Old Dec 29, 2007, 01:57 AM
shappo is offline
Find More Posts by shappo
Joined Mar 2007
new racing boat hull - what engine, etc ??
Hi everyone,
I am relatively new to boats except for some electric ones, I am more of a plane man. However I have been given a pretty good looking hull and am keen to get it going. The thing is I am not sure of what engine to put in it, or anything about the weight distribution of the boat, what size prop, placement of prop, 1 or 2 props, how many blades on prop, etc. so I am really in need of your help ! any info would be much appreciated as I do not want to bugger up this nice lookin hull I have been given. I want to put a glow plug engine in it, I have a couple of aeroplane ones lying around but from looking on the net it's not worth mucking around with the watercooled head conversion and all that so i think I'l buy a proper marine engine for it, but I would like to use my electric starter for the aeroplane to start it cos I have had nothing but trouble with pull starts in the past. Is it possible to use electric starter on a boat ? Also I see that most boats use a flexible shaft inside metal tubing, is this the best way to go ? what do you use to lubricate the shaft ?
Basically I want to make the boat go fast and have some good fun with it, so if anyone could tell me some good tips for getting it going it would be much appreciated.
Here is the specs for the hull:
length: 88 cm (34.5 ")
width: 31.5 cm (approx 1 ft)
made of fibreglass
have a look at the attached pics and tell me what you reckon would be the best idea to get it running nicely for optimum performance. Also any info on what type of boat ir is would be great.
By the way, as I am after all the running gear for this boat if you have anything that you think would be suitable I would consider any offers to purchase bits and peices from you.
Thanks heaps everyone. Andrew.
shappo is offline Find More Posts by shappo
Old Dec 29, 2007, 06:50 AM
w3bby is offline
Find More Posts by w3bby
Helsingborg, Sweden
Joined Jul 2005
Hi Andrew, welcome to boats
The boat you have is a FSR-V hull used for Naviga endurance racing. I do not know the manufacturer.
These hulls are designed for a sub surface propeller, rudder under the hull and trim flaps under the stern. At 88cm you are probably looking at a 3,5cc hull.
For all your needs you should contact Dave Marles at prestwich or Ian Folkson at Ians Boats.
You can find an excellent site for these boats here and lots of pictures here.
w3bby is offline Find More Posts by w3bby
Old Dec 29, 2007, 08:13 PM
shappo is offline
Joined Mar 2007
thanks for the reply, so I have a hull that is capable of going quite fast ?? I have been looking at some pics and found an arrangement that looks like what you explained (attached pic), is this correct ? So for an 88cm hull what dia and pitch prop would I be looking for ? and please excuse my ignorance but do these boats have a centrifugal clutch ? and can I use my aeroplane electric starter to start the engine ? As I hate pull starts. Is the placement of the engine an fuel tank critical ? (weight distribution). Cheers, Andrew.
Old Dec 29, 2007, 08:57 PM
w3bby is offline
Helsingborg, Sweden
Joined Jul 2005
Where are you situated? Help can come from other sources depending where you are.
Guess you didn't check the links I posted No, that is not a sub surface drive, that is a surface drive. This is the drive set up you are looking at
Setup on these boats is critical, prop angle, cg etc. As I said before, get with Ian or Dave and they should be able to help you, they have quite a few World Championships between them for this type of boat.
Old Dec 29, 2007, 09:48 PM
shappo is offline
Joined Mar 2007
Hi,
indeed I did check out the links but didn't contact either dave or Ian, however I will. I am located in Australia, and I feel a bit guilty asking either of them for a heap of help when I cannot purchase anything from them because of freight costs and exchange rate, it's just not worth it. However I will ask and see what they say. Do you know of anyone in Australia that has similar knowledge that I could purchase from as well ? thanks, Andrew.
Old Dec 30, 2007, 06:50 AM
w3bby is offline
Helsingborg, Sweden
Joined Jul 2005
Ok, this type of boat is not that popular in Oz I believe so you are a little on your own I would guess... Try a posting on the Australian forum for local help.
As regards asking for help from Dave or Ian you are going to be buying stuff from them (as suppliers for this type of boat aren't that common) or you will be making a lot of stuff yourself I'm afraid.
Other suppliers
MTL
Gunderts
Old Jan 06, 2008, 05:46 AM
john mc lucas is online now
Find More Posts by john mc lucas
Harrington N.S.W. Australia
Joined Jul 2006
Hi Shappo
That hull was designed by Alan Trinder back in the 60s, I think it was called the Avenger, usually run a .40 to .46 Engine. I seen that hull in our LHS in taree, ask gary for my Ph No and i will give you all the info you need, It should be set up simular to the picture posted by w3bby, I used to run that type of hull many years ago they are a lot fun set up properly, or pm me.
Cheers.
John Mc Lucas.
john mc lucas is online now Find More Posts by john mc lucas
Pro Boat ShockWave 26 EP RTR VS. MBP Offshore Flyer RTR Racing Boat w/FG Hull RC Boat Guide Racing Boats - Electric 4 Aug 17, 2005 08:58 PM
new plane on the way! What engine? jessh1969 Fuel Plane Talk 14 Jan 21, 2004 07:23 AM
New Look E Zone(What Do All the New Symbols Mean, etc?) bobandris Site Chat 1 Sep 23, 2001 07:42 PM
