug 2005
here's some pics of mine. I don't suggest cutting the hot air exit holes, its just what I did. I used a good drop of exopy on my elevator horn, as I didn't want to lose the elevator at top speed. (make sure you wet inside the elevator with epoxy to make sure good adhesion. My friend also used that much epoxy and his has been clocked at 299kph.
The little hole below at the back of mine is the exit for the areal. I have my reciever behind the elevator servo it is tricky, but you can just get it in and out. 'Shhhhhh' probably has the best idea with the reciever and servo next to each other...Make sure to glue the push rod tube along its length down the fuse, maybe dribble some CA down there, it needs to have NO play in it if you are trying to achieve fast speeds, as my mates and I have found that it will get 'spongey' at high speed. I can't emphasis this enough.....lube the elevator wire. I spray silicon down mine. Otherwise, it may have a little pit of stick and you will be putting in elevator , getting no reaction, so you will add more with no reaction, then you will add more and the friction on the wire will all of a sudden release and you will get mega elevator...not fun at high speed.
Sand the inside of the fuse to make sure the epoxy will stick...you don't want to lose the elevator mid flight.
One last thing... I suggest to paint the wing to get some contrast happening. I found the white wing reflected the blue sky and because the wing is small it can get easy to lose.
rosco is offline Find More Posts by rosco
Old Jan 02, 2008, 12:10 AM
BioBa is offline
Find More Posts by BioBa
BioBa's Avatar
Brisbane, Australia
Joined Nov 2002
Aileron control
I prefer this ball link system to control the ailerons. With the standard straight wire linkage I noticed some strain on the sevo horns and wire. Also the aileron sometimes did not return easily to its center position. The ball linkages I borrowed from my heli set up. Works super smooth!!
BioBa is offline Find More Posts by BioBa
Old Jan 15, 2008, 07:38 PM
Flying Cat is offline
Find More Posts by Flying Cat
Flying Cat's Avatar
Cary, NC
Joined Jan 2002
To make the first few flights a bit less of a challenge, I would like to suggest using a 6x4 prop instead of a 4.75x4.75 or 5x5. The 6x4 prop will deliver significantly more thrust -i.e., MUCH easier launch- and you will loose just a bit of speed. Once you are comfortable launching the Sokol, you can move to a 4.75x4.75 Graupner carbon prop.
Enjoy,
Flying Cat is offline Find More Posts by Flying Cat
Old Jan 25, 2008, 03:32 PM
mikedsilva is offline
Find More Posts by mikedsilva
mikedsilva
Brisbane, Australia
Joined Apr 2005
I have to say, this has really whet my appetite to get a Sokol...
Where in Brisbane can i get hold of one?
or does anyone want to sell theirs?
(Brisbane)
mikedsilva@optushome.com.au
0418 316 203
mikedsilva is offline Find More Posts by mikedsilva
Old Aug 20, 2008, 05:11 AM
CrocEnd is online now
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
Where in Australia can we get a SOKOL I will buy now.
Or purchase from out side Aussie. HELP.
Cheer's All relpies welcome and Thanx.
CrocEnd is online now Find More Posts by CrocEnd
Old Aug 20, 2008, 05:58 AM
Stuntman is offline
Find More Posts by Stuntman
Upside down Miss Jane....
Stuntman's Avatar
Georgetown, Newcastle, Australia
Joined Aug 2002
http://www.wiredrc.com.au/shop/index...&productId=195
I am hoping they get some sunracers back in stock soon.
cheers, Shawn
Stuntman is offline Find More Posts by Stuntman
Old Aug 20, 2008, 06:12 AM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Shows in stock ... great team to deal with
cheers jeff
Shawn beat me to it ......Jeff also drooling over Sunracers.
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Aug 21, 2008, 03:26 AM
CrocEnd's Avatar
Darwin
Joined Aug 2002
Good went to there site thank you,you lot.
NOW whats this Sunracer Pic or some one show were
Thanx again in Aussie
Discussion GWS Piper Cub Build Tips & Hints? Royster Australia 111 Feb 07, 2007 03:11 PM
sokol build ? tetsuzo High Performance 3 Apr 05, 2002 04:39 AM
Needing FMA Razor Build tips kushal_22 Foamies (Kits) 12 Mar 26, 2002 03:40 PM
Terminator HLG - Comments? Tips? Hints? thelocust Electric Sailplanes 7 Oct 15, 2001 08:50 AM
SIGs Rascal Tips and hints ? William A Sport Planes 2 Sep 09, 2001 03:35 PM
