Old Dec 27, 2007, 07:21 PM
Razor_Racer is offline
Find More Posts by Razor_Racer
Actively makin humans obsolete
Razor_Racer's Avatar
Northern Virginia
Joined Jul 2007
Tricopter Build
I've been gathering parts to build my own Tricopter, after being inspiried by the Y-UFO, but being turned down by that $400 price tag.
Control will be through 120 degreee CCPM mixing designed for helis (good thing I already have a DX7 for my T-Rex 450), and rudder will be done by pivoting the motors.
Heres pics of the parts so far...
Order from HobbyCity at a hefty $125
A trip to Michaels a few minutes ago left me with this $3 pre-built center frame
Also have carbon rods, plywood, and wooden sticks to finish up the little bits.
Razor_Racer is offline Find More Posts by Razor_Racer
Old Dec 27, 2007, 11:34 PM
crashagain is offline
Find More Posts by crashagain
Custom Auto Upholsterer
crashagain's Avatar
Redding
Joined Jul 2007
Looks interesting..
Keep the pics and write up's coming...
crashagain is offline Find More Posts by crashagain
Old Dec 30, 2007, 04:35 PM
Northern Virginia
Joined Jul 2007
Started on my motor mounts, made from 3mm thick plywood. It took a while to mark and drill the holes, since the motor mount holes and the wires coming out are in different positions on each motor.
Old Dec 30, 2007, 06:12 PM
Northern Virginia
Joined Jul 2007
Finally finished all of the mounts!
Old Dec 30, 2007, 06:50 PM
joeling is offline
Find More Posts by joeling
joeling's Avatar
Joined Nov 2005
Razor_Racer,
Very nice. keep it coming. BTW, I don't see any gyros. U do intend to use some gyros don't u? No gyros = super fast hands to balance the craft.
Regards,
Joe Ling
joeling is offline Find More Posts by joeling
Old Dec 30, 2007, 08:02 PM
KingBubbaTruck is offline
Find More Posts by KingBubbaTruck
Reno, NV
Joined May 2007
Holy Moly, That looks like it should have a good deal of lift.
I've got one of those motors on my fundango (plane) and it will pull it out of my hands vertically. I also used one to electify an old gentle lady I had laying around. I've been happy with the motors so far as they seem to run pretty nice and cool, for what I'm using them for on some 3s lipos.
Very interesting thread, looking forward to seeing it fly...
KingBubbaTruck is offline Find More Posts by KingBubbaTruck
Old Dec 30, 2007, 09:09 PM
Northern Virginia
Joined Jul 2007
Thanks guys. No gyros on this one, but later I can add an AP2000i stabilizer designed for helis if I wanted to. I already have some experience in a T-Rex 450, so hopefully this wont be too much harder. At least it will be cheaper to crash, though
Since I finished the mounts I'm getting started on the little things that allow the mounts to attach to some 5mm carbon tubes. Dunno if the tubes will be stiff enough for the thrust, but they fill stiff enough...
Anyways heres how I want to attach it. When I'm finish arranging everything I'll glue the carbon tubes to the mounts. Note my building doesnt look completely clean, I'm 14 so I have yet to fine my building skills
EDIT: Finished all three! Thats enough for tonight.
Old Dec 30, 2007, 11:02 PM
joeling is offline
joeling's Avatar
Joined Nov 2005
Hi Razor_Racer,
I'm impressed ! Keep up the good work ! You are 20 years ahead of me !
I think this thread may be useful reference :
http://www.rcgroups.com/forums/showt...ight=tricopter
Regards,
Joe Ling
Old Jan 10, 2008, 08:18 PM
Northern Virginia
Joined Jul 2007
Couldnt do much past two weeks, but finally tonight I finished up a little more. The little hexagon box is also from michaels, sure makes my life easier
Old Jan 10, 2008, 09:50 PM
tend2it is offline
Find More Posts by tend2it
Wow That's Cool!
tend2it's Avatar
Bay Area, CA
Joined Nov 2004
Lookin' great ... only concern is the wood might add too much weight ... carbon fiber is a lot lighter and strong.
--Eric--
tend2it is offline Find More Posts by tend2it
Old Jan 15, 2008, 12:19 PM
stefalo is offline
Find More Posts by stefalo
Joined Sep 2006
Razor,
I have been trying something similar to your build. I was originally going to do only mechanical movement of the motors but have decided I need to vary thrust. I see you have a dx7, hopefully you can help me. I have a dx6 and cannot figure out the setup for heli mode. I have no heli experience so this is all new to me, it just looked like a fun project. Can you tell me what settings you are succesfully using on your dx7. Also for your esc's if you don't have one in throttle how are you powering up the esc's. Any help would be great.
Thank you in advance
Stefan
stefalo is offline Find More Posts by stefalo
Old Feb 13, 2008, 10:03 AM
Northern Virginia
Joined Jul 2007
I havent programmed my DX7 yet as the model isnt ready to be programmed. I dont know how tbe DX6 works, so check your manual.
For the DX7, I will set it to 120 degree CCPM heli mode. The ESCs will go to elevator, pitch, and aileron plugs in the reciever.
When the radio is in the 120 degree CCPM, when you move the throttle up, the elevator, pitch, and ailerons also go up, because that is how CCPM helicopters increase the pitch of their blades.
Old Feb 14, 2008, 05:46 PM
Northern Virginia
Joined Jul 2007
Woo! Finally parts came in, took a couple weeks... possibly last time I order from bidproduct.
3 Beefier servos than the HXT 9 grams, along with 34 5mm wheel collars. I only needed a couple collars, but I couldnt understand from the web site how many are included, so I ordered some... oh well, the more the merrier
Oh yeah, old pic of steering set up:
Old Mar 01, 2008, 09:16 PM
Northern Virginia
Joined Jul 2007
Finally got around to doing more work
I basically got the steering setup finished after getting some threaded rod at the LHS. The servo is mounted with some double sided servo tape. I thought it would just be temporary, but I feel like it's sturdy enough to actually fly with it. Also the motor mount is CA'ed in, thats the only permanent part of the setup.
I mounted the motor on the very end of the carbon rod. The servo can handle the load just well, but the motor wires will be two feet long! Will it be okay?
Old Mar 01, 2008, 09:37 PM
Shpook is offline
Find More Posts by Shpook
What's that button do?
Shpook's Avatar
Hollywood, FL
Joined Feb 2008
Looks good...and unique. I'm interested in how this turns out, as it looks to be a different design that what I've seen around. Keep up the good work!
Shpook is offline Find More Posts by Shpook
