Old Feb 25, 2004, 12:36 PM
Tanis is offline
Find More Posts by Tanis
resistance is futile!
Tanis's Avatar
Essen, Germany
Joined Jan 2004
Here is a modified pic of the PCB.
For a full modification of the board, the red transistors should be replaced by 'IRLML 2502' (N-FET) and the blue ones should be changed to 'IRLML 6401' (P-FET).
I would suggest, only to change the transistor No. 6 and make a link where i draw the light blue bar. To leave transistor No. 5 as is, saves weight, as you don't have to use a 'Cruse-Resistor' (Ri of the original transistor is high enough )
I think it's not necessary to modify the H-Bridge for the actuator, cause there should not flow much current (depends on coil-resitance).
I have to check out F1 an F2 function of te RX6 C chip... that'll take a while... sorry about that...
PS: I've never used an actuator on the 'pulsed' H-Bridge (non-turbo-mode), but i guess you would have a 2 step digital steering...
PSS: If the H-Bridge is tuned with IRLML 2502 and IRLML 6401, the PCB need's at least 2,4 V !!!!
Tanis is offline Find More Posts by Tanis
Old Feb 25, 2004, 05:48 PM
Remy is offline
Find More Posts by Remy
Netherlands
Joined Feb 2004
Tanis,
thank you so very much..
But what is the "F1"and the "F2"function?
And you sad:" for al FULL modification,you need to replace all the transistors" "i would suggest to..."
So is it better to change all of them,or only number 6?
(I fly withe a 145mah kokam,so thats not the problem for the 2.4V that he need )
And the H-bridge,im sorry,but that is....¿
Tommorow I call every local shop,near this city,and if the dont have de fets,i must order them of the internet so that's take a little wile..
So,when i replace transitor 6,the moter gets to see the full battery voltage..
(ofcourse i must turn the signals of the transmitter)..
(people thank you very much for the time hou spend om my questions..)
Remy is offline Find More Posts by Remy
Old Feb 25, 2004, 11:55 PM
Tanis is offline
Tanis's Avatar
Essen, Germany
Joined Jan 2004
@Remy
Check your PM, so you can save some calls !
The F1 and F2 functions are like a '3rd chanel', unfortunally not used in most PCB-designs, so you have to pick the signal directly from the RX6 C chip and build the 'driving-part' externally. My english is'nt very good, and it's hard for me to describe my thoughts....
As i said, you should first change only the transistor No.6, and try if it works. If the actuator has not enough power, you can cange the transistors No.1 - No.4, but i guess that is not necessary.
With a single transitor you can only drive a motor or an actuator in one direction. If you need to have 2 directions, you have to use an H-Bridge. Try to google it out (i'm to lazy to describe that in english... ).
I'm completely new to RC-Planes / Helicopters, but i've done lots of Bit Char G mod's ...
--- Tanis ---
Old Feb 26, 2004, 04:26 AM
Koen Van Goethem is offline
Find More Posts by Koen Van Goethem
Brussels,Belgium
Joined Feb 2000
to Tanis
Do you know where I can find Fets like FDS6679 (13 A P channel )
I've tried to buy here in belgium , but no luck
I only need some (not many ) for a repair .
you can reply in German
Gruß
Koen VG
Koen Van Goethem is offline Find More Posts by Koen Van Goethem
Old Feb 26, 2004, 04:52 AM
Remy is offline
Netherlands
Joined Feb 2004
Tanis,i have send you a PM reply back
The H-bridge,i have searched on the internet(www.google.nl) I only found that a H-bridge isa sort of IC..
By the way,you do it greet with your english
its better than the mine
tanis,thank you very much for you time,en when i have the fets,soldered them,en tryed them,i let immideatly know it
Weight a second,ow here!,I have found the answer,to the H-bridge:P
http://www.interaccess.org/arg/arg-list/msg00560.html
Met vriendelijke groeten (this is dutch for"With frendly greets" "
("mit friendlich grüten")
Remy van Wijk
Old Feb 26, 2004, 05:52 AM
Tanis is offline
Tanis's Avatar
Essen, Germany
Joined Jan 2004
@Koen Van Goethem
i don't know where to get the FDS6679 by now, but i've found a similar Fet, that is easier to get : its the 'irf7416 smd'. This Fet is pincomatible to the FDS6679, but only can handle 10 amps. I have to check several Datasheets, when i'm back from work, maybe there is a better matching Fet....
Regards
--- Tanis ---
PS: I've answered in (bad?) english, cause others like to know it too...
Old Mar 01, 2004, 01:32 AM
Brussels,Belgium
Joined Feb 2000
to remis : if you like to learn about H-bridge
read the following link
http://www.dprg.org/tutorials/1998-04a/
make shure you read up to the part "Semiconductor H-Bridges"
this is what we need to power an E motor is the 2 directions .
in modern circuits , the NPN and PNP transistors are replaced by
N- and P-Fets .
To Tanis : Your english is "VERY" good , my german is worse .
I really need the same Fets , they are used in a 3phase H bridge
one phase has burned out
I'm not shure weather I will get my hands on these specific fets
regards ,
Koen VG
Old Mar 01, 2004, 02:09 AM
Tanis is offline
Tanis's Avatar
Essen, Germany
Joined Jan 2004
@Koen Van Goethem
i'll ask the a college at work, if he could get some 'samples' of that Fet. That may take a while, but they are for free then ...
--- Tanis ---
Old Mar 01, 2004, 05:05 AM
Brussels,Belgium
Joined Feb 2000
Tanis , that would be great !! Costs will been paid .
This FDS6679 Fet is used together with an N channel IRF7831
can your collegue check for this too ??
best regards ,
Koen VG
Old Mar 01, 2004, 05:53 AM
Tanis is offline
Tanis's Avatar
Essen, Germany
Joined Jan 2004
@Koen Van Goethem
the IRF7831 is aviable at www.conrad.de (Artikel-Nr.: 164357 - 14 ). The price is 1,91 €.... But i will ask the college too ...
regards
--- Tanis ---
Old Mar 01, 2004, 08:52 AM
Brussels,Belgium
Joined Feb 2000
What a response time !!
good to know that conrad can deliver the IRF Fet
regards ,
Koen VG
Old Mar 21, 2004, 12:53 AM
theoneinventor is offline
Find More Posts by theoneinventor
Wonder bread
theoneinventor's Avatar
USA washington
Joined Mar 2004
the link called bit char-g hack madness; the first post, doesn't work i really want to ckeck out that site though. what to do?
theoneinventor is offline Find More Posts by theoneinventor
Old Mar 22, 2004, 09:46 AM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
The link will work within a day or so. The RC-CAM site's host is having hardware issues. I understand that the server is being rebuilt due to hard drive issues.
RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Anyone need a cheap BitChar-G Clone to hack? Mr.RC-CAM Scratchbuilt Indoor and Micro Models 5 Apr 29, 2004 07:46 PM
