Old Dec 19, 2002, 11:29 AM
darmar is online now
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
Micro An-225 with 1" edf-s
Got inspired by Hawker's work and made me this one plus micro rc car guts.
ws 26
wgh 82 grams
has 6 home made 1" fans with hottest 6mm motors(38000 rpm)
for those micro cars.
rx used for diferentional trust control. Tx is two chanel AIR tech on 49 mhz fr.
Four motors closer to the fuse are DD from the source(kokam 560) and two motors at each side are running trough rx.
All but nose section is 1/32 balsa.
Flies over seven minutes on kokam 560 single cell.
darmar is online now Find More Posts by darmar
Old Dec 19, 2002, 11:30 AM
USA, PA, Pittsburgh
Joined Jul 2001
one more
Old Dec 19, 2002, 11:32 AM
USA, PA, Pittsburgh
Joined Jul 2001
fan
..or ducted PROP for some folks...
Old Dec 19, 2002, 11:41 AM
USA, PA, Pittsburgh
Joined Jul 2001
Next project is close to be completed
12" WS twin Mig 29 with 1 1/4 fans
shotting for AUW 25 grams.
Will post as soon as tests are completed.
Darmar
jimmyray is offline
Find More Posts by jimmyray
jimmyray's Avatar
Oxford, Alabama USA
Joined May 2001
AMAZING!!
Got to get some video!!
jimmyray is offline Find More Posts by jimmyray
Old Dec 19, 2002, 01:48 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Keewwwllll,
I agree, Movies movies moveis, moveis, moooooovies!
JasonJ is offline Find More Posts by JasonJ
Old Dec 19, 2002, 01:53 PM
Ductedfann is offline
Find More Posts by Ductedfann
Ductedfann's Avatar
mid west
Joined Jan 2002
That looks like fun. Do you think that it will be a good flyer for in doors?
My english some times not so good.
Ductedfann is offline Find More Posts by Ductedfann
Old Dec 19, 2002, 03:46 PM
USA, PA, Pittsburgh
Joined Jul 2001
I'll do the video as soon as wether is better. Plane does not tolerate winds of any kind since it has no movable surfaces for flight corection.
Turns are on the wide side, pretty scale. It can be flown indors but I didn't try it.
It's much less responsive than wattage lightning. Motors for turns are getting less voltage trough the rx than ones directly connected to the battery and that makes the model turn much slower and with bigger radius.
I dont have right charger for these KOKAM cells but one I use from Radio shack works fine,voltage has to be checked not to exced 4.3 volts.
Can't tell if the cell is getting worse after four flights using this charging method. Flights have still the same duration and battery is only warm to touch.
If these tiny motors are goin to survive 3+ voltage we'll see.
No problems with range. TX is made for 300 feet range but rx( from those rc cars) I use with long magnet wire as antena is good for the flights to 100+ feet which is god enough for me to see the thing and make the turn.
Darmar
Old Dec 19, 2002, 04:27 PM
Demon-Leather is offline
Find More Posts by Demon-Leather
"Experienced-Crasher"
Demon-Leather's Avatar
Rex, NC "Extreme Boonies"
Joined Jan 2002
NICE Work!
That's REALLY Kool! .... Say,if You hooked 2 of the outbard motors to the TX, do You think it would turn better?...
Or... perhaps some kind of sub-micro actuator like the Micro-Boys use that would break power to one side or the other of all 3 fans and re-engage the fans when the control was neutraled like a set of contact points? Bet it would turn pretty sharp then! You say You have 2-channel... You could use 1 for thottle-controll (up & down) and one for the actuator (left & right) Don't those micro cars have some sort of steering actuator You could cannabilize? A couple sets of contact breaker points from an old micro switch should suffice for the motor cut-offs....Just a thought Bob
Demon-Leather is offline Find More Posts by Demon-Leather
Old Dec 19, 2002, 04:51 PM
JasonJ is offline
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Ohh, how bout using car ESCs for the outboard motors, then then durring a turn the one would spin in reverse!!!!! I bet she would turn sharp then!
Old Dec 19, 2002, 04:56 PM
zbrubaker is offline
Find More Posts by zbrubaker
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
Can you say..."unrecoverable spin"? I knew you could...LOL
zbrubaker is offline Find More Posts by zbrubaker
Old Dec 19, 2002, 06:56 PM
Ductedfann's Avatar
mid west
Joined Jan 2002
Before on a small P-38 I made that used the motors to steer I just added an HS-50 no case as a eleavator and this made the turning much better.
Old Dec 19, 2002, 07:30 PM
USA, PA, Pittsburgh
Joined Jul 2001
Oh, I wasn't complaining about the way it turns just comparing it with model that flies on the similar setup.
the model wasn't ment to be fast and make sharp turns. That would make it fly like "rare bear" or something.
Thanks for the input anyway.
Darmar
Old Dec 19, 2002, 07:46 PM
jermaine is offline
Find More Posts by jermaine
crazy about airliner
forest MS, USA
Joined Mar 2002
material
Hey darmar
what is the material or the maker please post
jermaine is offline Find More Posts by jermaine
Old Dec 19, 2002, 08:16 PM
USA, PA, Pittsburgh
Joined Jul 2001
jermaine see the post No 1.
Discussion Sub 3" EDF with 2:1 thrust:weight? Bugman Jeff Electric Ducted Fan Jet Talk 4 Feb 20, 2007 08:02 PM
Discussion Gemini with dual brushless EDF's questtek Foamy EDFs 1 Dec 02, 2006 04:54 AM
what to do with a pair of GWS edf's ??? Beige Parkflyers 13 Dec 04, 2002 09:20 AM
45.1" Tempest with 10 CP 2400's Ron Daniels Scale Kit/Scratch Built 11 Aug 07, 2002 03:33 PM
OK to use an ESC with a brake for EDF? twinster2 Electric Ducted Fan Jet Talk 8 Feb 01, 2002 01:02 AM
