Old May 22, 2001, 02:16 PM
deadcell is offline
Find More Posts by deadcell
deadcell's Avatar
Enterprise, MS
Joined Jan 2000
I use a Easton hunting arrow shaft made from carbonfiber, its 22 inches long in my FMA Razor, but i don't know the dia. Its smaller than a no#2 pencil. Thanks DC
deadcell is offline Find More Posts by deadcell
Old May 22, 2001, 07:05 PM
barn buster 50 is offline
Find More Posts by barn buster 50
tyler, texas, united states
Joined Mar 2001
i dont know what the diameter of mine is, i just used the one that came with it, its plenty strong! so i just put it in with the 3M- 77
barn buster 50 is offline Find More Posts by barn buster 50
Old May 22, 2001, 09:25 PM
newflyer is offline
Find More Posts by newflyer
newflyer's Avatar
Crowley, TX, USA
Joined Dec 1999
i used an aluminum tube about 3/16th OD. Put it in on the CG (8"back from the nose). I made it as long as I could without going into the EPP part of the wing. I put it in with this epoxy I got at Lowes that dries hard as a rock, but is light. Covered it with navy blue 21st century covering. Monokote would probably work fine, as I really cranked up the temp and the foam did not melt. Now it flies MUCH better than original. I did not use any of that fiber type tape. Not needed with the spar. Next mod will be to cut my old plastic battery/motor holder about2" in front of the motor and bury everything else...
newflyer is offline Find More Posts by newflyer
Old May 22, 2001, 09:32 PM
DaJudge is offline
Find More Posts by DaJudge
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
22" section of 2216 aluminum hunting arrow. Works great. It's as light as the CF rods and very strong. Plus, I had some extra ones laying around and didn't have to buy any.
DaJudge is offline Find More Posts by DaJudge
Old May 22, 2001, 09:38 PM
Joined Mar 2001
yes, ive also found that if its free i can aslo make it work
Old May 23, 2001, 12:48 AM
Ben C is offline
Find More Posts by Ben C
UK
Joined Jan 2001
Tube or rod as a zagi spar - which do you have?
I use a rod, diameter 3/16". I would be interested to see what other people use as a spar . . . we see lots of 'it should be 18"' or 'it should be 24"' but no-one ever mentions the diameter.
Just interested,
Ben C
Ben C is offline Find More Posts by Ben C
Ricky front wheel - which do you have? dmincin Motorcycles 3 Jun 19, 2005 01:25 PM
Which S&B Foamie do you have? Flying Low Foamies (Kits) 56 May 01, 2003 04:48 AM
flybar or flybarless, which do you guys prefer? jack brady Micro Helis 6 Dec 18, 2002 11:31 AM
Dial Up, DSL or Cable Modem - Which do you use? mrebman Life, The Universe, and Politics 16 Mar 06, 2002 02:27 AM
Duskstik Wing - Which do you have? mrebman Parkflyers 15 Sep 23, 2001 06:03 PM
