Old Dec 31, 2007, 01:28 AM
Rcgary20 is offline
Find More Posts by Rcgary20
pro R/C crash-test pilot
United States, WY, Gillette
Joined Jan 2006
new to gas engines , US 41cc
well i got a jumpstart to gas engines , was at my hobby shop today and originally went to go get some CA and ended up with alot more than that , got a 90% finished Robinhood 99 , with a US 41cc , ive never run gas motors before and need input on how to tune/etc. as far as i can tell it has never run , been sitting for a few years so ill give gas a try , been running nitro forever but i couldnt pass up this plane for $100! thank all , Gary.
Rcgary20 is offline Find More Posts by Rcgary20
Old Jan 01, 2008, 04:50 PM
Rcgary20 is offline
Joined Jan 2006
nobody?????? dont know the essentials for running gas engines , recommendations on oil , or anything about tuning , any help would be appreciated.
Old Jan 02, 2008, 10:32 AM
psantaana is offline
Find More Posts by psantaana
Buenos Aires, Argentina
Joined Oct 2005
Hi:
I'm new to gas too but I can tell you my little experience.
I used 20:1 mix during brak-in. Hi octane unleaded gasoline and 2T semi-synthetic oil for brak-in. After a galon or two, you can go to 40:1 with synthetic oil.
I have a 45cc engine with a 20x8 prop. I think that for a 41cc a 18x8 should be ok.
I found that these engines are very similar to nitro ones. You have 2 needles (Hi and low) but they run at lower RPM (7.000 or so).
Somebody also told me that gas engines need to warm up a little to be ready to fly.
Well, it's no much but surelly somebody will help you more.
Pablo.
psantaana is offline Find More Posts by psantaana
Old Jan 03, 2008, 10:40 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Run 40 to 1 mix. of regular chainsaw oil. Give her an extra dab for the first gallon. Regular gas is fine. It's a tough little engine that will give you years of good service. 18-8 is the standard prop for it as said. To prime it, stick your finger in the carb and pump the prop up and down like a pump handle. no need to turn it right over. When your finger gets wet with gas, give it a about 4 more pumps, they like to start wet. Wind the spring backwards for half a turn, just enough so it flips over compression when you let it go. If you wind it up any more, you'll ruin, buckle up the spring. Make sure it's well tied down. Give it 1/4 throttle and it should kick off on the second flip. Be carefull.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jan 03, 2008, 06:11 PM
Rcgary20 is offline
Joined Jan 2006
thanks for the info , im not sure about those spring starts , not sure if i like it , but ill use it for now untill i can afford a starter for big motors , my brother told me for gas engines he used lawn boy oil for the first gallon and redline for the rest , he is running a DA 85 on an edge 540 and a Fuji 64 on his christen eagle , but ill use what i can for the time being , thanks for the help!
Old Jan 03, 2008, 06:23 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
When you get your finger rapped with that 18 in. prop, you'll apreciate it Gary. Just like getting hit with a hammer. Been there many times.These mag. ign. engines have to be swung over the top fairly quickly to get a spark. That's where it pays off. Lawn Boy oil will work fine.
Help! Super Cub - Need help on engine and battery upgrade genepeele Electric Plane Talk 1 Oct 28, 2007 11:03 PM
Discussion Need help with engine springboro Engines 6 Sep 09, 2006 01:36 PM
Discussion Need help Tuning Engine! KrYpTyK Off-road Cars 9 Apr 02, 2006 04:34 AM
need help setting engine MoD_Eagle Beginner Training Area (Fuel) 3 Sep 17, 2005 07:58 AM
need help my engine's connecting rod snapped how can I prevent it jk123 Nitro and Glow Power Cars 9 Mar 31, 2005 08:53 PM
